battery tender was plugged in... now battery is stone cold dead! Did I kill the car? | FerrariChat
Discussion in 'Technical Q&A' started by 348SStb, Jun 27, 2007.
  1. 348SStb
    348SStb F1 Rookie
    Ok, I keep my 348 plugged in with the Battery Tender whenever I don't use the car. I've been doing this for 3 years, and that's why I've never had a low battry or any battery issues.
    Well, Murphy has been contributing more and more to my life lately.
    On Monday, I plugged the Battery Tender in as usual. Today, I checked the car, and the Battery Tender was about 1,000 degrees to the touch, and no charge light was on. I turned the ignition key to see if the car had any power and it had nothing.
    I unplugged the Battery Tender from both the car and the wall. I re-plugged it into the wall only just to see if it would take power, and it did: the red light blinked.
    The car had not even one ounce of power. So I plugged in a conventional battery charger (6 amp) using the positive terminal located in the engine compartment and using a ground for my negative.
    The car would not accept any charge. It was properly connected. Despite my suspicion that trying to charge it would be useless, I left it connected.
    Six hours later, the car had no juice whatsoever.
    I'm freaking out!
    Did I destroy my electrical system somehow? Or do I just need a new battery? The battery is 3 years old and has never been dead or low.
  2. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Sounds like you need a new battery, but I'd call Deltran and explain the situation.
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I'd guess it's time for a new battery... but check your main fuses also.
  4. f355spider
    f355spider F1 World Champ
    18,026
    How is the battery tender connected to the car? I wouldn't bother checking fuses unless it is connected through the fuse panel, via a cigarette lighter or something.
    If it is connected directly to the battery via the pig tail or clamps, I would immediately suspect a shorted battery.
    Replace the battery, then drive the car to an auto parts house that will perform a free electrical test to confirm your alternator was not contributing to the battery failure.
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    There is no normal reason for any charger to get hot. Warm yes but never hot. And 3 years is about normal battery life.
    Change battery AND charger and make certain charger is fused per manufacturer's numbers.
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I have been laughed at by people here for warning against using those things, with most everyone arguing they never fail. Well, they do fail, and when they fail it can be catastrophic. Your lucky you found it before it set your car on fire and burned your garage down, because that's where it was headed. Seriously, I couldnt sleep at night with one of those things hooked to anything I own. Ive seen the results firsthand. My family, our lives, and our home is worth a lot more than a dead car battery.
  7. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I guess I missed the reason for one of these. I replaced my battery in 1999 when I got the car and it usually sits all winter unless it is a nice day and I drive it. I don't use a charger nor do I use any fuel stablizer. It has never let me down and now that I use it every day there still is no problem. Battery still takes a charge and runs at 13-14 volts. I realize I am now on borrowed time but that is only due to age. So I would think the only reason for a tender is because you have a leakage (short) in the car and it is taking out your battery. I would fix he source 1st and then you won't need the tender. My 2C. Enjoy the ride
  8. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    A failure mode of the Deltran battery tender (aka "Super Smart") in some instances is to overheat (not to 1000 degrees as was posted, but uncomfortable to the touch). The unit stops charging the battery at this point, but continues to draw enough current from the wall to keep the unit VERY warm. This won't result in anything "catastrophic", & shouldn't even be hot enough for the unit to melt vinyl if it is sitting on such a surface.
    Can you provide further details on the results of Deltran battery tenders causing fires or other damage that you have seen firsthand?
  9. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    :O :O :O
    Wow! So your car can sit all winter and not go dead? What kind of battery do you have, and does your analog clock still work? Do you have a radio with a clock or CD player or an old AM/FM two poster? Having both of those in mine (the former more than the latter) I've always thought to be sufficient to explain why it runs down eventually. I park my car in about November and get it back out in April or May.
    P.S.- as for concern about this particular device malfunctioning and burning your house down... I also worry about my refrigerator, that flourescent light I leave on 24/7, my computer, my stereo and my air conditioner/furnace! But I don't unplug them when I leave home...
  10. 348SStb
    348SStb F1 Rookie
    I think you make good points. However, I don't see why there shouldn't exist a Battery Tender that is smart enough to know when it is malfunctioning and that can turn itself off when it does malfunction.
    Does such a device not exist? Obsviously my Tender was too stupid to know that it was overheating.
    PS I will attempt to take the batter out of the car today.
  11. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    In almost 49 years, I cant recall another everyday electrical appliance more prone to burning itself up than a battery charger. Out of over a dozen chargers over the years, I had one catch fire, another two that smoked profusely and got VERY hot, and one that turned the 12 volt leads red hot and burned the insulation off. And a few other people I know over the years had had them go up in smoke as well. In comparison, I have never seen a home appliance burn up. Quit yes, burn no.
