Beeman Kodiak .25 air rifle | FerrariChat
Discussion in 'Other Off Topic Forum' started by thecarreaper, Mar 10, 2006.
  1. thecarreaper
    thecarreaper F1 World Champ
    17,957
    Savannah
    #1 thecarreaper, Mar 10, 2006
    i have several fine RWS air rifles in both .177 and .22 . i was wondering if anyone on here has any thoughts or stories to share on the Beeman Kodiak in .25 . this airgun is the nicknamed "elephant gun" of air rifles due to its power and cocking effort. i am seriously considering getting one, but $600.00 + for an air rifle is a bit disconcerting.
    ( i found a pic on the net while doing .25 cal ballistics research. )
    any help / experiences would be great :)
  2. PeterS
    PeterS Five Time F1 World Champ
    51,240
    Goodyear, AZ
    PeterS
    I've had beeman .177 for years. Great for small game. I'd like to know if the velocity would be reduced with a larger round. I shoot with the triple ring pellets and they fly pretty straight.
  3. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    The velocity will most definitely go down if you move up to a larger round (i.e. the .25 mentioned here). The benefit of the larger round is the increase in energy and knock-down power, albeit at a lower velocity. Larger rounds will typically retain energy better than smaller ones.
    That being said, I don't have any experience with anything other than .177 caliber air rifles. I'd say that a lot depends on the application you're going to use the gun for. If you're just punching paper or targets, the only advantage that I could see would be a slightly better ability to buck the wind. If you're hunting with it, then the real assets of a larger round would come more into play.
  4. thecarreaper
    17,957
    Savannah
    i am looking at a place with 13 + acres horse stables, ect, and even if this property falls through, the others are about the same size. though i can shoot real firearms on property this size, pellet guns and my ATF legal / registered silenced .22's are a bit more polite to shoot daily and safer. i guess i just *want* the .25, because they are top of the heap.
    for pest control a subsonic Agulia .22 round is cheap and hard to beat when fired from a normal .22 cal firearm. but, quality adult airguns have a mysterious draw for me, and i have had them for years.
    off to work, but i can post some great .25 ballistic info later if anyone cares. i was hoping there was an fchat freind on here that had a .25 Kodiak or knew of first hand experience. in some areas where a real firearm is prohibited, a powerful airgun is the only leagl way to go. even the powder free .22 rounds fired from a real firearm could get one in trouble if fired inside city limits. airguns are not usually regulated and have a safer shoot range to lessen overpenitration of backstops. however my RWS M48 with pointed pellets will blow through up 3/4 inch plywood at 40 yards and less. 50 yards is about max effective range and this is why the .25 has suck a draw. the .25 hit like a big slow .45 slug where as the smaller rounds loose energy but retain velocity. a fast moving .177 has a tendancy yo overpenetrate and do little damage at closer ranges for hunting small game and pests.
    a .22 and .25 hit like a sledge hammer due to sheer mass.
    must go to work .....
