For Sale - BC Forged monoblock wheels+tires for F430 / 360 | FerrariChat
For Sale BC Forged monoblock wheels+tires for F430 / 360
Discussion in 'Ferrari Parts & Collectibles' started by zboost300, Feb 15, 2022.
  1. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Selling this set of wheels with tires. About 2k miles on everything. I purchased everything new. These are 5x108 bolt pattern for F430 and 360, 19" front and 20" rear. Much lighter than the factory cast wheels. I would keep these, but I plan on getting a 599 and these have a different bolt pattern.
    F430 fitment, excellent fit no rubbing. Will fit 360 the same as well.
    They will most likely fit many other models as well, do your own research.
    Specifications:
    Wheels
    Front 19x8.5
    Rear 20x11
    Tires
    Front Bridgestone S007A 245/35/19
    Rear Bridgestone S007A 305/30/20
    They have the same ratios and diameters as stock so they will not interfere with E-Diff or throw off the speedometer.
    Price is $4500
    Located in Cedar Park, TX. I can ship as well.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,849
    MO
    Omar
    Should also fit the 456/550/575 family too. GLWS
  3. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Thank you!
  4. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    400
    Lance Malcolm
    Would these need spacers on front or rear for a 456 installation?
    Do you know the backspacing/offset on the fronts and rears?
  5. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Apologies I thought I had posted the offsets, they are as follow.
    Front
    19x8.5 +20 offset
    Rear
    20x11 +28 offset
    These were made to clear the carbon brakes so I doubt you would have any issues with the brakes considering how massive the 430/scud carbon brakes are.
  6. Auraraptor
    Sep 25, 2002
    13,849
    MO
    Omar
    No spacers based on that offset. Fronts would set nearly identical to nf2 fronts with 9in fronts.
    rears fit as is but may look better with 11mm spacer
  7. MaurizioAM
    MaurizioAM Karting
    Sep 5, 2018
    104
    Plano Texas
    Maurizio
    How would these look on a 456m, anyone care to photo shop? Also the rears are 1.2" overall diameter larger then OEM, would that cause any issues? Speedo would be off surely but anything else be of major issue?
  8. Auraraptor
    Sep 25, 2002
    13,849
    MO
    Omar
  9. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Unfortunately I don't have any Photoshop skills otherwise I will definitely help you out!
    Thanks @Auraraptor for the info! I suppose you could run a small spacer on the rears to make it more aggressive as several people do on other models.
    It seems the speedo would read 2.8mph slower @60mph. Which with our Ferrari speedos would probably make it a accurate for a change!
    MaurizioAM likes this.
  10. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Price lowered to $4000 for a quick sale.
  11. Davidspop
    Dec 23, 2019
    400
    Lance Malcolm
    Are these a "bronze" color? Or are they natural finish?
  12. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    The color is "royal gold". Sort of a translucent gold finish.
  13. Davidspop
    Dec 23, 2019
    400
    Lance Malcolm
    I really like these.... can a Ferrari center cap be installed?
  14. Bob H.
    Bob H. Rookie
    Dec 30, 2018
    41
    Denver, CO
    Bob
    Trade for a set of Novitec NF1's?
  15. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Yes, all you need is the set of adapter rings which are easily sourced from BC forged for around $100. Whith those the factory center caps will snap on like stock.
  16. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    I sold my F430 and do not need another set of wheels at this time, so cash only.
  17. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Still available
  18. wklinez327
    wklinez327 Rookie
    May 26, 2021
    20
    Warren Kline
    Do you have pictures of the wheels when they were on your F430.
  19. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Yes, all the pictures are in this post. Just scroll up in the first post they are there.
    If you want any more specific pictures just let me know and I will post them up.
  20. zboost300
    zboost300 Karting
    Jan 27, 2019
    139
    Wheels are sold.
