Aviation fuel | FerrariChat
Aviation fuel
Discussion in 'Technical Q&A' started by Daytona86, Feb 19, 2014.
  1. Daytona86
    Daytona86 Rookie
    Oct 24, 2010
    43
    Any know if you can run av 105 octane in a 1988 328 with no cat?
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,525
    Tuscaloosa, AL
    Drew Altemara
    There is no reason to. I would also be worried avgas does not meet some of the other motor fuel specs including the additive package required for motor fuel.
  3. zygomatic
    zygomatic F1 Veteran
    5,050
    Washington, DC
    Chris
    This would seem to be the best answer. But I'll ask anyway: what are you hoping the higher octane will do for you?
  4. ace51
    ace51 Karting
    Jun 30, 2008
    84
    NC
    no ethanol?
  5. Piper
    Piper Two Time F1 World Champ
    25,371
    Northern Virginia
    Bob
    Been a couple decades since I asked that same question, but from my imperfect memory when I broached the same question of 110LL avgas, the specific gravity of the gas is incorrect for auto engines. Sounds a little silly, but I recall the suggested fix being some small amount of linseed oil as an additive. Again, long term memory and can't even be sure I had perfect information at the time. But I'm pretty sure it's a nono to run straight avgas.
    I'd suggest you ask a mod to move this to the aviation section.
  6. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    Piper is right
  7. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    FWIW
    I ran 100ll in a high compression big block Chevy years back without a problem.
    Things were a bunch more casual then, the FBO was happy to take my money 16 gallons worth at a time. No road tax paid on Avgas and the color supposedly indicates this.
    In today's litigious world your FBO might balk.
    The miffed Cessna pilots waiting to refuel often warned me that it would hurt my engine.
    I beat the living daylights out of that thing and it loved it.
    I've seen 100% gasoline(if that is your goal) in rural areas. Those farmers know better than to put corn squeezins in their own machines.
  8. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I ran AVGAS in my chipped 1986 Porsche 944 Turbo with Bosch Motronic EFI and a CAT bypass. I wanted the higher octane for running higher boost during autocrosses. Never had a problem. 1980s vintage EFIs weren't so sophisticated back then.
  9. Piper
    25,371
    Northern Virginia
    Bob
    While I remember the issue, I don't exactly remember why it was a problem. Perhaps it's an issue of long, long term damage that doesn't ever manifest in the lesser mileage we put on our toys.
  10. boxerman
    boxerman F1 World Champ
    19,525
    FL
    Sean
    Buy 90 oct boat fuel. Or get Vp or shell racing fuel.
  11. The Kook Abides
    The Kook Abides F1 Rookie
    Jan 4, 2011
    3,459
    +1 my Ferrari ran like **** on avgas
  12. 328PWC
    328PWC Formula Junior
    Mar 5, 2011
    688
    Naples, FL
    Paul Cissell
  13. zygomatic
    5,050
    Washington, DC
    Chris
    I think there are a few reasons you don't want to run 110LL gas in your car:
    1)It'll kill your catalytic converters. Even LL has more lead than your cats like.
    2) Piper's memory is good here: the specific gravity of 110LL is lower (~.70) than typical pump gas (.72 - .77). This may interfere with fuel metering, so you may wind up inadvertently running leaner than planned. Further, the speed at which the fuel burns -- a imprecise/bad term -- will typically be higher with lower SG fuels. To benefit from this, you'd need extra advance in the ignition timing -- which your car likely doesn't have.
    3) If (and this is a big IF) your FBO will sell it to you, the Feds will love tagging both him and you with hefty fines. No road taxes figured into the price.
    To get back to the OP -- if you're running a car with ridiculous boost and want to prevent detonation you're better off going with either race gas or the old trick popular with some of the turbo monsters of the '70s: putting toluene (110 octane) in the gas.
  14. skip737
    skip737 Karting
    Dec 31, 2008
    115
    Lodi, New York
    WJH
    If your engine is running stock compression ratio, there is absolutely NO advantage in using higher octane gas than your engine requires for maximum power output. Wasted money, especially in today's world with 100LL aviation gas running between $6 and $9 per gallon. By the way, the color (blue) indicates that it is 100LL, not 80 (red) or 100 (green). It has absolutely nothing to do with road tax. High octane gas does not have any more energy in it than regular gas. Octane only measures resistance to detonation.
