Best Gas for Your Ferrari (sports car)? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by venusone, Apr 21, 2005.
  1. venusone
    venusone F1 Rookie
    Mar 20, 2004
    3,238
    Ok, so 93 Enmark is filtered twice, BP is pure all that, Chevron has the best injector additive. What do you put in your Ferrari (sports car)?
    I'm always afraid to stop at just any gas station...
  2. HobbsTC
    HobbsTC Formula 3
    1,469
    Lakeland, FL
    Thomas
    I know it's not a Ferrari, but my friend Fred had a 650hp supercharged Mustang with a built up motor. After he blew a head gasket, we took it apart and the pistons and cylinder walls looked almost spotless. He only used Amoco and that convinced me right there to only use it as well. Just my $0.02.
  3. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Whatever the nearest gas station has.
  4. BigSky355
    BigSky355 Karting
    Nov 8, 2004
    196
    Montana
    Chris
    Out here choices are a bit limited so I usually use whatever is convenient ie. Exxon, Conoco.
    Chris
  5. LAfun2
    LAfun2 Three Time F1 World Champ
    Oct 31, 2003
    39,248
    California
    Ryan
    Come on Jerry! You mean you don't plan the Ferraris gas stops days in advance, planning your trip just right, so that when the gas needle is at half tank, you right away call your gas agent, who comes home to deliver the special Ferrari Gas? I mean don't you know if you take bad gas your car might blow up, and if you let it go under half tank, the engine will catch on fire? The special Ferrari gas has added minerals and proteins for your cars diet. You are hurting the ferrari just by going anywhere ;)
    To answer the thread, I am with Jerry, wahtever is close by. :)
  6. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    The base gasoline is pretty much all the same, it all comes from the same pipelines and even if it was refined at a Shell refinery, all that counts is that Shell gets the same amount out of the cross-country pipeline as they put in. Then the unique additive packages are added and that's where the only differentiation occurs. (With the exception of Ethanol being added in green and agricultural states.)
    There's a recent initiative being pushed by the automakers to ensure that gasolines have enough cleaning agents (more than required by law). This is called "Top Tier" gas http://www.toptiergas.com/
    This is kinda like asking "What kind of motor oil for my Ferrari" or "What's the best Ferrari". Everybody's got an opinion and there's not really such a thing as a consensus. The only recommendations I think are necessarily valid are that it's best to avoid Ethanol (except for the first tank of spring to absorb water). BTW, I just discovered that these Top Tier gasolines have 8-10% Ethanol! Shame on you, Shell!
    Other than that... lots of people have had good experiences buying discount gas at Costco, lots of people have had good experiences buying only Shell b/c they sponsor Ferrari F1. In the last few years, people across North America have had problems with high Sulphur content gasoline ruining their fuel level senders and that happened at a lot of brand name fuel pumps as well as the generics. Why? Because it all comes from the same batch of crude (see above).
  7. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,778
    IgnoranteWest
    A blown head gasket will leak all kinds of coolant into the cylinder and steam clean the cylinder walls and piston tops real purty! :D
  8. Rifledriver
    36,760
    Personally I apply a ratio of distance/cost.
  9. Gatorrari
    Gatorrari F1 World Champ
    16,376
    Georgia
    Jim Pernikoff
    Over the years, two master mechanics have told me they consider Amoco to have the best gas, and Arco the worst. All the other "name" brands are similar, but stay away from "no name" gas. Has anyone heard other opinions?
    One thing I've heard repeatedly: if the truck is in the station filling the tanks, drive on. The act of filling the tanks can stur up any impurities that may have been sitting harmlessly at the bottom of the tanks. Unfortunately, those impurities will take time to settle back down, and there's no way of knowing if the truck has just left!
  10. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    lol Ryan... I only plan for the H1 since I need Diesel. :)
  11. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    A friend of mine who owns gas stations told me to avoid premium gas at mom-n-pop gas stations out in the middle of nowhere. The idea is they don't go through enough premium gas on a regular basis to keep the gas 'fresh', whatever that is. Apparently if the tanks aren't refilled regularly then sediment can build up. So in that case it would be better to use 89 octane instead of 91. High-volume gas stations are best (ie Costco).
  12. SrfCity
    SrfCity F1 World Champ
    Shell here, usually. I'm a sucker for the V-Power marketing propaganda and the Ferrari sponsorship ;)
  13. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    104 octane race gas. $4.59 a gallon.
  14. Dr Tommy Cosgrove
    36,232
    Birmingham, AL
    Tommy
    I try to stick with Chevron. Amoco second.
