News
Anyone wish they'd gotten a Lusso T instead of a Lusso or vice versa?
Discussion in 'FF/GTC4Lusso/F12/812S' started by sisiay, Jan 27, 2020.
  1. sisiay
    sisiay Rookie
    17
    Who are you going to use for the roof box?
  2. HBstig
    HBstig Karting
    95
    HBstig
    cavallouomo likes this.
  3. sisiay
    sisiay Rookie
    17
    So suction cup mount?
  4. HBstig
    HBstig Karting
    95
    HBstig
    Yes. No other way to mount it on the FF.
    Sent from my Pixel 4 XL using FerrariChat.com mobile app
  5. sisiay
    sisiay Rookie
    17
  6. HBstig
    HBstig Karting
    95
    HBstig
  7. Jas
    Jas Formula Junior
    Mar 2, 2005
    999
    Kent, UK
    Jas
    I agree, and would add that neither are nimble. We are discussing a 2 ton car here. Makes little difference whether it's 1925kg or 2000kg. (Approximate real life weights, not fake Ferrari weights.)
    V12 is the obvious choice here if buying a Lusso. If buying a turbo V8, why not just buy a different 4 seat car altogether?
  8. Jas
    Jas Formula Junior
    Mar 2, 2005
    999
    Kent, UK
    Jas
    But the main reason for the V12 is...…….
  9. SVR
    SVR Karting
    Feb 9, 2017
    75
    Moscow, Russia
    #84 SVR, Feb 14, 2020
    V12 with RWD mod
    Or V8 with ECU tune and exhaust
    AWD on Lusso is terrible, it kill all fun, and feeling of safety on slippery surfaces.
    And nose with v12 and PTU is too heavy.
    V8 much lighter, shorter and more deep in car base. And no PTU, in front of axle.
  10. SVR
    SVR Karting
    Feb 9, 2017
    75
    Moscow, Russia
    1. Because different 4 seat car, is not a Ferrari
    2. Design - shooting brake
    3. Passenger display )))
  11. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    5,807
    Bournemouth, UK
    I have just explained that above. Not true at all!
    ANOpax and Il Co-Pilota like this.
  12. Il Co-Pilota
    Il Co-Pilota Formula 3
    May 29, 2019
    1,843
    Copenhagen
    A.B
    Zeus is right. The tiny difference in weight is a non-issue. We're talking 1790 vs. 1740 kg. I'm a 73 kg guy, so I suspect that my weight alone may offset the difference of other more heavy set fellas. Add to that how different a spec can be. I think for all intended purposes, many v8 an v12 versions are surprisingly close in weight once you weigh them. The weight balance between each car is pretty much the same as well.
    You also need to think of the Lusso as rwd, not awd or 4wd. Yes it has a ptu with a small torque converter pump system, but that's nothing like a true 4wd system. It can transfer a bit of power to the front in certain situations, but it's not l8ke you the a big chunk of those 690 ps up front. About 80 or so at best, the rest goes to the rear. The Lusso V12 is and drives for all intended puposes as an rwd car, because that's what it is. What to experience the Lusso as 4wd? Find a muddy dirt road, raise the suspension so you don't scrape things, put it in ICE and floor it through the mud. It will lumber along slowly and not show much in terms of accelleration, despite your foot being mashed to the carpet. In that situation it really feels 4wd and that's fun. But then try this. Go out on a day where the roads are damp, temps are around 6-8 c, put it in comfort and floor it. So much for 4wd lol..it's an rwd car with the ability to put a bit of power to the fronts in some specific situations.
    REALZEUS and ANOpax like this.
  13. Agpl
    Agpl Karting
    Jan 15, 2013
    85
    Worcestershire UK
    John Ranson
    I have a V12 Lusso in the rural UK wet greasy conditions throughout our winter so the part AWD system is perfect to stop understeer when pushing on without the weight and loss of balance found in a conventional system.
    I also have a Honda NSX similar result through the independent electric motor on each front wheel. both incredible turn in ability especially given our weather.
  14. SVR
    SVR Karting
    Feb 9, 2017
    75
    Moscow, Russia
    In theory, everything is fine. But when you live in Moscow and once a week, BMW M5 or Audi c8 want to race with you on a snowy road, you will find out that such AWD is worse than the usual AWD because it does not give traction, and worse than the RWD because it does not give pleasure in Drift and predictability in difficult situations.
    I really love my winter-weekend Lusso, but my everyday M5 is much better in terms of all-wheel drive. When you drive slowly, or on a dry road, everything is ok. But it is worth starting to go a little faster, on a road different from the ideal, and satisfaction disappears, there remains annoyance.
