Anyone use Brad Penn oil? | FerrariChat
Discussion in 'Technical Q&A' started by parkerfe, Jan 24, 2008.
  1. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  2. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    I remember seeing engines that used Quaker State. When you removed the valve covers. There was this waxy residue. I was told Quaker State adds//has a high content of wax/parafin. I always used Valvoline in the 60s and 70s. I don't know if parafin is good or bad. I use synthetic.
    Charles
  3. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  4. f355spider
    f355spider F1 World Champ
    18,026
  5. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    high zinc content for classic cars, high flash point, quality base stock and additive package and more with resulting cooler oil temps...it is the same top quality green oil that was sold as Kendall GT for decades...
  6. f355spider
    18,026
    Any more info? The threads on www.bobistheoilguy.com in the forums show a couple oil tests. They were pretty unremarkable...meaning they were good, but nothing special. One even posted the zinc as no higher than what other oils "regular" oils have.
    http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Board=11&Number=1025144&Searchpage=6&Main=79501&Words=brad+penn&topic=0&Search=true#Post1025144
    This one shows the zinc up higher
    http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Board=11&Number=1046996&Searchpage=4&Main=81105&Words=brad+penn&topic=0&Search=true#Post1046996
    I know you have been searching for the "holy grail" of oil for your older car, do you think this may be it?
  7. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    A lot of good "in the field" comments from vintage/historic racing folks, Frank. When I started working on cars, that Kendall GT-1 was the ONLY oil I used, upon pain of death from my mentor. Paul Spruell was another strong proponent. You don't win four National Chamiponships on "bob the oil guy" reports...
  8. pks41805
    pks41805 Formula 3
    Aug 4, 2007
    1,152
    Colorado Springs, Co
    Paul Sloan
    I have tried Brad Pitt Oil to lube up my wife. Real smooth.
  9. staatsof
    95,271
    Fuggetaboutitland
    Bob
    LOL and about to die ...
    And, very appropriate for these what always seem like useless oil discussions.
  10. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I know that back in the late 60s and early 70s I always used Kendall GT oil in everything I drove from cars to motorcycles and was well pleased...it was the oil to use in those days...it even had its own unusual smell like no other oil and was a green color for some reason...now that the same formula is being marketed under the Brad Penn name, I think I may just give it a try the next time I change the oil in my BB512i...
  11. f355spider
    18,026
    Sure, oil analysis and testing is way over rated. Better to just ask guys who win multiple national championships. ;)
    I would suspect that anyone who wins consistently is doing plenty of research and testing on their own, using similar testing laboratories.
  12. pastmaster
    pastmaster Formula Junior
    Feb 5, 2006
    890
    Alma, Michigan USA
    Don't forget "BIG DADDY - DON GARLITS," and the "SWAMP RATS," series of Top Eliminator Dragsters.
    Don Garlits, swore by this oil, KENDALL GT-1. It was my favorite too, back in those days.
    Today, I use MOBIL 1 DELVAC 5W40 Synthetic, for my more modern cars, with the higher viscosity needs, and MOBIL DELVAC Super 1300 15W40 Conventional or Dino, for my older cars, that are operated more gently and driven on the road vs. track. It is changed more for time, than miles.
    These are Diesel engine oils, or HDEO's, but are also rated for gas engines too. They work very well and protect against corrosion etc., from sitting and storage too. Castrol, makes some fine Specialty oils too. And don't forget SHELL, if they don't have it, you don't need it.
    I don't know which oil is better, for the conditions we use them for. Brad Penn, I'm sure is also updated in other areas too. MOBIL, is always leading the pack and more current. I can walk into Walmart or Mobil Stations, and buy Delvac, right off the shelf, anywhere.
    Go to Bob is the Oil guy, bitog.com, and do some reading on both oils. You really can't go wrong using the old GT-1, in an older design engine. But I think modern oils like Delvac, are OK, may be better for our purposes.
    Ciao...Paolo
  13. pastmaster
    Feb 5, 2006
    890
    Alma, Michigan USA
    Re-reading this thread, I forgot to say this. I would use Brad Penn's GT-1, in any of my older cars that needed a 20/50W oil, without any hesitation. It was the best of it's era, and will do the job today. There are some auto parts stores locally, that have it or can get it, but it's still a hassle, as I am almost in BFE. Today, the HDEO's do the job for me.
    Also, on the Brad Penn Site, they make a break-in oil for rebuilt engines, for that use only. Very interesting...has anyone used it? I usually make up a witches brew, with additives, and those aren't available to us anymore, so this is great!!!
    http://www.bradpennracing.com/Products/BIO30.html
    Ciao...Paolo
  14. ckracing
    May 20, 2006
    728
    Charles
    I am reading the History of Mobil 1 oil. Wax in oil.
    By contrast, synthetics are “designer” fluids, composed of
    a very few of the best lubricant molecules.
    They stay together at high temperatures, keeping the
    metal surfaces clean and maintaining the lubricant film.
    They are virtually wax-free, so the oil keeps flowing at very
    low temperatures. And they can be tailored to meet any
    viscosity requirement.
    Charles
  15. Whisky
    Whisky Three Time F1 World Champ
    30,674
    In the flight path to Offutt
    The original Fernando
    Ok, I need to ask:
    When is the last time you read about an engine failure DIRECTLY ATTRIBUTED to 'OIL' failure ?
    I don't mean an oil system or pump failure, but oil itself causing the blowup ?
