best flat tire pump and sealant to carry in car? | FerrariChat
Discussion in 'Technical Q&A' started by Edward 96GTS, Jan 16, 2022.
  1. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,823
    any suggestions? and how long does it take to inflate a tire?
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,843
    MO
    Omar
    It depends quite widely depending on why the tire lost air in the first place.
    In other words, if the air escapes faster then it can go in, it will never fill.
    If its just a slow leaky seal or valve, typically it will hold air and fill fairly quickly, < 5 minutes unless your air compressor is junk.
    I was given a cheap slime air compressor over a decade ago that I still use for emergencies on my wife's honda. Ferrari offered a (rebranded/debranded) air compressor around the 599/612 era forward.
  3. Kenny94945
    Kenny94945 Karting
    Nov 1, 2003
    221
    Marin Calif
    FWIW
    Not a fan of sealants, but could be useful.
    I am a fan of plug kits.
    Motorcycle shops small plug kits that bundle small enough to fit in a glove box.
    Compressor, many options, just double-check the electrical cord length so you can reach any of the tires if the rim is not removed.
  4. Edward 96GTS
    10,823
    primary purpose is side of the road temp fix to get home.
    f355spider likes this.
  5. tazandjan
    39,007
    Sealant will trash your TPMS sensors, if you have them. Also best to have a compressor that attaches directly to the battery with alligator clamps rather than through the cigarette lighter. That connector often cannot handle the load.
    Texas Forever likes this.
  6. Edward 96GTS
    10,823
    for 1970 daytona
  7. tazandjan
    39,007
    TPMS sensors were not a problem on my Daytona, likely not on yours either. But mine had a spare tire and wheel and a jack kit.
    Rifledriver likes this.
  8. Edward 96GTS
    10,823
    looking for a quick fix. those octagon knockoffs can be stubborn.
  9. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    781
    Treasure Coast Florida
    MATT
    I carry a plug kit with its special tools from Walmart less than 10 bucks and a 20 dollar air pump from Harbour Freight. Carry the same setup in my daily Mercedes.
    Solid State and f355spider like this.
  10. tazandjan
    39,007
    Trick on octagon (or eared) knock-offs is to cast your own hammer using a frozen orange juice container as a mold (with a hole for the hammer handle). Does not last very long, but does not mar anything and gives it a good swack.
  11. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    Harbor Freight carries plastic coated dead-blow hammers of various weights/sizes...perfect and cheap. Jq.
    tonyswfla likes this.
  12. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Crude and ghetto so feel free to flame me but I carry a basic can of Fix-A-Flat in all my cars - had a puncture in my 360 when I owned it and the FAF sealed it and inflated the tire and allowed me to get home and then safely to the dealer for replacement the next day. PITA for the guy who is changing the tire so LET THEM KNOW it is in there but worked for me in a pinch and does not require equipment and rocket science to use.
    Obviously (as stated) it won't work for severe damage or sidewall punctures but will/does work for small punctures in the tread areas. FWIW - Cheers :)
    Texas Forever and tonyswfla like this.
  13. Mimmo Blue
    Mimmo Blue Formula Junior
    Apr 17, 2018
    324
    Stoney Creek, Ontario, Canada
    Dom
    CTEK makes an adapter plug. Female cigarette lighter socket on one end, the other end plugs into the battery charger plug which itself is connected directly to the battery.
  14. tazandjan
    39,007
    Not for a Daytona.
  15. Edward 96GTS
    10,823
    daytonas dont have traditional plug in cigarette lighters.
  16. f355spider
    f355spider F1 World Champ
    18,026
    Consumer Reports tested a bunch of various kits with inflators and sealants a year or so ago.
    This was one of the top rated ones: Amazon.com: AirMan ResQ Pro+ Tire Repair Kit : Automotive
    Shop around you may be able to find a better price. I got one a year ago for less than $70. I put it in the Ferrari in place of the factory one...as that thing is 13 years old, and expired...and even if it worked, no telling what a refill kit costs, or if even available. I would rather call a flat bed than use the kit, but its good to have options...
    Like others mentioned, I have a plug kit in the car too. They are cheap...you can get a really nice one for $20 online, just add a pair of pliers and a screwdriver if you need to remove the offender.
  17. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Oh how I wish I knew that first hand :) :)
    AHudson likes this.
  18. f355spider
    18,026
  19. Solid State
    Solid State F1 World Champ
    10,427
    Maximus Decimus Meridius
    @POLO35 has the right method. Use the sticky brown leather plugs and a fresh can of glue with the brush. Nice metal handle plug kit with sharp rasp and add a set of pliers. Keep air going with wet rasp in hole so when switching to inserting plug there is air pressure to seal it good. Only takes a few minutes.
    Using a sealant through the valve stem will clog it, the TPMS (if one), and make a total mess of the inside tire and rim forcing you to dismount and attempt to clean before repair.
  20. Edward 96GTS
    10,823
    ^ that method may not work with tires that have inner tubes.
  21. Rifledriver
    36,745
    If your Daytona has wire wheels it has tubes. A sealant bottle will not work for tube type tires. Nor will plugs. A puncture is caused by something piercing it. It will continue to pierce it until removed and if it is not a nail with the head on it it will never be found until tire is removed from wheel. I have been on many cross country motorcycle rides and this is all very old news to motorcyclists. I have fixed flat motorcycle tires in the middle of knowhere Alaska. Forget about it. Also do not bother with wrench and hammer.
    3/4 drive sockets are available for the octagons. Short 3/4 drive breaker bar and pipe that will slip over the end as a cheater bar. Leave it in the garage when close to home and when on the road pack it in trunk. I did the same for a client with GTO.
