Becker radio blocked because impossible to enter the code | FerrariChat
Discussion in '360/430' started by ArmenVanquishS, May 18, 2023.
  1. ArmenVanquishS
    ArmenVanquishS Formula Junior
    Sep 20, 2014
    323
    Paris, France
    Hello everyone,
    The original BECKER autoradio of this MY2005 F430 is blocked.
    Let me explain, as you can see, the display shows numbers from 1 to 7 only.
    It used to show the 8, 9 and 0 at the right of the display.
    Now, there is an arrow and pressing the button of the arrow will not change anything.
    Has anyone encountered this problem ? I can not enter my code so the radio is blocked.
    Turning off/on the battery won't change anything and by the way even with a new battery, it's still the same.
    Thanks for your help !
    Kind regards from Paris.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,931
    East Bay, California
    Joe
    If it's anything like the other Becker units, you need to leave it on for 24 hours before it will reset itself. Not sure what the implications on for the car to stay on the whole time. Your best bet would be to take it out and hook it up to a 12v lead for the 24 hours. Some people say it only takes two hours. Only one way to find out I guess
  3. ArmenVanquishS
    Sep 20, 2014
    323
    Paris, France
    Thanks for your reply !
    The battery has just been replaced so I will avoid letting the car turned on for several hours ;)
    As I tried pressing other buttons on the radio, the radio put itself into safety mode and I had to wait around 2500 seconds, which I did but unfortunately the display remains the same.
    In French it is written "Entrer le co***" but as you can see the message is not clearly readable because of the ****
    Then I'll try to take it out and hook it up to a battery and see what happens.
    I'd be curious to know if anybody has ever got this kind of display with numbers from 1 to 7 only instead of the whole line from 1 to 0 at the right.
  4. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,843
    MO
    Omar
    Yes; You locked it; you need to wait for it to reset. Depending on the model that is either an overnight, disconnect/reconnect, or a 1hr wait while on. I forget which version the 4xxx series had as its been a while.
  5. ArmenVanquishS
    Sep 20, 2014
    323
    Paris, France
    Thanks, I'll try that.
    Simple question, seeing that currently numbers go from 1 to 7, does that mean that in this situation when it is locked, there is an additional code to unlock the radio apart from the original code of 5 digits that I usually enter after reconnecting the battery (with numbers 1 2 3 4 5 6 7 8 9 0) ?
    This is what I don't understand, can't I find the code to unlock it ?
    I only have the original autoradio code to unlock it when I turn the battery on.
    Thanks guys !
  6. Auraraptor
    Sep 25, 2002
    13,843
    MO
    Omar
    Good question. That I am not sure of….Bekker Audiosound in NJ would know as they service these
  7. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,780
    San Jose, California
    Do you have the original books that came with the car? There should be something in there that looks like a thin credit card that has your code on it.
  8. ArmenVanquishS
    Sep 20, 2014
    323
    Paris, France
    Hi,
    Yes I have all the books and the original code card but there is a 0 inside.
    I know it by heart and was dialing it every time after turning the battery on, but on my current display, numbers go from 1 to 7 only.
  9. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    898
    S La
    After finishing the 2002 major service and resetting the radio code, or trying to, the message "wait" appeared and stayed that way for several days as I recall. It then started working normally. I did the drive relearn procedure but doubt that the radio had anything to do with that.
  10. ArmenVanquishS
    Sep 20, 2014
    323
    Paris, France
    OK thanks for the info.
  11. The Pilot
    The Pilot Rookie
    Jun 7, 2024
    1
    Latvia
    Martin Friberg
    Hi,
    I have same issue with only able to select numbers 1-7 but my code should be 9015.
    I bought my F430 a couple of months ago and didn’t bother fixing the issue with the radio code since the engine sound is just amazing .
    Anyone know how to solve this issue.
  12. Mario Andretti
    Mario Andretti Formula 3
    1,739
    Boston
    If I was in that situation, I would definitely throw away that POS Becker unit and install something else.
    BrettC likes this.
  13. mkt
    mkt Karting
    Sep 22, 2010
    52
    Wassenaar, Holland
    Maurice
    Your code cannot be 9015.
    The Becker Ferrari Cascade has a 5 digit code.
    Mario Andretti likes this.
  14. wtam608
    wtam608 Rookie
    Sep 24, 2015
    46
    The Pilot likes this.
  15. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Enter a lot of bad codes until it locks you out and then wait 2 days and see if resets with 0-9
