Best Walkie Talkies For Runs? | FerrariChat
Discussion in 'New York Tri-State' started by ghost, Mar 17, 2006.
  1. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    A couple of people have reached out to me to inquire about the best WT's for runs. Are Motorola Talkabout's still the standard? I had an older pair and didn't find them great. I hear newer gen WT's have the ability to attach ear phones and all sorts of doo-hickeys.
    Recommendations?
  2. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    Good thread. My Radio Shack units aren't bad, but they don't always interface well with the other brands. Strange since we are on th same frequency, but neve the less I'm down for picking up a "group" buy on some good units.
  3. ghost
    Dec 10, 2003
    10,046
    Singapore
    Agreed, I think Ciao Bella likes his...
  4. ClydeM
    ClydeM F1 World Champ
    11,600
    Wayne, NJ
    Clyde E. McMurdy
    We tried this a year ago. Bleh on the quality.
    Although the range was adequate (1 mile or so), the quality of the transmission was not. Fuggetabout tunnels.
    Yelling into them was mandatory and rots-o-ruck trying to figure out what was being said.
    BTW: I used motorola (650's??? with 5mi radius) with headsets.
    update: I think I have the 6250s & I wouldn't recommend them.
    Motorola T6250
    Single Package Up to 5 Mile Range
    8 GMRS 1 watt channels
    7 GMRS/FRS 1 watt channels
    7 FRS 1/2 watt channels
    38 interference eliminator codes
    10 audible call alerts
    Ring alert
    Talk confirmation tone
    Lock - single key
    Button beeps
    36 segment LCD display with icons
    Backlit LED
    Transmit LED
    Battery meter indicator with audible low battery alert
    Audio accessory connector (single pin)
    Time out timer
    6.02(h) x 2.20 (w) x 1.32 (d) - size of two-way radio including antenna
    Includes:
    Removable Swivel Belt Clip
    One Year Warranty
    Users Guide
  5. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
  6. Acura Nsx Pilot
    Acura Nsx Pilot Formula Junior
    Nov 10, 2003
    518
    NyC
    Bailey
    Having been on over 50 runs in the past few years some of them over 200 miles in distance one way I highly recommend the motorola XTN line of business 2 way portable radios. They offer all the features you are looking for from VOX ( Voice Activated Transmission ) to several different headphone to covert hidden ear/mic set ups. They offfer everything from a 1 watt to a 5 watt model but 2 watts is what I have been using with the Nsx Club and it covers about 3 miles effectively with a maximum quoted range of 5 miles. I do not recommend getting anything less then a 2 watt model. Problems that maybe encountered with radios of less and more wattage can be this. People with low wattage radios can recieve transimissions from others with high wattage radios but cannot effectively transimit back because they maybe beyond there effective transmission range. The cars most effected by this are the lead cars and end cars. I think everyone gets the point here without me going into this further. I would post pics but I am beyond my limitations for a non subscriber so here are links.
    This is the radio I recommend and use
    http://www.motorola.com/governmentandenterprise/northamerica/en-us/public/functions/browseproduct/productdetailpage.aspx?navigationpath=id_803i/id_1388i/id_2352i/id_2200i
    Brand New Lot of 6 New Motorola XU2100 Two-Watt, One Channel UHF Radios
    Range up to 6 miles outdoors / 250,000 sq. ft. or 20 floors indoors 2-watt technology provides up to four times the power of family radios
    Operates on 56 UHF business-exclusive frequencies
    Single-channel operation with 121 Interference Eliminator Codes (83 Digital and 38 Analog)
    Voice-activated, hands-free operation (VOX) capability. Requires optional accessories. Requires FCC License
    Each XU2100 Radio includes the following:
    2 Watts of Power 56 UHF Business Exclusive Frequencies (FCC License Required)
    Designed to Mil-Spec 810 and IP54 Specifications
    38 Analog and 83 Digital Interference Eliminator Codes
    3 Scramble Settings To Reduce Eavesdropping
    Audible Call Tones VOX (Hands-Free Use With Accessories) With 3 Sensitivity Levels
    Cloning Compatible (Multi-Unit Charger Required)
    Drop-In Charger Compatible (Drop-In Charger Required) Lightweight - Only 9.9 oz With NIMH Battery
    2 Pin Accessory Plug 1500 mAh NiMH Rechargeable Battery
    10-Hour Plug-In Charger
    Swivel Belt Holster
    This unit will take standard AA batteries as well as a nicad pak which is a nice feature. I carry a compact inverter in my car and keep mine plugged in so that I have full power all the time.
    You can find them used and new on ebay.
    Typically used you can find them from $50 - $120
    New on Ebay they can be had for less then $160
    I recommend getting the UHF models XU2100 and up.
  7. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    These are ok as far as wattage but on the FRS/GMRS frequency band you will get alot of interference and cross talk and anyone with a regular FRS/GMRS no matter what there wattage is if there with in your range can interfere with you.
  8. idloveaguinness
    idloveaguinness Formula Junior
    Nov 3, 2003
    684
    LI NY
    Kevin Landry
  9. ghost
    Dec 10, 2003
    10,046
    Singapore
    Great write-up Bailey. Thanks.
