Best single post lift?
Discussion in 'Ferrari Discussion (not model specific)' started by sherpa23, Jul 5, 2014.
  1. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    #1 sherpa23, Jul 5, 2014
    I am not sure where the best section for this would be so I am going to put it here.
    I have a very high 2 car garage but it is somewhat narrow. I am thinking of putting 1 or possibly 2 single post lifts. I don't think that 4 post lifts would work great in here so single posts would be good. Does anyone have any experience with these and can they recommend any to buy or to avoid. Thanks.
    I'm thinking about these:
    http://www.aclifts.com/parking/m1-65.asp
    FYI, here is a pic of the garage in question.
  2. HotShoe
    HotShoe F1 Veteran
    8,599
    Lake Worth, FL
    Anthony Lauro
    Do you want it just for storage or do you want to use it for work?
    The collector I used to work for go a two post Rotary with the asymmetrical low rise arms and it's IMHO the best out there. The low rise, asymmetrical extension arms are a must for the F40. Even them it might be close and you'll need planks to get it high off to swing the arms under.
    I'd also recommend getting the optional soft pad mounts to avoid marring the surface.
  3. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    No work. Just storage. Have a place nearby for work.
  4. Tinbender
    Tinbender Formula Junior
    327
    Raleigh,Lake Lure,NC
    Terry W. Phillips
    I have two of their m1-6.5 lifts and love them. The only problem is you have to back one car on so you can get out of the car. Also this may be a problem with the cars parked under the lift. You may have to back the one on the left in.
  5. ersatzS2
    ersatzS2 Formula Junior
    862
    Norfolk VA
    #5 ersatzS2, Jul 6, 2014
  6. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    I have a single-post bendpak for parking and a two-post bendpak for working on the cars. You can see the single-post in my profile picture. It has worked well for me for 4+ years.
  7. Aaron360
    Aaron360 Rookie
    Jul 22, 2012
    27
    Charlotte NC
    Aaron Gray
    #7 Aaron360, Jul 6, 2014
  8. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    Awesome. How come you guys went with the bendpak over the ac one? Not worth the premium? Regardless, I love the feedback and the pics.
  9. Aaron360
    Aaron360 Rookie
    Jul 22, 2012
    27
    Charlotte NC
    Aaron Gray
    Not sure about the price for the ac one... I paid around 6k for mine installed. I thought that was a fair price for this lift.
  10. IamRobG
    IamRobG F1 Rookie
    Jun 18, 2007
    4,092
    NY
    Bendpak doesn't have it on their website anymore. It says "discontinued"
  11. Graz
    Graz Formula 3
    Oct 15, 2012
    2,327
    New Jersey and Florida
    Graziano
    Aaron, are the ramps low enough so that you don't scrape the front end when you drive on them? I used to have a 4 post lift that required modification to avoid that issue. It was such a pain I removed the lift. Thinking about a single post like yours now. It looks less intrusive and safer to drive on. Thanks, Tom
  12. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    Just curious - how tall is your garage and how much room left when the garage door unfurls above when open?
  13. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    #13 ar4me, Jul 7, 2014
    I had my doors converted to high-lift, and changed to jack-shaft openers on the wall eliminating the center rail of your typical garage door. IMO, those are must-do changes and can add notable cost (compared to the lift itself). Added pic from my profile:
  14. ersatzS2
    862
    Norfolk VA
    #14 ersatzS2, Jul 7, 2014
    That's quite interesting. I can think of two reasons based on feedback I've gotten on mine over the years: 1) The lift is pretty terrifying for installers. I am sure the physics pencil out, but there is still some substantial risk factor around the integrity of the concrete slab, quality of the anchor bolts etc. If you look at my build thread on the garagejournal link, you will see my 'safety chain' to add a bit of piece of mind if an earthquake (they do happen in NJ) were to suddenly jolt the base loose.
    2) the lift is quite expensive relative to a 4-post. 4-posts are incredibly inexpensive and made by dozens of mfrs. This lift is $6K which would buy 3 cheap 4-posts. So maybe the addressable market wasn't that big. But see my garagejournal thread for more single post options...
    PS: if I had to do it over, I think I would've bought the AC lift. I think it was slightly more expensive and also there was no 'certified' local installer, so I went with BendPak. But the quality of of the AC seemed higher and I liked that it was US made.
  15. Aaron360
    Aaron360 Rookie
    Jul 22, 2012
    27
    Charlotte NC
    Aaron Gray
    Tom, yes the ramps are low enough that I haven't had any issues driving up on them.
  16. Aaron360
    Aaron360 Rookie
    Jul 22, 2012
    27
    Charlotte NC
    Aaron Gray
    I have around 11 feet from the garage floor to the bottom of garage door opener, this set up works good for me because I have two low profile cars, the 458 and a 1933 ford coupe with a chopped top. I would probably have to go to the jack screw opener system if I had two regular height vehicles.
  17. RossoDiamante
    RossoDiamante Karting
    Jun 3, 2013
    214
    Mid-Atlantic, US
    My garage looks similar in dimensions to yours. I wonder if I could squeeze this type of lift in. I haven't done anything to date because the 2 and 4 post lifts seem to be wide enough to impact the space available in the other bays for our other cars.
    What, if any, additional concrete reinforcement work did you do to install this lift? I'm pretty sure I have a traditional 4" slab in my garage which has been structurally fine with no cracking over the 16 years I've been in the house. But I question whether that is enough?
  18. Todd308TR
    Todd308TR F1 World Champ
    Nov 25, 2010
    11,071
    LA
    Todd
    Is it ok to use a lift like this, with the driver over kit, for long term storage?
  19. ersatzS2
    862
    Norfolk VA
    No additional reinforcement but slab was poured 6" thick and it was a high density concrete formulation. If I had to do it over, I think I would pour a special footing with the 'cast' in place. But so far no problems. (6 yrs)
  20. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    I'm considering buying a lift as well but am wondering about installation. Did you hire someone to install it for you? If so, where did you find them?
  21. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,575
    Gates Mills, Ohio
    Jon
    I'm also considering this. There are installers recommended on the BendPak site, as a starting point.
    http://www.bendpak.com/Support/clickserve/
  22. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    I had an AC lift in Florida (similar design to the Backyard Buddy), and it was awesome!
    They are a great company, and their customer service is very good in my experience.
    BT
  23. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
  24. Italian Stampede
    Jul 10, 2014
    56
    As with what I mentioned in regard to care car products, you get what you pay for. Be sure not to buy some cheap asian made lift, chances are you will toss it out in a year and buy a better one.
  25. clex2
    clex2 Karting
    Aug 30, 2009
    103
    This is not a BendPak unit. It looks like a SP-6K-SS which goes by various company names but is the same unit.
    I've have heard it works well.
    Auto Lift AL-SP-6K-SS 6000 lb. Single Column Car Storage Lift
