Aux input on original radio | FerrariChat
Discussion in '612/599' started by 360Marnix, Dec 29, 2019.
  1. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    490
    Holland
    I have a OEM Ferrari radio (becker mexico 6104)
    A few months ago I bought an aux input cable to use instead of the cd changer.
    I installed the cable. But the cable is equiped with a pink cable/wire.
    Can somebody tell me where to put this wire?
    It should be connected somewhere, the aux is not working now.
  2. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I think this is the wrong cable. Also you have Image Unavailable, Please Login to disconnect the CD player by removing both blue and green plugs.
  3. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
  4. 360Marnix
    Jan 4, 2017
    490
    Holland
    It is probably the wrong cable indeed. I removed the yellow, blue and green plugs and I selected the aux option in the radio menu. But it still does not work.
  5. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,313
    South East
    Jimmie
    The 6104 is standard in the 360 & 575 too and there are many threads covering aux (albeit usually using an Apple wire) - my recollection is the spare wire on the Apple cables charged - also Aux in the menu needs to be turned actively on not just selected - I recall cross checking the pins (in the diagram above) against the description in the manual helpful to make sure everything was correctly connected ie C1 is the speakers and C2 is the CD or Aux connection