    Seems like a winner. Have you used the headset / earbud accessories? Would be nice to be able drive without having to use one hand for push-to-talk operations. At least for us old school 6-speed guys. - :)
  10. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    I do not use the VOX feature but I do have the remote mic/speaker for mine which I attach to the seatbeat up by my shoulder. Its the same way highway patrolman wear theres and I find it is easy to toggle and transmit as well as hear clearly. View link to see what I mean
    http://img19.imageshack.us/img19/7582/radio0rp.jpg
  11. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    For those who are concerned about the notation that a license is required I have never been asked for one and you can buy these radios at any staples or office depot. In the case that you want to cover yourself anyone person can get a license and you can use theres. So in this case fchat or someone here submits a application for one and then everyone here can use it for club drive events and it makes it legal so that you dont have to worry about the FCC coming down on you. The nsx club has a similiar license and I operate under there license.
  12. ClydeM
    11,600
    Wayne, NJ
    Clyde E. McMurdy
    I did check with the FCC on this. Technically, it does require a yearly license renewal. Something like $90 as I recall. But as Bailey suggested, these radios are sold in volume all over. Do you really think everyone is getting their licenses when they use the high-power band?
  13. ghost
    Dec 10, 2003
    10,046
    Singapore
    Bailey, no issues with FCC "business-specific" frequencies vs. "FRS" frequencies? It seems that WT's on both frequencies can talk to each other but want to confirm.
  14. ghost
    Dec 10, 2003
    10,046
    Singapore
  15. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    Here are some of the advantages of having radio communitions
    You will hear announcements that
    " We are getting off at the next exit ....PLEASE dont crash into me or cause an accident trying to exit "
    " There is law enforcement up ahead or coming up the rear ...SLOW DOWN ! "
    " I am stuck at the light or intersection .....Please slow down so I can catch up with out breaking the sound of speed "
    " I think my car is on fire I am pulling over to check before the smoke in the cabin over comes me "
  16. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    I have never tried this but I see that yes the FRS frequencies do overlap the business frequencies but I could not find any specific information as to what frequency the motorola frs radios operate on. Also the FRS radios mentioned earlier by john I did notice a notation that said that they also require a license. In my experience thou when using the business band radios it is very private with Little to no cross talk and extremely clean and clear communications.
  17. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    They look like factory refurb units and there NIB. There are still five days plus left for bids and these will go for no less then $120 a unit I bet.
  18. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,247
    Northern CA
    Yin
    Here's the scoop on FRS/GMRS channels and usage/licensing.
    FRS is unlicensed, limited to 0.5 watts and uses 14 frequencies, commonly designated as channels 1-14. FRS radios are handheld and have fixed/integrated antennas. Usual range for FRS is 0.5-1 mile.
    GMRS is licensed, can be higher power, up to 50 watts for a basestation, but usually 1-4 watts for a handheld. GMRS radios operate on FRS channels 1-7 (these 7 frequencies are shared between FRS and GMRS) and an additional 8 channels designated 15-22 (note that a GMRS radio does NOT normally include FRS channels 8-14). Under normal power, a handheld GMRS radio is capable of 1-2 mile range and a mobile/base radio is capable of 2-5 miles. Also GMRS radios often have an external antenna capability (such as a car mount antenna), using an external antenna can significantly extend the range within the same power limits. GMRS channels have "little crosstalk" and are "clean and clear" because there's less traffic and more power.
    GMRS also has an additional 8 frequencies, paired with channels 15-22 that are assigned as "repeater" frequencies. Using those frequencies with an active repeater in the area can extend the range of a GMRS radio to as much as 50 miles. Repeaters are privately owned and misuse will probably result in the repeater being shut down against the abusers and a complaint being filed.
    An FRS/GMRS radio will operate on all FRS channels 1-14 plus GMRS channels 15-22, but use on channels 15-22 requires a GMRS license. GMRS license violations have not traditionally be tracked down and enforced. However, that was partly due to bureacratic confusion between the complaints office and the enforcement office of the FCC (the complaints office wasn't passing on GMRS violation complaints). Recently, the FCC enforcement office has agreed to take GMRS complaints directly. Penalties include confiscation and fines on the order of about $10K.
  19. ylshih
    Honorary Owner
    Mar 21, 2004
    20,247
    Northern CA
    Yin
    BTW, the XU2100 does NOT operate on any FRS/GMRS channel. It's another business service entirely. The FRS/GMRS frequencies are in the same general frequency band (460-470 MHz), but they are not the same frequencies as those listed for the XU2100.
  20. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    OK looking into it alittle further I dont think that the two frs radios and business radios will work with each other as the frequencies are alittle off
    Here is the frs channels/frequencies
    http://www.ba-marc.org/writeups/gmrs-frs-freq.htm
    Here are the Business channels/frequencies
  21. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    I'm in on this group buy. Let's make a good offer and also get the ear bud accessory.
  22. Acura Nsx Pilot
    Nov 10, 2003
    518
    NyC
    Bailey
    You could have just said this before and saved me from doing more research on this relic of a computer at my sisters house. Thank You thou for the info it is greatly appreciated.
  23. ghost
    Dec 10, 2003
    10,046
    Singapore
    Geez Yin - is there anything you don't know - :)
  24. ghost
    Dec 10, 2003
    10,046
    Singapore
    So basically, if we want to coordinate with other WT users, who most likely will be using WT's that employ a FRS/GMRS frequency, it is probably a good idea to AVOID the XU2100 unit.
    Might still be a good buy if we get all five units, as those five people whould have a clear and strong communication amongst themselves, but obviously compatabilities beyond that, with traditional FRS/GMRS units, would seem to be a problem.