  15. Christian Sasfai
    Dec 31, 2012
    140
    Heath, Texas
    Christian Sasfai
    Avgas (the most common flavor known as 100LL) will run fine in older low compression V8s that can handle the lead. The combination of high octane and lead suppress detonation which is/can be a problem on aircraft engines. In a modern (remember, most piston aircraft engines are 1950s technology) automobile engine, the lead causes more issues than the high octane rating solves. I run a chain of FBOs and I can tell you that the number of folks buying 5 gallon cans of Avgas has dwindled to virtually zero. The specialty 'pump gas' that's available is much better for this purpose.
  16. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    get the pure gas app for iphone. Details locations selling gas without Ethanol
  17. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    My friend mix 50-50 of Avgas and 93 octane fuel in E34 M5 factory non-cat.
    Works fine
  18. f4udriver
    f4udriver Formula Junior
    Feb 1, 2012
    297
    Central Illinois
    Mike G
    I believe the octane rating is different for aircraft and 100LL may not be equivalent to 100 octane rating for a car.
    Whenever we run 100LL in our tugs they seem to run hotter.
    If you really want to go nuts you could buy 145 or 150 octane (can't remember exactly) that they use at the Reno Races.
    Somewhere I remember reading that 100LL was actually less octane then current car premium.
    But you are guaranteed no ethanol it really harms aircraft fuel systems.
  19. GTB Dave
    GTB Dave Karting
    Nov 3, 2013
    112
    B.C. Okanagan
    Dave
    It's been a while, 25 years or so, but if my memory serves me correct there are some issues with running the AV gas. At the time I was involved with a drag boat operation, which ran a normally aspirated 900hp 500 inch Chevy. The static compression ratio was close to 15:1. We ran Cam2 racing gasoline for fuel. Our 45 gallon drum ran dry and we couldn't get another in time for the weekend. We picked up some AV gas to get by. It was no where as good, the octane just wasn't good enough for us. But there were guys that ran it, and I seem to remember they complained because they couldn't get a good plug reading with the stuff.
  20. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Jumping in a bit late, but IMHO, no reason to use AV gas in a 328. My '86 runs just fine on 93 octane (or more often 91 octane) right out of the pump, and if you have upgraded your hoses to modern hose, which should be done anyway for safety, the ethanol in modern gas should not be a problem. That's my $.02. YMMV, but that's how I see it.
  21. JG333SP
    JG333SP Formula 3
    Mar 24, 2010
    1,871
    N Shore, MA
    Jim G
    So this 328 has no cats-but does the ethanol gum up older fuel injection systems/or newer ones for that matter? I know about the issues with old gas lines
  22. 88Testarossa
    88Testarossa Formula 3
    Sep 25, 2012
    2,450
    Annapolis and Daytona Beach
    Al
    I ran 110 AVGas in a 66 Vette in the 60's but wouldn't run in in my Ferraris today
  23. dwhite
    dwhite F1 Rookie
    A buddy use to use it in as a blend with reg gasoline his Twincam Lotus engine when lead was being taken out of gasoline - had no hardened valve seats.
  24. no8080
    no8080 Karting
    May 5, 2011
    83
    Uk
    Why not just use high octane car fuel? We have 99 octane fuel available at the pump in the UK.
    Putting higher octane fuel in a car does not yeild any performance benifits, unless the car is designed to run on high octane fuel.
    An example would be my F10 M5, it's quoted BHP figured is based on 98 octane fuel, it is designed to run on 98 octane fuel, running on a lesser octane fuel will lower the BHP, but not by much.
    Cars tend to be build to accept a wide range of octane levels, so unless you remap the ECU and start changing your engine it's a waste of money.
    Neil
  25. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    803
    Orchard Park NY
    Bruce Roche
    91 no etoh available at many marinas and stations. Also 100 with 9% etoh at some stations. I use a mix. Or just 93 if that'S all there is. GTS Bruce
