Any recomendations for bent wheel repair? I don't mind removing the wheel and tire. Hit a big pot hole on the 710 N to 405 N onramp. Image Unavailable, Please Login
Ouch, rough on the outside. Usually those happen on the inside. www.supremepower.com - Talk to Eric. Has fixed several of mine.
The wheel might be able to be straightened but they would not allow it in aviation unless you anneal it, then straighten it, then heat treat it then run a check for cracks using zyglow or magnet penetrant inspection. You will then need a full repaint which will never match. Replacement wheel is probably $4k, suggest you call you insurance company and make a claim. (you might also file a claim with the owner of the road, don't laugh, I know they do it some times.)
I've had very good results with Al Reed in Anaheim. Does full concours wheel restorations and repairs. Al Reed at 3010 E. Coronado #A, Anaheim (714) 632-3907
+1 on Al Reed, he's done 2 sets of P****** rims for me, including straightening on a few of them. Go around back and check out the guys polishing Fuchs wheels, what a mess!