  15. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    Actually it is probably not sediment, but more likely water. Fuel and fuel oil can act like a dessicant and draw water. This is especially true of stations that sell diesel but don't sell very much. For me I apply the following formula, location X time frame/ price and that usually equalls SAM's.
    ________________________________________________________________
    F512M-The last of a spectacular series of vehicles and the "M" stands for MAGNIFICO!
  16. Fred2
    Fred2 F1 World Champ
    18,044
    nj
    In order to preserve the originality of the car, I have made arangements to have fuel imported.
    I work with a Gas Station in Milano that ships me a 50 liter drum of Agip premium fuel once a month.
  17. Tubi
    Tubi Formula Junior
    Jul 1, 2004
    577
    Athens
    Hari
    Shell Optimax
  18. Ferrari 328 Euro
    Ferrari 328 Euro Formula Junior
    Jul 19, 2004
    423
    Salem, MA
    Brandon
    Premium Unleaded from Mobil for me....
    Occasionally add an octane booster, but not with every fill-up.
  19. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Sam's when I'm home. Then it is pretty much price/location/how far down is the needle...
  20. rikilamb
    rikilamb Karting
    Nov 13, 2003
    67
    surrey
    riki lamb
    Shell Optimax at 98 octane
  21. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I use Amoco/BP 93 octane for my M5, Amoco/BP 87 octane for my wife's H2 and Mustang and Citgo 100 octane for my BB512i. And, I do notice a difference in the Boxer when I use 93 octane instead of 100 octane...i.e., detonation at WOT.
  22. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    like say what now?
  23. marknkidz
    marknkidz Formula 3
    1,323
    so cal
    mark
    Here in So. Cal I use Uno-cal "76", I mix 1/2 100 octane race fuel and 1/2 super unleaded both are available at select gas stations. I dont know if it makes a difference!!
  24. glh
    glh Formula Junior
    Mar 26, 2005
    328
    Burlington VT
    G.L.
    The following is information I have gotten per someone I know really close to me that is President/CEO of a 700 employee Chemical Engineering Consulting firm with offices worldwide. Basically they design and build petroleum refineries.
    Any fuel you put in your engines that is above what the engine specification is goes right out the tail pipe.
    If the engine is design to work with 87 Octane putting 91 is just pouring money out of your exhaust pipe and your wallet. If your engine genuinely runs better (less knocking), I encountered that in a V-10 Excursion I owned to tow my boat it means you are more than likely using your engine for something it should not be stressed that much to do in the first place! And it will soon kick you back!
    Also regionally all fuels come from the same refineries whatever the brand. As an example if you buy fuel in Eastern Canada it has been refined at the Ultramar plant in Quebec City, no matter what the brand is. Some companies might mix additives once it is in the truck but I am told this is more advertised than it is actually practiced.
    I imagine all F-car engines are rated for 91 Octane anyway taking into consideration the high compression ratios and rpm involved. Most people here would know better than me.
    I have experienced putting hi-octane fuel in my boat (i.e.: 55 Gallons of 106 Oct. in a tank that holds another 200 Gallons of 93) when doing "Poker Runs" in which you tend to go WOT in longer stretch than usual. I noticed the engine ran a little cooler, I asked my referenced person in the first paragraph how that would be and he mentioned that the engines I have that run with a bypassed thermostat (very different than cars that run at much higher temperatures (needed for emission regulation) and usually a constant temperature with fully functional thermostat) might experience better heat dissipation due to the slower burn rate of the fuel brought on by the higher octane and thus running unburned fuel thru the exhaust valves and heads, he said it might be a little because of that but…. more than likely it was due to lead in the racing fuel that acts as a much better heat dissipater and lubricant thus helping the engine run more efficiently. He also added that I could get away with running racing gas that contains lead in the boat due to my straight exhaust and no-catalytic converters… He did not however volunteer to pay for the $5US a gallon that racing fluid costs or help into pumping it from a barrel into the freakn boat!
    I hope this helps, sorry for being long winded I hope I explained myself somewhat clearly… Always a challenge for me!
    G.L.
  25. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Octane: Your compression ratio determines this. Use the LOWEST octane you can without pinging. The owners manual is best; don't think higher or lower than they recommend is better; it's not.
    Additives: Brand name gas has all kinds of good additives; cheapo gas does not. Buy the brand name or keep carb/injector cleaner in your garage. Some people have more sucess with one brand than another; this is a fact, not a superstition and so pay attention to how your engine likes the brand you use.
    Water: ALWAYS go to a busy gas station. They get new shipments a lot and you will get less water and crud than with Joe's Fillin' Station out in the boonies.
    Season: There are Summer and Winter formulas. See above to be sure you have an up to date gas.
    Ken