    The failure mode of a Ferrari wont result in burning it to the ground either, but they have and they do. Why would you want to put a fire prone appliance into a fire prone car? Regardless of what the failure mode "should be", many times Murphy has other ideas.
  12. 348SStb
    348SStb F1 Rookie
    Ok, I pulled the battery out of the car.
    Now that the battery is out, I hooked up the charger to it. Whether it is actually taking a charge I don't know; but the amperage does shoot up to the max (0%). Remember that when the battery was in the car, the meter showed nothing. I'll give it a few hours to see if the battery takes the charge.
    In the meantime, I guess I will hold off on going to Pep Boys to pick up a new battery?
  13. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    Not a battery tender, but a "smart" charger when left io overnight caused a fire in the best paint shop in our area that destroyed a city block.
    Since that happened, I charge my battery when it needs it, when I am there, and check on it frequently. Not as convenient, but having your house burn is also not convenient
  14. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Take your old one with you... they'll test it for you.
  15. David_S
    11,260
    Mountains of WNC...
    David S.
    So you are saying you have never seen this occur with a Deltran product (known as a battery tender - NOT a battery charger)?
    I have personal experience with a Snap-On charger with a "smart" mode causing a battery to explode after approx 4 hours on charge.
  16. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Sounds like a plan to me. Then I'd go to Sears. If you're not on the Optima bandwagon (I'm not), my recollection of a Consumer Reports battery test a couple of years ago was that DieHards scored in the top 1 or 2 in all of the sizes they tested. They also have a machine there that they use to qualify your battery for warranty replacement; they can hook it up and while you shop they can confirm 100% for you that it's beyond salvation.
  17. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    In my experiance, once a battery is completly discharged as your battery is, it's not worth the hassel to deal with. They NEVER are the same after. And you can bet, when it fails, it will be at midnight, cold as hell and raining....with your girlfriend or wife in the passanger seat....
    Darrell.
  18. 348SStb
    348SStb F1 Rookie
    Ok guys, thanks for all your input.
    They tested the battery at Pep Boys and determined that it was in 100% fine shape. They jolted it and it took a 1-hour charge to completion.
    I went home and popped the battery in place and voila! The car started.
    As for the mystery of what happened, I'll worry about that once I rinse all the sweat and grease off me! It's amazing how dirty I am after popping a wheel off and changing a battery.
    Regards,
    David
  19. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Probably a bad battery cable. Jiggle them at the connections with a meter and see if it fails. Mine did that; looking at it you'd have no idea it was bad!
    Ken
  20. t024484
    t024484 Karting
    Nov 9, 2006
    171
    Netherlands
    Hans A. Polak
    For the almost neglectable amount a new battery cost, I fully support DMOORE.
    A battery that was fully discharged is damaged and will never recover to its old state.
    Hearing as to what happened: "battery empty but not short circuited", "charger superhot but still working afterwards", my guess is that you connected your charger the wrong way, plus and minus interchanged.
    So instead of charging your battery, you completely discharged your battery with the 6A or so that your charger can supply. A continous current of 6 Amp into zero volt is more than enough to make your charger as hot as hell.
    Seems to me the only logical explaination.
  21. DGS
    DGS Six Time F1 World Champ
    69,596
    MidTN
    DGS
    This sounds like you might have a couple of things. If you normally connect with a cigarette lighter plug, be aware that some of them aren't all that solid, and they can short. That would drain your battery (or kill the lighter fuse) and heat your charger.
    It also sounds like the "positive connector in the engine bay" isn't making contact with your battery -- thus unable to charge in the car, but okay out of the car.
  22. f355spider
    18,026
    Now drive it back and have the alternator tested to confirm that the alternator is charging correctly.
  23. Steve King
    Feb 15, 2001
    4,367
    NY
  24. 348SStb
    348SStb F1 Rookie
    I certainly did not connect the charger backwards. As for what actually happened, it is still a mystery to me.
  25. F430Rod
    F430Rod Formula Junior
    Feb 17, 2007
    482
    Orange County
    Rod
    Is it necessary to use the trickle charger every time you park the car? Or only if you don't drive for an extended period of time?
    The most I've gone is 2 weeks without driving and my F430 has started fine. Car is 2005.
    In my M3 I usually only drove once a week...sometimes two weeks and car started fine each time and the stock battery lasted 6 years and was still good when I simply decided to replace it with an Odyssey 925 I believe. This battery works good too.
