Ball Polished Wheels and discolored clear coat | FerrariChat
Discussion in '360/430' started by CoreyNJ, Jul 2, 2020.
  1. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    On one of my wheels the clear coat is has some white discoloring near the center cap. Is this common? is there a way to fix without stripping and respraying the wheel? For example, does this kind of stuff polish off or once it discolors, the clear coat is done?
    Thanks,
    Cheers,
    Corey
  2. AandSC
    AandSC Formula Junior
    788
    Jax, FL
    Allen
  3. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    I guess I'll have to wait till the driving season is over since it will take upwards of two weeks with shipping. I wonder since my rims aren't actually damaged, but only have the clear coat issue if someone can simply polish the clear coat off in those areas and re-clear the entire rim locally so I don't have to put the car on jack stands for two weeks.
  4. AandSC
    788
    Jax, FL
    Allen
    Would be interested in knowing the same, but from what I’ve read that doesn’t work.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,686
    Central NJ
    Dominick
    There is a place in Edison that does rim refinishing
    Sent from my moto g(7) using Tapatalk
  6. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    AWESOME... what is the name of it and do they do polished rims or just painted?
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,686
    Central NJ
    Dominick
    Crimson wheel repair ..give them a call .. +1 732-632-7750
    Read and heard good things .. not endorsing..and no affiliation ..just figured I pass on the name
  8. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    What you see is simply corrosion of the aluminum under the clear coat. Over the years I have tried various clear coats on the custom aluminum moldings I fabricate. Nothing seems to be immune to this. I have even had custom pieces I've fabricated show this (usually at the edges where the clear realistically cannot "seal" the aluminum) as soon as 6 months upon delivery of the parts. Some last for years without problems. Even my powder coat guy of 25 years admits he cannot guarantee his clear powder coat won't show the same problem down the line when applied over aluminum-- for him too it'***** or miss.
    As others have suggested, you'll have to have them stripped and redone.
    I would however address it as soon as you can as the aluminum is actually corroding and you want to get to it before it gets too deep into the wheel. Tho longer it's there it will be hard to minimize the damage to the wheel itself from it's decomposition due the corrosion.
    Also, I see you live in New Jersey. If you drive the car in the winter at all, you may want to have another set of lesser wheels on the car once you have redone yours. Salt and aluminum-- not good. Clear coat or not.
  9. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    Ok. So it’s the aluminum not the actual clear that’s an issue.
    Can they be fixed by any wheel repair guy even if they don’t have a ball polishing machine?
  10. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    Check the thread. There's a few suggestions on who to go to.
    I doubt you want to go to "any wheel repair guy". Just sayin'...
  11. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Short answer for ball polished is no. They will need to strip the wheel, clean up the corrosion, ball polish again, and clear coat.
    KC360 FL and AandSC like this.
  12. AandSC
    788
    Jax, FL
    Allen
    One crazy thought I had was to buy a second set of ball polished rims so that one refinished set would always be on standby.
  13. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    I actually was thinking that, but selling the wheels after they are done.
    AandSC likes this.
  14. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,701
    Melbourne Florida
    KGC
    ... and keep one set for the winter months and salted roads.
  15. AandSC
    788
    Jax, FL
    Allen
    Thankfully no salted roads or winter where I live....
  16. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    I did the "sports" car in the winter back in 2000, which ended in a Boxster sliding down my driveway and into a snow bank. Ok, granted I didn't have winter tires on, but I think the Ferrari will join my GT3 hibernating for the winter. I did drive the GT3 one year with winter tires when I first got it, with the rear engine it was pretty amazing in the snow for a two wheel drive car, but an inch of snow and with the RS splitter was like a snow plow. Sold the spare wheels before the next winter.
    I guess that's why I have a Cayenne Diesel for winter (don't know what I'll do when it's time to replace it, love the diesel and they don't make them anymore).
    AandSC likes this.
  17. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    AandSC likes this.
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,650
    England
    Mark
    The trick is to use etching lacquer. Most places use regular clear to repair and it's next to useless. Nothing will last forever over bare aluminium but the right product makes a difference in terms of several years.
  19. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Or spay with an adhesion promoter THEN clear.
    mwstewart likes this.
