Best current battery for a 1995 456GT? | FerrariChat
Discussion in '456/550/575' started by uberlink, Feb 10, 2023.
  1. uberlink
    uberlink Formula Junior
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    Anyone got a recommendation for a good battery for a 1995 456GT? Mine has finally given up the ghost.
    I've been searching the forum and mostly finding older posts, which seem out of date when I try to find the batteries recommended there now.
  2. tazandjan
    39,007
    Looking at an old Fiamm chart, the 456 GT uses the same battery as the Maranellos, so an Interstate MTZ-34R *AGM) should work fine. Just ordered one for my 575M. Expensive, but a 4 year replacement warranty.
    Mirek likes this.
  3. Mirek
    Mirek Formula 3
    1,460
    Los Angeles, CA
    Mirek
  4. JohnnyRay
    JohnnyRay F1 Rookie
    3,482
    Central FL/NW WI
    I believe the MTZ-34R can be sourced reasonably at Costco??? Others can confirm...
  5. JohnnyRay
    JohnnyRay F1 Rookie
    3,482
    Central FL/NW WI
    Confirmed MTZ-34R in my x-ref list. Essentially, any 34R battery will do the trick. AGMs are generally the preferred choice these days, however. I went with the NAPA BAT 9834R a couple of years ago - as made by East Penn...
  6. puckybadger
    puckybadger Formula Junior
    319
    Milwaukee, WI USA
    Me too. Looks good (all black), works good. That green and white Interstate doesn't do it for me.
  7. JohnnyRay
    JohnnyRay F1 Rookie
    3,482
    Central FL/NW WI
    Another good AGM source (for your other vehicles) are the AC Delco batteries, as found at Summit Racing and others. Low cost and free shipping to your door. And no core charge! I have successfully installed these in my Cobra and Pantera. Unfortunately, they only make a group 34. No 34R....
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    H6 If i recall correctly. Costco wont sell it to you without year make and model which will not pull up in their computer. You can look on the labels for group number. I always tell them it is for the space shuttle....
  9. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    guys. So no issues with the Interstate MTZ? I need a new battery and was reading the old threads about AGM batteries POTENTIALLY not being good for these cars. That was never actually an issue with the 456/550?
    thanks
  10. tazandjan
    39,007
    I have been using them about 9 years, currently with the MTZ34R. Work great and mine has not been on a charger (except while in for service) in that time. You do need longer J bolts since the battery is a little tall. Mine seem to last about 7 years, and so did my old MTP90 that was not AGM.
  11. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,849
    MO
    Omar
    #11 Auraraptor, Nov 21, 2023
    I use a MTX48-H6 in my 575 and a MTZ-34R in my 456. Both are AGM. I also favor / support AGM use. Note in my 575 I also upgraded the OEM battery heat shield to the next generation PN 250100 version (needed minor trimming but it’s much more robust than the original heat shield. Recall the 575 moved away from a solid metal shield for the battery ala 550/456. That first generation flexible shield material was complete garbage hence why it’s mostly in tatters (if present at all). Eventually, I plan to do similar for the 456M (while trying to also keep the original metal heat shield used in that car; my 456m needs all the heat management it can get).
    This is the battery technical info I have:
    MTP-91
    Amps: 875
    Cranking Amps: 875
    Cold Cranking Amps: 700
    Voltage: 12
    Termination: A
    Pro-rata Warranty: 85
    Weight: 36.9
    Width: 6.88
    Length: 11.38
    Height: 6.88
    MTP-H6
    Amps: 800
    Cranking Amps: 800
    Cold Cranking Amps: 640
    Voltage: 12
    Termination: A
    Weight: 40.8
    Width: 6.89
    Length: 10.94
    Height: 7.48
    MT7-34R
    Cranking Amps: 1000
    Cold Cranking Amps: 800
    115 minutes RC
    Width: 6.75
    Length: 10.82
    Height: 7.75
    MTX48-H6 (AGM)
    Cranking Amps: 950
    Cold Cranking Amps: 760
    120 minutes RC
    Width: 6.94
    Length: 11.0
    Height: 7.50​
  12. Aerosurfer
    Aerosurfer Formula 3
    1,788
    Indianapolis
    Nick
    Say what you want about Autozone, this battery was in the car when i acquired it about 2 years ago, and have had zero problems, great fitment too
    Mirek likes this.
  13. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    Thank you.
    Happy turkey day!
    Cheers!
  14. tazandjan
    39,007
    Odds are your Duralast was made by Clarios Johnson Controls. They make a huge portion of the lead-acid and AGM batteries sold by companies like Autozone. Their top end batteries are as good as any, regardless of the sticker on them.
  15. Aerosurfer
    1,788
    Indianapolis
    Nick
    Very neat info, had no idea about any of that. Thanks!
  16. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    Hey I’m all about taking recommendation and I have an AutoZone right near me. But when I look up this battery on their website, it says ‘does not fit your vehicle’. And then, when you type in your vehicle, it gives a different Duralast battery. 27F-EFB. Obviously, if that battery is already in your car, then it does fit. Does it look like it was modified to squeeze in? Does anyone have any opinions about this different Duralast battery? 27F-EFB
    https://www.autozone.com/batteries-starting-and-charging/battery
    Taz- I hear what you said about Duralast batteries and I’m totally inclined to just get the one that came up on the website.
    Any opinion is much appreciated. Thanks in advance
  17. Aerosurfer
    1,788
    Indianapolis
    Nick
    Definitely wasnt modified in any way. I had it out once to repair my monovalve (heater valve). Other than needing to move the coolant tank it came out without any issues. Per my cooling harness design, there is room to route the upper harness over the top and behind the battery.
    As far as i can tell its a great fit. Next time the car is down, ill get some pictures for the thread
  18. tazandjan
    39,007
    Jaredsalinsky and Auraraptor like this.
  19. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    man crazy times here... NO ONE has the interstate batteries (although I can get on amazon oddly enough...)
    I bailed on the Duralast 27F-EFB - absolutely would not fit in the car; I measured yesterday and there is no way I could've squeezed it in.
    I still may do the Duralast 36.
    Between the Interstate MTZ-34R ($400) and MTX 48H6 ($250) there is a pretty big diff in the $$. Anyone have any input on the H6?
    thanks
  20. Auraraptor
    Sep 25, 2002
    13,849
    MO
    Omar
    See above. I use a MTX48-H6 in my 575
  21. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    LOL I'm an idiot! too much turkey!
    ty
  22. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    Sorry to keep beating a dead horse, but does anyone have an opinion on the diehard H6 AGM? Having trouble finding the interstate MTZ 34R. And advanced auto parts is right down the street with the diehard H 6.
  23. Auraraptor
    Sep 25, 2002
    13,849
    MO
    Omar
    It’s worked great in my 575. Holds charge and starts up every time.
    Not sure what info you’re looking for exactly information wise. Realize most ‘brand’ batteries in the US are made by the same company
  24. Aerosurfer
    1,788
    Indianapolis
    Nick
    You got plenty of info, isn't it now more a decision of...
    It's Ed, scowman and Auraraptor like this.
  25. Jaredsalinsky
    Feb 8, 2023
    653
    tampa FL
    Jared salinsky
    You know what man you’re totally right. It’s just this is my first Ferrari and I’m really trying to be as fastidiously perfect as possible. At the end of the day you could drive yourself crazy with the back-and-forth second-guessing! For goodness sakes, it’s a battery! That being said I’m not sure I would put a lithium in an old Ferrari. But the diehard H6 AGM fits size wise and spec wise so I think I’m just gonna pull the trigger and do it.
    And thank you as always
