Best C-Tek Battery Charger for 575M | FerrariChat
Discussion in '456/550/575' started by ko23, Aug 21, 2016.
  1. ko23
    ko23 Karting
    May 6, 2015
    207
    For the life of me, I can't figure out the C-Tek website for what's the best charger for the 575M or the 550. There are so many variations and so many options. Can anyone shed some expertise into this please? What do you use for trickle charging?
  2. ko23
    ko23 Karting
    May 6, 2015
    207
    I have seen this one used at a storage place. Have you had good experience with this? It seems inexpensive but then again, I am sure the mark up is crazy since Ferrari Dealers marks up the C-Tek by 8 times.
  3. 308 GTB
    308 GTB F1 World Champ
    11,642
    New Jersey
    Barry Wolinsky
    #4 308 GTB, Aug 21, 2016
    You've got several choices other than the C-Tec. Dave mentioned one. Another is the Schumacher SE-1-12S. It's been serving dependably in my 550 for fifteen years.
  4. JSP
    JSP Karting
    Oct 5, 2013
    159
    Texas
    Steve
    I have a $20 WalMart tender on my 575. No problems.
  5. Jon Von Bon
    Jon Von Bon Formula 3
    1,697
    Toronto / Florida
    Jeff
    The Schumacher is the best charger period. I have 2 of them. Super reliable. I have lots of toys so I'm always charging something and these do the job.
    good call Barry.
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    I've been using Deltran (Battery Tender) products since the early 90's on several race cars that ran total loss systems (no alternator) and my other cars in storage with never a problem.
    I bought this one a few months ago because I had just installed an AGM battery and this tender works on both AGM and flooded.
  7. 308 GTB
    11,642
    New Jersey
    Barry Wolinsky
    Hi Dave,
    I have a cover over the positive terminal. I had to trim the cover that came with the Braille to get it to fit over the cables. It's always best to shield the positive terminal as you did. That's an old picture I posted.
    Barry
  8. 308 GTB
    11,642
    New Jersey
    Barry Wolinsky
    I have the same tender mounted in my F355 Challenge, Jon. Three years of reliable service with that one.
    Barry
  9. pkl03
    pkl03 Formula Junior
    521
    Sydney, Australia
    Peter
    I use CTEK MXS 5.0. Have used it for about 4 years with no issues and leave it connected for weeks at a time.
    MXS 5.0
    It appears the U.S. version is MUS 4.3
    CTEK Multi US 4.3 - CTEK Battery ChargersCTEK Battery Chargers
  10. JohnnyRay
    JohnnyRay F1 Rookie
    3,482
    Central FL/NW WI
    I use the C-TEK 800 (0.8A) on most everything. A few are branded as Aston Martin. Have 16 of them in service on everything from lawn tractors to the 550. They work well and I have had zero failures. Often available at low cost on eBay.
    I also have a couple of the larger C-TEKs. They also work fine, but no need for the additional capacity. Keep in mind that these are tenders - not chargers. If you have a drained battery, a conventional charger is the the correct device to restore the bulk of the charge.
    One key difference with a C-TEK is the de-sulphating mode that pulses the charge voltage occasionally. This helps batteries deliver the longest possible service. Look for that feature if you are considering others. I also have a perfectly good Harley-Davidson branded tender for example. It offers all the other benefits - but no pulse mode. I just replaced a battery this year...
  11. tazandjan
    39,006
    Broadway provided a factory red with Ferrari markings CTEK 800 with all their used Ferraris back in 2008. Mine is in one of the ZIVAN Schedoni cases, but I have not used it for about 6 years. If you drive them, they do not need one.
  12. ko23
    ko23 Karting
    May 6, 2015
    207
    You are right... gotta drive more. Great posts everyone. Thank you. You guys are a great source of information and expertise.
  13. tonyswfla
    tonyswfla Formula Junior
    823
    Florida
    Take a look at the NOCO G7200; on Amazon
