Bench vise handle removal? | FerrariChat
Discussion in 'Technical Q&A' started by yelcab, Dec 2, 2023.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,391
    San Carlos, CA
    Mitchell Le
  2. wmuno
    wmuno Formula Junior
    513
    Wilmette, Illinois
    Bill Muno
    This looks like a Craftsman vice with the red paint and the arrow marking. If it is, then the handle is not removable.
    This line across the handle looks like someone might have cut it which would be quite odd. If that is the case, put vice grips above and below the cut line and turn counter clockwise to see if the 2 sections separate.
  3. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    340
    Scottsdale, AZ
    Jim
    I have one that looks just like that, and the ball on the end unscrews.
  4. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    Search Craftsman vice restoration on YouTube or Google and you can find people who have restored that particular vice (or very similar models). In some photos I saw on line, it appears the ends are forged / swaged on that cross bar. If you wanna check to see if there might be threads, try putting some WD40 on the ball area where it appears to be threaded maybe. Wipe everything away, then hit the ball with some heat from a torch. If there are hidden threads, usually you can see the WD40 that made its way down into the threads boiling back up.
    With enough heat and torque, most any threaded part will come off.
    Ray
  5. yelcab
    Nov 29, 2001
    13,391
    San Carlos, CA
    Mitchell Le
    That end is not coming off. So, it has been donated to neighbor to be replaced with a higher quality bigger bench for me.
  6. hessank
    hessank Formula 3
    1,869
    Canada, Florida
    Fred
  7. yelcab
    Nov 29, 2001
    13,391
    San Carlos, CA
    Mitchell Le
    Believe it or not, I have everything on that picture including the OxAc torch. I did not want to go through all that for a cheap bench vise anyway.
