battery size for 575 | FerrariChat
Discussion in '456/550/575' started by henryr, Sep 28, 2009.
  1. henryr
    henryr Two Time F1 World Champ
    22,314
    Atlanta
    Juan Sánchez Villa-L
    looks like i'm gonna need a new a new battery (ppi when i bought it said it was weak).
    what size ? part number ? i think i've seen a few with interstates....
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Interstate MTP-6 is a perfect fit, and a very good battery.
  3. henryr
    22,314
    Atlanta
  4. tazandjan
    39,007
    Henry- I have an Interstate in mine. Works great.
    Taz
    Terry Phillips
  5. henryr
    22,314
    Atlanta
    my stock battery looks like it has some stick on heat shield around it. how important is that to replace given i have never noticed it on another car?
  6. tazandjan
    39,007
    Henry- It just extends battery life a bit. Kind of a tight fit with the insulation and battery and the insulation usually needs to be trimmed slightly to fit the battery, at any rate.
    Taz
    Terry Phillips
  7. henryr
    22,314
    Atlanta
    i see no MTP-6. i see a MTP-65 on the website. ?????
  8. tazandjan
    39,007
    Henry- Here is what I have on batteries. It is an MTP-91, not an MTP-6.
    MTP-91 Interstate fits perfectly with slight mod of the insulation ala box cutter. A mere trim. More cranking amps than the Fiamm.
    Delco 48-6YR or 48/91-6YR is a substitute for the MTP-91. Special order, no personal experience.
    Taz
    Terry Phillips
  9. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    My bad, its MTP-H6
    Both are very good, slight difference in dimensions. MTP-91 has slightly higher CCA, H-6 is more expensive, and heavier.
    Product ID: MTP-91(Automotive Truck)
    Amps: 875
    Cranking Amps: 875
    Cold Cranking Amps: 700
    Voltage: 12
    Termination: A
    Pro-rata Warranty: 85
    Weight: 36.9
    Width: 6.88
    Length: 11.38
    Height: 6.88
    Product ID: MTP-H6(Automotive Truck)
    Amps: 800
    Cranking Amps: 800
    Cold Cranking Amps: 640
    Voltage: 12
    Termination: A
    Weight: 40.8
    Width: 6.89
    Length: 10.94
    Height: 7.48
  10. tazandjan
    39,007
    #10 tazandjan, Sep 29, 2009
    Dave- Will add the MTP-6H to my list. Here are the details on the original FIAMM VR760:
    FIAMM VR760
    CAPACITY (Ah): 115 (min.)
    COLD CRANKING (A EN): 760
    CHARGE: Wet
    DIMENSIONS (mm): 276x175x175 (10.87x6.89x6.89 in. )
    DIMENSIONAL GROUP: L3B (says L3C in WSM)
    This would seem to indicate the FIAMM actually has more cold cranking power than either Interstate battery.
    Interestingly, the FIAMM applications tables (pdf too big to attach) shows the 575M replacement battery as a Titanium Plus L3 80+, not the VR 760. Here are excerpts from the tables.
    If any one wants the FIAMM applications pdf, let me know and I can e-mail it to you. It is 3.2 Mb.
    Taz
    Terry Phillips
  11. henryr
    22,314
    Atlanta
    i can only imagine what the "factory" battery costs ? $2k?
  12. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Plus its not warrantied at almost every service station in the country.
  13. tazandjan
    39,007
    Henry, Dave- Ricambi had dry FIAMMs for the 575M for about $400 last time I checked. I do not even think concourse judges care any more.
    Taz
    Terry Phillips
  14. henryr
    22,314
    Atlanta
    what needs to be modded ? insulation ?
  15. tazandjan
    39,007
    Henry- Affirmative. Slightly too tight a fit otherwise.
    Taz
    Terry Phillips
  16. henryr
    22,314
    Atlanta
    what insulation? the battery trim or the car insulation ? the mtp-h6 actually looks like it has the same dimensions except the height.
  17. fc_11
    fc_11 Karting
    Nov 21, 2008
    161
    NY
    mtp-91 fits but the added height makes it a bit tougher to get in. i could only get the heat shield around 3 sides so i left the aft-face uncovered. the difference in the 'feet' makes the battery sit more aft so the shielding doesn't fit. you could trim the forward foot and probably get it all to fit - but its more likely your heat shield will fall apart getting the battery out.
  18. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    For length and width the MTP-H6 is almost exactly the same as the Fiamm, just a bit taller which is no problem fitting. I don't have any insulation, previous owners must have removed it, but your insulation blanket should fit just fine.
  19. henryr
    22,314
    Atlanta
    i have the mtp-91 as having virtually the same deck height. just a little longer 11.38 vs 10.87 for the WOP battery.
    i'm gonna try the mtp-h6. looks to be about 1/2 taller but everything else matches.
  20. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Henry, you have to remove the coolant tank, but you do not have to disconnect the hoses, just move the whole thing, hoses and all out of the way.
  21. fc_11
    fc_11 Karting
    Nov 21, 2008
    161
    NY
    henry - you're right its the mtp-6 that i have, not the 91.
  22. henryr
    22,314
    Atlanta
    #22 henryr, Oct 3, 2009
    i swapped out the battery today. having shorty ratchet wrenches helps out big time. 10, 12, 13mm.
    here's a pick of the old WOP battery. the interstate MTP-6H is a exact copy as far as sizing even though the earlier posts show it to be slightly taller. it is a ***** to get the battery out without removing the coolant overflow tank. there are a couple of hoses attached that still manage to take up some room.
    best procedure is to slightly tilt and lift straight up. the battery is only 40 lbs or so. i just used my free hand while drinking a beer.
    now i'm of to the dealer friday as my check engine light is now on....:(
  23. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Just FYI
    I asked the Interstate guy today (the shop next door is an Interstate dealer) what the ”H” in H6 stood for thinking it might mean it has handles. What he said was that the “H” series are the highest quality battery they make, similar to a 91 but of a higher quality.
  24. henryr
    22,314
    Atlanta
    mmm, i double check but i dont think mine had handles......
  25. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Neither does mine. "H" stands for Heavy Duty, not handles
