"AVH" failure warning light and funny braking | FerrariChat
Discussion in 'California/Portofino/Roma' started by MalibuGuy, Aug 23, 2013.
  1. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,795
    I had a weird experience when I developed an "AVH" failure warning light and immediately noticed greater "free" travel of the brake pedal.
    The car still braked but it seemed that there was a noticeably greater initial free travel of the pedal before the brakes engaged. When the the warning light went away, the brake pedal response returned to normal. When the problem re-occured, the brake pedal behaved strangely again.
    Has anyone else experienced this? Also need to mentioned that CST failure and Mannetino failure also occurred.
    Car is at the shop.
  2. MalibuGuy
    Sep 18, 2007
    5,795
    Also need to mentioned that the warning lights occured during driving and not at start up.
    I had been driving for about 30 minutes when the lights came on and the braking became weird.
  3. mtarvydas
    mtarvydas Formula Junior
    Oct 26, 2011
    701
    On the Mountain
    Martin Tarvydas
    I am not sure if this is remotely relevant to your issue but everything seems to boil down to battery life and the computer. I drove to work this week and did not realize that the radiator fan was running even with the key out. An employee comes in 2 hours later and says "hey your radiator fan is running." SH$T called the dealership and promptly drove the car over. Well on the highway I get "Power steering failure" "Transmission failure" and "AVH failure" It is just such a great feeling of limping on the road and watching everyone honk at you.
    Root cause - relay switch. All the other shutdown failures occurred because the battery was almost completely drained.
    Let's hope it is something as simple as that for you MalibuGuy
  4. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    I think when you get a barrage of sensor warnings, especially from different components, that a common factor could well be electrical. As cars become more and more electronically complicated, with sensors to detect various component failures, a weak link like the battery will definitely throw up multiple spurious faults.
    BTW, are you guys hooking up the battery tender every time you put the car away at home? I find the battery takes a bit of time to charge back up even after a long drive in the country. Perhaps the HELE system in my car is having a significant effect, but the charging system in my car does not seem to keep up with the draw.
  5. MalibuGuy
    Sep 18, 2007
    5,795
    I have a brand new battery, less than 2 weeks old.
    BTW the original factory battery was woefully under powered for the Cali electrical system.
    If you have the old one, get it updated with the more heavy duty battery.
    Also I drive the car every day and so my battery should be in good charge condition--provided that the battery and electrical demands and alternator are properly matched and designed. That is a question!
  6. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    A more heavy duty battery is a very good idea but even a new battery can still be defective and driving the car everyday does not mean the battery is being adequately recharged. If it's stop-go traffic, it actually makes it worse.
    So I ask again, are you hooking up the battery tender every time you put the car away?
  7. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    A friend with a 458 had a similar issue (the cars have basically the same internal IT structure, if I can call it that).
    As usual, the initial suspect was low battery/voltage, which can cause these kinds of issues...and the usual fix is to clear the codes with a DEIS, and charge (or replace) the battery.
    However, turns out that he actually had a relay and sensor failure; popped up clear as a bell on the DEIS, actually a straightforward fix, but it caused an electrical fault (hence the set of multiple, theoretically unrelated alarms/failures).
    In your case I'd suspect that you're feeling it in the braking (incl ABS) as that system feeds off so many other inputs - or, could be sourced to that (eg. booster not holding pressure).
    So - pure speculation on my part, a bit of my friends' story, we usually (and it's often the case) assume that it's a battery/charging issue, but it's not. FWIW I had a similar issue with a BMW.
  8. mtarvydas
    Oct 26, 2011
    701
    On the Mountain
    Martin Tarvydas
    That is my biggest challenge, I live in a high rise condo so nothing less than a 300 foot power cable will allow me to plug-in. Leaving for a month now and will be amazed if any of my cars start when I am back.
    Hey 4th_gear in your area for a while, perhaps we can break bread. I will PM you.
