Best Fuel Injection system cleaner ? | FerrariChat
Discussion in 'Technical Q&A' started by finnerty, Apr 15, 2015.
  1. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Anyone have recommendations for a good "pour in the tank" product that has worked well for you ? This is for a modern car with EFI injectors (not our old trusty Bosch CIS) if that makes a difference.
    I haven't used any in a very long time, so I'm not up on the latest products / recommendations.
    Thought I'd give it a try at least before I go blow $800 on a new set of injectors.
  2. Cribbj
    Cribbj Formula 3
    David, the favorite seems to be Chevron Techron in a can, but nothing beats pulling the injectors and sending them off for a proper cleaning by a specialist. It runs between $15 and $20 per injector and is well worth doing at every, or every other major.
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I would add that when you use the Techron add it to a half to quarter tank of gas. This increases the concentration and improves performance of the product.
  4. DavidJ
    DavidJ Formula Junior
    Feb 12, 2012
    387
    Northern NJ
    David
    Lucas injector cleaner and lubricant works very well. I think it is best in breed.
    I have heard that Techron eats rubber, as in fuel lines. That may be old information, the formula may have changed, the newer rubber may have changed too.
    I will say it worked well for one of my cars in the mid-late 90s. But I used it sparingly.
    DavidJ
  5. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
    The lucas injector cleaner and lubricant doesn't do much at least according to extensive readings I've done online. Techron seems to be the preferred choice.
  6. DONRON
    DONRON Karting
    Dec 21, 2012
    74
    Westchester County
    Ron
    The first bottle of techron I purchased was 12 bucks in an auto parts store, now I found a 6 pack at Costco for 19.99. I use it in everything at that price
  7. muk_yan_jong
    muk_yan_jong Formula Junior
    Oct 11, 2008
    568
    Brian McK
    Techron or BG 44K or Seafoam are great for maintenance/occasional cleaning.
    InjectorRx or a similar company to clean and verify pattern.
  8. f355spider
    f355spider F1 World Champ
    18,026
    #8 f355spider, Apr 15, 2015
    They are different concentrations, though the bottle sizes appear similar (nice marketing trick no?). You have to read the bottle and dilution rates to catch it. Basically with the Techron at Costco, you need to use two bottles to match what is commonly sold in the auto parts store. Or use one bottle in half a tank... IIRC the Costco ones are good for 12 gallons, the auto parts store ones are 21 gallons.
    I have no idea if these products work, but have used Techron and lately Lubro Moly fuel injector cleaner. Perhaps once per year in the Ferrari, twice per year in the daily driver BMW. After many years of use, I had the injectors removed, tested and cleaned in both cars, and neither had any serious issues. I think the worst on either car (and only a couple) had high single digit flow variation. But would the results have been the same, had I not used any additive?
  9. EP328
    EP328 Formula Junior
    618
    Northern California
    Ed
    After running a bottle of injector cleaner through a tank of gasoline, change the oil. Techron and the like will get into the oil.
  10. f355spider
    18,026
    ?? Just like gasoline does? ;) If Techron in getting into your oil, you have bigger problems...
  11. EP328
    618
    Northern California
    Ed
    Not the same. Very different bunch of molecules. Engine condition not really that relavent. I discussed this with the folks at Oronite. (chevron subsidiary that manufactures additives)
  12. f355spider
    18,026
    Thank you for sharing. Good to be cautious. What would be the potential negatives?
  13. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    I use Techron a couple times a year. Then send your injectors out for professional cleaning every several years. Not bee a really big deal. I replaced my injectors so I have a back up set. Probably not a bad idea.
  14. jcurry
    23,630
    In the past
    Jim
    Still seems odd. I buy Chevron gas almost exclusively. There is Techron in Chevron gas. Maybe not at the concentrations that adding a bottle of Techron to a tank amounts to, but it is still there. So your statement would imply that using Chevron gas requires more frequent oil changes. But what is bad about Techron in oil? Many parts of the lubrication system can be susceptible to build-ups, and many additives can be applied to both the fuel and oil systems, e.g. Seafoam (mentioned above). Could a few molecules of Techron really warrant an immediate oil change?
    The topic of injector cleaning comes up frequently in general aviation. Probably the best response I've heard in those discussions is that gas is a solvent.
  15. SEAN@TEAM AI
    SEAN@TEAM AI Karting
    Sponsor
    Sep 22, 2006
    201
    Charlotte, NC
    Sean Smith
    +1 Techron and Costco too.
  16. EP328
    618
    Northern California
    Ed
    Like you said, techron is in Chevron gasoline ( as well as Texaco branded gasoline). All fuels are required by the EPA to have a deposit control additive. The amounts in gasoline are much lower (orders of magnitude) than when you add a bottle of techron or other DCA to your tank.
    When I got my 328 I did not know the history of what fuels were run in the car. I talked to my buddies in the fuels engineering group at Chevron and they suggested I run two bottles of techron through the car (two tanks) and then change the oil.
  17. JCR
    JCR F1 World Champ
    10,762
    H-Town, Tejas
    The best fuel system cleaners have Poly Ether Amines. PEAs for short. Chevron calls theirs by the trade name Techron. The Redline brand SI-1 is version is more concentrated.
  18. finnerty
    May 18, 2004
    10,406
    Thanks guys !
    I'll go to the parts store tomorrow and pick up a couple bottles of Techron, and give it a shot.
    I'm not sure about the oil contamination issue (Techron's website does not mention it as any concern) ....... though I can appreciate both sides of the argument. But, since I was going to do an oil change anyway, I'll just wait to do it after the Techron treatment --- so no worries either way.
  19. f355spider
    18,026
    Ed,
    As a previous owner of an 87 328GTS, I can tell you, if you have the original steel injectors in your car, consider replacing/upgrading to the later brass ones. Just get the Bosch part number and order online, they are the same as used in the period 4 cylinder Mercedes of the day. I paid around $20 an injector (12 years ago!), so I am sure they have doubled in cost now. But on a hunch, I had them replaced during some suspension work and the tech tested the original ones, and two were leaking and two others had messed up patterns, they were like a straight pencil stream. After the swap, the car pulled much more smoothly and stronger to redline...very noticeable!
  20. EP328
    618
    Northern California
    Ed
    Injectors were one of the first things I had replaced when I got the car back in '08. They were the original steel ones.
  21. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    injector cleaners are primarily preventative measures and not really equipped to clear a clogged injector... if injectors are suspect of being clogged they are best cleaned / rebuilt by a specialist... as you mention giving the cleaners a try should confirm the final direction to go... good products have already been mentioned... there is one other that has worked for me is a product called Startron... they have a web page... the Startron approach is by using enzymes to clean vs chemical reaction... it also conditions blended fuels preventing their breakdown... it is my primary additive now... it is available everywhere
  22. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    573
    california
    Jack
    I am about to pull my injectors out, I did the cleaning, it helped but they are leaking and running lean at full throttle. I can not find the thread about the company that cleans and tests your old injectors. Any help?
  23. f355spider
    18,026
  24. Rifledriver
    36,745
    Fuel injection Corporation in Livermore. As for Bob and tell him I sent you.
  25. jackgt
    Jan 27, 2015
    573
    california
    Jack
    Is this the one that gives you the before and after readings? I saw it on a post but can not find it again---
