Best paint for brake calipers?
Discussion in 'Technical Q&A' started by Aldo360, Dec 3, 2018.
  1. Aldo360
    Aldo360 Rookie
    Dec 1, 2018
    15
    Aldo Benato
    Can you tell me from experience a good paint to use to paint brake calipers
    Nothing from Autozone please, high quality
  2. tazandjan
    39,037
    If you are not going to use them on the track, good old PPG body paint and clear coat work fine, with the decals under the clear coat. What color do you want and we can give you the PPG paint code?
  3. Aldo360
    Aldo360 Rookie
    Dec 1, 2018
    15
    Aldo Benato
    #3 Aldo360, Dec 3, 2018
    Thank you,
    Suprised to hear PPG could work because of the high temperatures but I am no professional.
    I want yellow , the same color yellow as on the badge on the side, with the horse.
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,651
    If you remember, good brake fluid boils ar 600ºF, stuff that has been in the car for 6 months no better than 500º.
    So, we are not talking about the temperatures of the pads (1200ºF) or rotors (1000ºF), but something way lower.
    If you don't take the car to the track, and don't find a need to decelerate from 160+ to 55 MPH as fast as possible, your brake calipers won't get that hot and most paints can deal with those kinds of temperatures.
  5. Redneck Slim
    Redneck Slim Formula 3
    1,622
    Palo Alto,CA,USA
    Walt Kimball
    The paint has to be unaffected by brake fluid. Otherwise paint (especially around the bleeders) will come off when changing brake fluid.
  6. TheDiffuser
    TheDiffuser Formula Junior
    Nov 11, 2017
    404
    The Diffuser
    Just had mine done as you want - to match the yellow shields. The paint brand wasn't anything special, but was a very high temperature type. Then clear coat with the new Ferrari decals.
    I'm really stoked with the result. Didn't want the Allen bolts black.
  7. tazandjan
    39,037
    308 milano likes this.
  8. Aldo360
    Aldo360 Rookie
    Dec 1, 2018
    15
    Aldo Benato
    That looks good but what about painting the word Ferrari is there a trick for that. Or was it decals, could you put decals there for the Ferrari writing?
  9. tazandjan
    39,037
    High temperature brake decals. You can find them on the internet in the size you want or get OEM ones from Ferrari.
  10. moysiuan
    moysiuan F1 Rookie
    4,090
    Canada
    Brake calipers have rubber seals inside, rubber hoses attached to them, so they do not get that hot or else the rubber would degrade. Which does happen in racing, on tight circuits.
    But that's why regular paints, especially enamels which are often advertised for engine blocks, are ok. Regular paints with organic ingredients are good to about 400F. To get the higher temp capability, ceramic or aluminum silicones are part of the solids, sometimes in a two part epoxy type of blend. The downside is they typically need to be heat cured at about 300F, which if your brakes calipers don't get that hot the paint won't cure and will flake off. And curing the caliper in a oven at the required temp will do no favours for the rubber parts, unless the caliper body was fully disassembled with no rubber parts left on.
    The stickers will probably be heat capable to a lesser degree. But since they work well for many, that tells you that the calipers don't get that hot.
    https://www.ebay.com/itm/Ferrari-HI-TEMP-PREMIUM-BRAKE-CALIPER-DECALS-STICKERS-CAST-VINYL-/362071223258
  11. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    Anyone have any recommendations for a vendor that can do both?
    Powder coat or a brake fluid resistant paint & rebuild the calipers with new seals?
    Basically so it looks OE with the Ferrari logo.
  12. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    625
    Eden Prairie, MN
    Matt
    Use a self etching primer as a base coat under the color and then clear. The primer will help with adhesion and longevity