  9. MalibuGuy
    Sep 18, 2007
    5,795
    Found out it was a brake switch problem. So low voltage wasn't my issue.
    FerrariErnie and Willl like this.
  10. EricJG
    EricJG Rookie
    May 4, 2012
    3
    Amazing to spend this amount of money and find it acceptable to have to plug up your car to a battery charger to keep warnings, failures from appearing. Almost any nicely optioned car these days have nav, parking sensors, cameras, terrain or traction settings, etc. and you don't have to plug them in to run or maintain. Not buying"these cars have advanced electronics." Almost all cars do these days....
  11. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #11 4th_gear, Aug 24, 2013
    Well Eric, don't buy them then. :D Save your money and buy a Prius.
    Actually, my BMWs all had the same problem and that's where I learned how to properly take care of these cars. They had all the electronic goodies at least a decade before the "any nicely optioned car these days" finally got them. Many of those goodies weren't invented by the "any nicely optioned car these days". It's called the trickle-down effect.
    Anyway, in case you haven't clued in yet - most Ferraris are not driven daily and highway motoring for a Ferrari is a bit of a waste.
  12. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #12 4th_gear, Aug 24, 2013
    Good to know it was a single point failure. A brake switch problem may also explains the odd behaviour of your brakes although I thought brake switches only turn on the brake lights. So I'm not sure how a brake switch failure would cause the CST and Manettino "failures" as well as cause an odd behaviour with the brakes. I also have no idea what AVH means.
    Maybe your dealer should explain further - my wild guess is that the brake switch may have short-circuited and caused a surge that affected nearby sensor circuits (CST?) fed by the same electrical feed. I also wonder how the switch affects brake feel.
    Here's what I could dig up for a brake switch on the California. It's the only brake system switch listed by Ricambi for the Cali.
  13. MalibuGuy
    Sep 18, 2007
    5,795
    Eric I think you are right. 100%!
    Ferrari should be expected to meet high standards from owners. After all, we are the ones who make Ferrari profitable.
    Having cars which break down or have dead batteries or cracked exhaust headers is just not acceptible.
    Look Ferrari is happy to take owner's money --charging exhorbitantly for options-- owners spending $100K for silly plastic options.
    But then when the car breaks, the dealers have cheap ass Prius for loaners. This is pretty low class. Hope Ferrari are hearing this.
    Contrast this to the Saleman who looks down his nose at you if you try to negotiate for the car. And then the salesman who offer you twenty grand less than market as he twists your arm to take your car in for trade so you can get a spot on the list for a new car.
    Why Ferrari doesn't see the fact that poor engineering might actually explain why the racing team certainly hasn't done anything great over the past 6 years except dissappoint.
    Yes Alonso you are right too. I agree. The car needs to be better!
    Oh and I never liked BMWs either!
  14. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Wow MalibuGuy, you ARE pissed! I know you've had a string of service issues lately so I don't blame you. Of course, you know Ferrari doesn't actually make these parts but does build the engines, suspensions, car bodies and design how they are put together, along with the software.
    You need to find out why the part(s) failed and how the sensors were spuriously triggered. I wished service techs would explain things properly - same problem with many doctors. :( It's important for an intelligent person to understand the causes of problems because if you can't get a handle on a complex personal possession - they end up owning you.
    BMW, Porsche and Mercedes were the first makers to employ complex BOSCH systems in cars. IMO, they made their cars several notches better than the rest and dragged the entire car industry to vastly improve literally all the cars we see on the roads today. Everyone copied the Germans.
    I really loved my BMWs, which I held onto for at least 15 years each, until some idiot banged into them. I didn't buy another BMW because the new mass-market ones aren't that interesting to me …because they are mass-market. You don't seem to be impressed with a loaner Prius either so I don't think you plan to own one.
    BTW, have you considered taking your business to the other Ferrari dealers in the LA area?
  15. jumpinjohn
    jumpinjohn F1 Veteran
    7,404
    Texas
    What do you mean DD a Ferrari is a waste? If I buy something I intend to use it unless it is perhaps a collectible. Cars, guitars or whatever!