    If someone pays me enough money, I'd run baby oil through my engines.
    Some folks say they are paid endorsers of products (oil) - 'but I would be using this oil anyway';
    While that may be a true statement, a majority of folks 'grow up' on a certain brand of oil, and they don't deviate. For whatever reason.
    Again, I didn't say ALL folks, I said the majority. Kinda like how your dad or grandpa has always been a 'ford guy' or 'chevy guy',
    same applies to certain products. Like oil.
  16. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I'm on a Top Fuel Dragster pit crew (I'm the data geek). We run a solid-block 426 Hemi with a top-hat blower, etc. We only run Brad Penn (70 weight) - 17 Quarts, changed after each run (contaminated with NitroMethane). All I know is that stuff is STICKY. On one run last year the catch tank belched out of the overflow and drenched my data logging computer. What a mess! The nitro in the oil attacked all the plastic cable connectors and fused them. It took me days to clean it all off and replace the connectors.
    Not really on the topic, but I thought I'd chime in.
  17. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Very good point.
    Quaker State paid for 5 engines I had to build back in 77 or 78, havent heard of anything since then. When changing the oil on ? back in the early 70's I remember having to stick a screwdriver through a layer of that white scum that collected in the bottom of an oil pan just to get it to drain. The owner told me he used Penzoil.
    I changed to Redline only after Mobil started fooling around with their formula's. I have to say using the Redline 5w-40 gives better hot idle oil pressure than we were seeing with the 15w-50 Mobil 1.
    Dave
  18. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    That's funny, In the 70's, I pulled the valve cover from my Father's old Buick Riviera, he used Pensoil too and I found the same white thick sludge. I used Valvoline back then in my old Vette and mine was immaculate. I've heard that Valvoline is a high detergent oil, it sure looked like it. I use mobil1 now and it doesn't leave any residue either.
  19. kalkocz
    kalkocz Rookie
    Apr 2, 2006
    12
    Los Gatos CA
    Charles Z Kalko
    Hello everyone.
    When I first purchased my 512 TR, I asked the previous owner what oil he had been using. I was actually surprised with the answer that I got. Namely that he was running a non synthetic dino oil called valvoline VR1 racing 20w50. His thoughts where that if I started using a synthetic that the my engine would start leaking like a sieve and that it was the only safe oil for cars with flat tappets. He was basing this recommendations from people he knew that where moding late model Lambos and Porsche's and started seeing strange wear on cams and bearings in the last few years.
    So this peaked my interest and I started to search around on VR1 oil. I soon learned that there where two types of VR-1 oil the new versions and the "Old" that was not for street use. This has lead me down the rabbit whole of SM vs SJ type oils!
    As for Brad Penn Oil do a goggle search for: "Ultimate Motor Oil Thread or Why we hate CJ4/SM oils" it will lead you to a 911 technical forum on pelican parts forums web site. It's quite a tome of a post it's around 500 posts long and very in depth. I did manage to wade through the information that is presented there. I suggest it to any one as a good primer on the topic of oils.
    As I know that Oil like timing belts are a religious topic around here I will leave the conclusions to the reader.
    As a side note I have started to steep learning curve in to oil analysis. Since I am definitely a gear head and one can never get enough data it seems the way to go on this topic.
    Cheers
    Charles
  20. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    Back in the day, many people would trash Castrol because of the sludge build up in the valve covers. But when I started, multigrades were a new thing and oil changes/greasing was every 1200 miles! Modern engines have much improved breathing characteristics and do not show that so much anymore. But for me, first choice is the manufacturers recommended grade with a slight adjustment to suit prevailing conditions/temperatures. The manufacturer plays little in the choice, Elf/LubroMoly/Mobil etc., not much to choose imo. Although when I was a chief mechanic, it was known to repackage oil so that our sponsors would be happy and so would our engine builders (in F1 and Indianapolis).
    B.
  21. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    I hear that, been there. Happened often.
  22. DadsFerrari
    DadsFerrari Formula 3
    May 31, 2004
    1,559
    New England
    Mister M
    Also looking to buy more brad penn, any good deals in the northeast or on the web?
  23. BillyD
    BillyD Formula 3
    1,806
    Pacific Northwest
    Bill
    I went to their web site & asked via email & they gave me both mail order & local retailers. Lucky for me there is a retailer less than a mile from my work place.
    Bill
  24. bill brooks
    bill brooks F1 Veteran
    BANNED Silver Subscribed
    Jul 30, 2007
    5,961
    waynesburg,pa
    bill brooks
    ruff creek general store in ruff creek,pa. stocks it.
    you'll probably have to pick up. ray doesn't ship.
    he does sell for $49.95+ tax.
  25. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,633
    NJ
    Peter
    I did quite a bit of reading selecting oil, and this was the thread that convinced me to go with Brad Penn. I tried to buy it from the person that provided much of the info in that thread (Charles) because I really valued those comments, but he didn't have the 15w40, so ended up ordering 2 cases on Amazon. I'm running it now in the 330GT -- it seems fine but pretty difficult to tell a difference in oils.
    I think oil-related failures are unlikely to occur with any brand of oil, but I do think brands can make a difference in wear over a long period of time. It takes the oil companies a ton of research to figure out the right combination of additives, so it seems better to buy a well formulated oil than to try to use additives on your own. I was thinking of adding ZDDP Plus to oil given flat tappet motor, but after reading many articles I don't think that's a good idea.
