Best garage flooring | Page 2 | FerrariChat
Discussion in 'Detailing & Showroom' started by ko23, Dec 13, 2016.
  1. Brian Show
    Brian Show Rookie
    Apr 13, 2020
    18
    Brian Show
    I apply micro cement to floors and think the products are good. There are a few different brands about and now I only apply one but I am biased as I distribute it. I've not had any experience with epoxy floors. I use a festfloor micro cement which is very thin but very tough wearing which makes the micro even stronger as well as solidly water proof
  2. Hopeful
    Hopeful Karting
    May 31, 2019
    153
    Vero Beach, FL
    Tony M.
    No need to do anything but listen to Shaun. Had the garage in my newly built home done 6 years ago. Floors ground, 100% solids epoxy, chips, and clear coat. Still looks great, clean up is simple, no hot tire marks, and nothing seems to stain it except one small spot where I spilled nitromethane and didn't wipe it up. I wash it out once or twice a year and in between, windex and a paper towel takes up anything.
  3. Falcon7x
    Falcon7x Karting
    Feb 20, 2012
    190
    Flight Level 450
    Stew
    Mine lasted 18 years, was ok for the price. I now have swistrax, much better but of course a bit of $$$.
  4. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
    I've used Rustoleum epoxy shield in 2 houses. Works well and is easy to roll out. Stands up to fluids, jacks and jackstands. My only complaint is that, after 5-6 years, I got some peeling under the tire areas. If I were to do it again, I would go solid color--without using the little paint chips.
  5. Voda
    Voda Formula 3
    Oct 10, 2013
    1,808
    Seattle
  6. Tifoso Ferrari
    Tifoso Ferrari Formula Junior
    Nov 7, 2005
    578
    Upper Volta
    Gianni Cagate
    Terrazzo tile … nothing better nor more beautiful
  7. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    398
    FL
    David
    Shaun, my shop floor was treated with an unknown commercial spray on sealer when new, about 10 years ago. It has done a decent job of sealing the concrete, but oil stains are hard to remove. I usually just use brake cleaner on spills, and it comes up fairly well. I'm thinking of doing an epoxy coating, but concerned of bonding with the unknown sealer. How would you prep the concrete in my situation? My shop is 3,200 sqft, with most of the oily diy work being done in a 20x20 area where my lift is. I applied the Rustoleum epoxy to our new 2.5 car attached garage last year. If I tackle the shop, I'd definitely rent a commercial grinder....
    Thanks!
  8. pexogoce
    pexogoce Karting
    78
    pexogoce
    I am purchasing a house in a couple weeks with a 3 car garage (750sqft) and I want to coat the garage floor. I plan to clean and etch the floor with muriatic acid first but I would like to get opinions on which kit to go with. I see great reviews on the Rustoleum Garage Shield and the Kilz brands as well as the ColoredEpoxy brands. What are your recommendations? And go!
  9. pexogoce
    pexogoce Karting
    78
    pexogoce
    no response to this
  10. Hopeful
    Hopeful Karting
    May 31, 2019
    153
    Vero Beach, FL
    Tony M.
    I would be leery of any DIY product. A professionally-installed, solvent-based epoxy that is near 100% solids is worth the expense.
  11. pexogoce
    pexogoce Karting
    78
    pexogoce
    @Hopeful thank you so much for your suggestion
  12. Dougster
    Dougster Karting
    Feb 28, 2013
    157
    Dallas TX Area
    I did the rustoleum kit on my last house. Held up for about 2 years then started to peel. Others I knew had the same results. I ended up having to cover it with the race deck plastic. On my new house now I had it done professionally. They grind the floors rather than etch them. Time will tell…
  13. pexogoce
    pexogoce Karting
    78
    pexogoce
    @Dougster also thank you for your suggestion
  14. Vegas CS
    Vegas CS Formula 3
    1,122
    Vegas
    James
    I had my garage floor done by a company called Fastlane Coating. They are in a few states and use a polyurea (sp). Supposed to be more durable than epoxy.
    These are the best photos I have on my phone.
    Flea7, Rexcat458 and colorfull like this.
  15. pexogoce
    pexogoce Karting
    78
    pexogoce
    Polyurea coatings are indeed a popular and durable option for garage floors. They are a type of protective coating that can withstand heavy loads, resist chemicals and stains, and provide a glossy finish. Unlike epoxy coatings, polyurea coatings can be applied in a wider range of temperatures and cure quickly, allowing for faster installation.
    Fastlane Coating is a reputable company that specializes in polyurea garage floor coatings. If you had a positive experience with their services and are satisfied with the results, that's great! It's always a good idea to do your research and choose a reputable contractor with a good track record to ensure that your garage floor is installed properly and will last for many years to come.
  16. pexogoce
    pexogoce Karting
    78
    pexogoce
    nothing hear from any one.
  17. ferrariwithsnowtires
    ferrariwithsnowtires Formula Junior
    Dec 17, 2005
    620
    colorfull and Face76 like this.
  18. Brian Show
    Brian Show Rookie
    Apr 13, 2020
    18
    Brian Show
    Determining whether the garage floor coating is epoxy or polyurethane can sometimes be challenging by appearance alone. However, you can perform a simple test to get a better idea.
    Acetone Test: Apply a small amount of acetone (nail polish remover) on an inconspicuous area of the floor and let it sit for a few minutes. If the coating softens or dissolves, it's likely polyurethane. If it remains unaffected, it's likely epoxy.
    To recoat the areas, you can certainly apply a layer of clear coat over the existing coating to prevent further peeling or degradation. You can use a clear epoxy coating designed for garage floors or a polyurethane clear coat. Make sure to clean and prepare the surface properly before applying the clear coat.
    If you're looking for a high-quality primer to ensure proper adhesion for the clear coat, you can consider using Primer No6-100 ml can' from Aerospheres https://www.aerospheres.com/products/paints/primer-no6-100-ml-can/. It's essential to follow the manufacturer's instructions for both the clear coat and primer for the best results.