  16. EricJG
    EricJG Rookie
    May 4, 2012
    3
    I understand the "trickle down effect" but what I don't understand is the effect you sound accustomed to ....the "trickle charge up my ferrari after it sits a short amount of time effect". I'm blessed with some great cars and some do sit for some time but amazingly when I hit the key or button they start....with no failures. Not bashing as i do love ferraris(I'm on this site obviously) but every time I see a post about batteries, trickle charging it just irks me. No thanks on the prius🚗
  17. LARRYH
    LARRYH F1 Veteran
    9,513
    virginia usa
    I was told by the Dealer he'd mechanic that the new Fcars including the california only have a tolerance of 3/10 of a volt that is at 11.7 volts the systems will act up and start throwing faults. So I have found that just charging the car overnite once a week will solve most problems interesting i do not have the same problem on my 2001 550 which has a much less advanced systems (sic)..
    If you live in a condo with no electrical outlet available and the assoc will not add one at your parking space. .. then there must be a way to handle it.??
  18. MalibuGuy
    Sep 18, 2007
    5,795
    Sorry for my post!
    I was/am pissed.
    Anyway, you are right about the fact that Ferrari doesn't make all the parts. But they should fix some stupid problems which keep coming up on their cars.
    For example, cracked exhaust headers. Why don't they find a different supplier. I doubt they make the headers themselves. Seriously these headers have been problematic since the 360, 430, and now Cali and probably 458 too. What is the logic of using something that keeps breaking. Ferrari should hire a new firm to make their headers.
    Battery issues. First of all, if the supplier of your battery says that it shouldn't be located in a hot place, then why does Ferrari place it right next to the engine?
    Also if you know that the car has a complex electrical system, all cars do nowadays, then you should install a battery which is well or over-matched to those needs.
    Ferrari's priorities are mixed up- Let's place the battery for weight balance right next to the engine and not worry that it will age prematurely and die because of the heat! Let's save as much weight as possible and install a battery which barely meets the needs and most certainly won't meet the needs of the car once the battery starts to age!
    But of course when the owner has a problem, lets drag our feet and pretend we don't know why this happened. It is the owners fault. He needs to drive the car more. Or look at his mileage, he needs to drive the car less. After all this is a Ferrari! No one should drive the car like that.
    Bad switches and sensors. Since the cars have a lot more vibration and heat than other cars, Ferrari should use much more robust higher quality parts. Yes the parts are already expensive because of the low volumes, but trying to save here will result in failure of these parts later on. A sensors that melts and needs to be replaced, costs far more in terms of labor to replace than the actual part.
    Anyway, the Cali is meant to be a DD. This is what Luca said. I didn't proclaim this but the President of Ferrari did. Owners drive--put miles on-- daily drivers.
    But not too much miles, of course. Just the right amount, "Si?"
  19. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Well, what I actually meant was "take the side roads instead of the highway", if you can. I find cruising on the highway is only entertaining for the first few seconds when I accelerate from the ramp and another few seconds when I decelerate to exit the highway.
    I know it's not always possible but if you can find a decent secondary highway route to your daily commute destination that would likely make for a more entertaining drive. Failing that some folks also leave way early for work if they can have a more open highway to stretch their cars' legs on.
    Of course, for many people a DD doesn't actually involve commuting at all. So I'm not actually against DD usage, I just hate driving in heavy traffic. Years ago I simply moved downtown so I could walk to work and drive for fun.
  20. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Well, kudos to you if you have never had to contend with car problems after sitting your cars for weeks. But remember that batteries are consumables so they will crap out on you regardless.
    You might also consider why battery tenders and chargers are such popular items (some even with carmaker's branding) and why many people have used them on their cars …for decades. While I think it makes for entertaining discussions and "encouragement", griping about it doesn't necessarily prove a carmaker is negligent or messing up on purpose, unless we design cars for a living.
