best way to remove cosmoline? | FerrariChat
Discussion in 'Boxers/TR/M' started by Triton, May 19, 2009.
  1. Triton
    Triton Karting
    May 17, 2009
    182
    Boston - Metro West
    Paul M
    what is the best way to safely remove cosmoline that has been there for 18 years in the engine bay of a Testarossa?
  2. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,289
    Maryland
    Curtis Campbell
    Shamile? I think you took care of this didn't you?
    I will have to tackle this myself on the next major cycle. I hate looking at it too.
  3. Jon H
    Jon H Karting
    136
    Houston
    Jon Halvorsen
    Diesel oil and a paint brush & rag works well.
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Yes, I have traveled this well worn path many times. :)
    I've been removing cosmoline on my 91 TR for the past 5 years. ( first 4 years was just super detailed cleaning )
    I've almost got it all....I mean ALL, removed.
    I've found the best thing is brake cleaner ( NOT NEAR RUBBER) and my trusty toothbrush. For areas with rubber use 3M wax and tar remover. Use the spray version as the stuff evaporates real real fast.
    Shamile
    Freeze...Miami Vice !
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Doesn't that eat your paint?
    Are you talking about stuff like CRC as shown here:
    http://www.crcind.com.au/catalogue.nsf/(TDS)/TDS5089%20Oct99/$FILE/TDS.pdf
    Any better recommendations?
    Note that CRC says:
    "Protect all rubber parts and painted surfaces from overspray."
    WD-40 is slower - but seems to work without damage.
    Thanks,
    Vince
  6. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    On machine tools we used kerosine for years. I don't think it would be a problem on the black paint.
  7. redtrman
    redtrman Formula 3
    2,292
    VA - Heart in Pitt
    Jason Bourne
    Just a note, when you remove the cosmoline, your car will no longer have a rust protectant on those metal parts so you might want to reconsider or have a replacement protectant applied to prevent rusting of that italian beauty.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Mineral spirits are cheap, pretty effective and not too aggressive on painted surfaces.
  9. rscholl
    rscholl Formula Junior
    Dec 4, 2003
    296
    Houston,TX
    I removed all of the cosmoline from my M5 with 3M adhesive remover. Worked great, but the cosmoline was much newer and came off very easily.
  10. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Yes, that's the stuff. You can buy it at Walmart. Don't use it near the paintwork. It's fine in the wheel wells, chassis area, under-pan, steering rack well area, frame rails. Use it in small spurts while scrubbing with a tooth brush. Don't use the full spray to remove the cosmoline without scrubbing.
    Yes, that's also the stuff. The 3M stuff is great...paint safe as well, but $9.00 a can and it doesn't go far.
    Redtrman,
    Yes, this is the rust protector, but it's sprayed so willy-nilly, everywhere else would rust where they didn't spray it. When I removed the cosmoline, I put new undercoating (Eastwood rubberized undercoating ) with a schutz gun and an air compressor. On top of that, I put a couple of coats of Eastwood extreme chassis black....looks great !
    Shamile
    Freeze....Miami Vice !
