"Bello Nero" Dino 246GTS*08054* 1/63 20-B-50 | FerrariChat
Discussion in '206/246' started by surface master, Dec 31, 2012.
  1. surface master
    surface master Formula Junior
    271
    Southern California
    Steve N. Kouracos
    #1 surface master, Dec 31, 2012
    It's the start of a New Year with lots of work scheduled. I picked up my newest Dino surface and paint job from Jon G's shop last week. Jon is so meticulous by the way he pulls these Dinos apart. Everything is in separate plastic crates, labeled and in zip-lock bags. Don't forget about the subcontractors and all the missing parts that he locates, not to mention all the new fasteners he purchases. We laugh together when these cars come apart... he finds that most of these Dinos from previous repairs were put back together from stuff that was bought from the local hardware store down the plumbing department aisle. Jon is a magician when he puts these cars back together.
    The owner (Mel Bahri) lives locally and I am sure he will be around frequently to check on progress. He has owned this Dino for more than 4 years and has only driven it a couple of times. Why?... well, we won't go there. He is a great guy and loves his Dino very much. And also loves Black. All his cars are black.
    Last week we started stripping his car to metal. Oh Boy! I have seen a lot worse I tell Mel. Mel's Dino has very little rust repairs needed but some old sheet metal damage from a few fender benders. Repairing old damage can be challenging... when there's lots of brass repairs (no good) all the brass and most of the old sheet metal has to come out. There will be some fabricating involved.
    I will post the repairs as we get into them. Here are a few photos.
    Happy New Year to all of you!
    Steve
    http://stevekouracos.wordpress.com/
  2. Night Ranger
    Night Ranger Rookie
    Jan 2, 2013
    11
    that helps alot. without labeling I'd end up with alot extra bolts and washers after completion. good luck with the project
  3. surface master
    271
    Southern California
    Steve N. Kouracos
    #3 surface master, Jan 2, 2013
  4. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Thanks Steve you found my crescent wrench!
  5. ferraripete
    ferraripete F1 World Champ
    if it is a craftsman...i suspect they will replace it:)
  6. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Are you kidding!! Harbor freight.
  7. HMB-Dino
    HMB-Dino Formula 3
    2,173
    Pebble Beach, CA
    RonG
    That's probably where the rust started (the cheapo wrench) and spread from there!
  8. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,830
    Western NY
    Fred
    It's amazing how much rust a Dino body can hide! It's great that Steve will be bringing this spider back from the brink. He and Jon are definitely the Dino Dynamic Duo! Fred
  9. surface master
    271
    Southern California
    Steve N. Kouracos
    #9 surface master, Jan 3, 2013
    After we found Jon's Crescent we found his Allen wrench. HaHa. Now back to business. Let's get this thing stripped and start replacing all the bad sheet metal so this black beauty can get on the road!
    Steve
  10. surface master
    271
    Southern California
    Steve N. Kouracos
    #10 surface master, Jan 3, 2013
    We hope to have the stripping completely done by the end of this week. We'll then figure out what metal work and fabrication we'll have to do. Where we are right now, it's looking really good.
    With most of these older restorations they have been stripped before. They've been stripped by somebody using 36 grit on the end of grinding wheel.... when I get a car I don't know how much metal there is left, especially on the edges. This is a really big problem with the 206s and aluminum cars. We know that the safest way to eliminate material is by hand. It's very tedious work and a very slow process. There are only a few projects and depending on the client's budget the cars get media blasted. This is only when a car gets completely taken apart and stuck on a rotisserie. I also use a method when it's thick with filler, I heat up the area with a torch the filler peels off like butter.
    The following photos will give you an idea of the work required in hand stripping.
    Steve
  11. surface master
    271
    Southern California
    Steve N. Kouracos
    The owner came to the shop and viewed the progress on his "Black Beauty" Dino this last weekend. He's happy to see as much work as we've done on the car and has given us the go-ahead to move forward with some necessary repairs as we move toward body work.
    We'll post some photos over the next couple weeks.
    Steve
  12. surface master
    271
    Southern California
    Steve N. Kouracos
    #12 surface master, Mar 4, 2013
    This will be the last bath this Dino will ever see. Now that the surface material has all been stripped off we de-greased and pressure steam washed the entire car -- inside and out. Everything that needed to be masked off, such as wires and fuse block, were masked off and wrapped in plastic tighter than a drum. After the bath, while the metal was still wet, we sprayed an etching material on the sheet metal to prep the steel for body/sheet metal work. The material was worked in by hand with Scotch Brite pads and rinsed off one more time after the etching process was completed. The car then moved into the spray booth oven and baked until all the moisture is out of the car and has completely dried out.
    Steve
    Steve Kouracos | Fine Craftsmanship In Automotive Restoration & Resurfacing
  13. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Steam and high heat, I would not want those two on any Dino. Scary, as condensation has mysterious ways of creeping.
    Specially with the wiring loom around, unless it's getting tossed...
    Personally, dry sand, sandblasting, soda blasting.
    Regards, Alberto
  14. surface master
    271
    Southern California
    Steve N. Kouracos
    Not so scary if done properly and with the right equipment for this process. This is not a rotisserie job where you can media blast. I have soda blasted before and will never, ever do that again. They both have their drawbacks. The de-greasing and steam cleaning is to remove all the grime, oil, and grease and to make sure the chassis is 100% clean. As I mentioned, after the body gets metal etched, we return the chassis and body to the heated, down draft spray booth where the air is constantly moving and stays at a constant temperature until the car is completely dry.
  15. surface master
    271
    Southern California
    Steve N. Kouracos
    #15 surface master, Mar 4, 2013
    Just got the parts back from the walnut blaster. We seam sealed and will get in to primer quickly so they can go back on the car and we can start our surfacing and fit and finish. As you can tell by the photographs the factory numbers are etched into the aluminum. It's too bad, they'll soon be covered with primer.
    Steve
  16. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    #16 omgjon, Apr 9, 2013
  17. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    where does that piece go?
  18. 412monzaindy
    412monzaindy Formula Junior
    Mar 8, 2005
    876
    Ontario Canada
    PBI
    It's BELLA not Bello
  19. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Between the engine and the passenger compartment.
  20. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Had to be of course, must be thevphonangle made it look to wide!!!
    Anyway, covering one side or both?
  21. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Only one side is covered, the side that faces the passenger compartment.
  22. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    ok got it.thanks
  23. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Jon, great stuff! Is the label correct on the dimensions, 600"?
    Regards, Alberto
  24. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    e' una bella macchina, ma e' un Dino
    so, she is beautiful car, but its a Dino
    which is masculine. :)
  25. swift53
    swift53 F1 Veteran
    6,735
    E.S.
    Alberto
    Perfect Luigi!
    'Bello Nero', means something completely different, as in a very suntanned man, a compliment for someone on an Italian beach.
    Regards, Alberto