  21. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    That sounds awful. Wasn't aware of that problem and will try to learn more about it. Would you have any links to earlier discussions?
    I think there may be another view of this matter. From what I know, excessive heat does shorten the life of batteries but heat also boosts battery capacity (amp-hrs). I suspect Ferrari put the battery in the middle of the engine to improve battery reliability at the cost of potentially reducing battery life.
    Most battery issues tend to be due to weak charge or cold temperature starting so it would seem to make sense if they traded battery life for better battery capacity. I think it's not really a weight distribution issue because the Cali's rear bias is only 53% and I suspect 54% might even be better. I think the battery was purposely placed there to keep it warm.
    This actually brings up another lesson I learned with my BMWs - radiators. Both BMW and Mercedes (and other lesser makes) equipped (and probably still equipe) their cars with "plastic radiators" - essentially units with plastic housings and aluminium cores. The result was periodic catastrophic ruptures of either the plastic housing and/or fittings, immediate loss of coolant and possible heat damage to the engines.
    Why did BMW do this? My guess was "weight savings" more than "cost savings". My old E39 540i Sport had a huge front end weight bias which the industry deemed undesirable (and which I deemed fun to play with). Plastic radiators saves weight. Anyway, that's my guess.
    So what's the connection to the Cali's battery placement?
    The connection is heat, specifically heat buildup that results when the car is no longer in motion (benefiting from air flow/exchange) and heat buildup was what degraded and ruptured the plastic radiator components. In an attempt to prevent the plastic radiator disasters in my BMW I would religiously pop the hood of my BMW whenever I put it away. Since cooking the battery while the car is already protected from cold in your garage is completely pointless, I would suggest popping the hood if you store it in a private garage. I already do this with my Cali because I thought it pointless to cook the engine. A moving car gets a great deal of cooling from air flow and I don't perceive any cooling once the ignition is turned off. The radiator fan stops running.
    I suppose I'll have to wait and see if it helps protect the battery but most batteries do need replacement after 3-4 years so it's like your tires, and should probably be renewed even if it looks OK.
    Yes, the thing about keeping the mileage down is ridiculous and really more advantageous to the factory as it reduces the risks of warranty repairs.
    As for the parts, there's probably some sort of "luxury tax" added on top of an already healthy profit margin. I'm also wondering if the reason why poorly-performing parts may still be used as replacements is because the factory bought a huge quantity in the beginning, keep the surplus ones on inventory as replacements. So they would be reluctant to switch to a better replacement until they use up their stock of the crappy ones.
  22. jumpinjohn
    7,404
    Texas
    Ahhhh! This makes sense! And I totally agree on the freeway part. No F car in my stable yet, but my 911 Cab is a daily driver such as my drive is... For trips, however, I stay on side roads as much as possible.
  23. Lonnie
    Lonnie Formula Junior
    May 22, 2013
    499
    NY/Delray Beach FL
    Lonnie Mandel
    Interesting comment on brake pedal. I owned a a Cali for a couple of mnths and from time to time felt the same feeling in the brake pedal. There were certainly times I felt the brake pedal had more play in it then other times.
  24. I know this thread is 10 years old at this point but I'm going to try anyways to see if there is the odd chance that anyone else has experienced this.
    I have the same persistent problem with AVH / Mannetino failure errors and the play in the brakes BUT I only get it when I go over bumps, railroad tracks, or a dip in the road.
    Then the car goes into Wet mode and stays there for as long as you drive until you shut it off and let it rest about 15-20 mins and then it starts up and works normally until you go over another bump.
    Car is 2013 458 Spider
  25. Fanaticrom
    Fanaticrom Rookie
    Mar 27, 2021
    17
    Romania
    Might be one of the ground wires (there are several around the car) that doesn't make a perfect contact.
    The 458 seems to be the most sensitive car in the world when it comes to voltage variations :(
    I am experiencing something similar (not from bumps) for the last year. It is driving me nuts.
