BB512 window fail | FerrariChat
BB512 window fail
Discussion in 'Boxers/TR/M' started by jww427, Nov 1, 2017.
  1. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Hello all!
    My passenger window won't go all the way up. It stops at 3/4.
    Any advice would be helpful.
    thanks!
    1981 BB
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,617
    romano schwabel
    may be the wire transporting the window down and up got loose at the glass and during moving down it was moving also to the glass so it can not go more up again?
  3. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,540
    Tuscaloosa, AL
    Drew Altemara
    It might also be the window guides have "gummed up", are causing too much resistance as they roll up, and need to be replaced. See if you can help it to close. If so you might look at replacing the window guides fur strips. When you try to lube them the just get tackier. Its a messy job but not that hard. Good luck. Drew
  4. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Yes, the window lifts are about as well designed and effective as the AC
