Anyone try this flat tire repair product? | FerrariChat
Discussion in 'Technical Q&A' started by SCKOMS, Jul 2, 2012.
  1. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Saw this on a TV show tonight. It pumps sealant and air into a flat tire to seal and re inflate it. Seems like a good deal at $50 on Amazon.com.
    Has anyone tried this or carry it in their car?
    http://www.slime.com/shop/safety-spair-70005/
  2. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    I'm not crazy about putting all the slime into the tire. When the tire is eventually repaired properly, it has to be cleaned out. I never used the stuff, so I'm just guessing. I would imagine that it may work ok for a small leak, to get you home or to a repair shop.
    My preference was this kit:
    http://www.stopngo.com/categories/Tire-Pluggers/
    I saw them advertised at a motorcycle show that I went to, they did a demo, it worked very nicely!
    I like that there are no messy glues to deal with, or dry out. It is also very quick and easy, compared to the "standard" string type plugs. I put a set in my car, along with a very small 12v pump that I used to use on my motorcycle. I also replaced the original tire sealant can with an $8 can of fix-a-flat, just in case. Of course I would use that as a last resort, it would have the same disadvantages as the slime stuff.
    The choice is yours, but I don't think that there is any great answer to a flat on our cars.
  3. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Weve turned into a society of push button sprays and slimes. Yes, beter than nothing, I guess, especially in emergencies, but much better alternative is to have the spare if the space for one is provided in the car.
    These days, some manufacturers dont even provide the extra tire anymore. Sheesh. (GM is one- I had to source a spare "donut" at a jnk yard for my new chevy recently). A donut is better than instant slime goo into your hopefully repairable tire......
  4. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Works WAY better than the aerosol fix-a-flat types
    These days? The 348 has not had a spare tire or jack since 1989!
  5. Splitting Atoms
    Splitting Atoms Formula 3
    Sep 18, 2011
    1,557
    South Carolina
    Eric
    Some of the local tire shops will not remove the old tire to replace it if a product like "fix-a-flat" has been used. There is the potential that it could slime their equipment and they don't want to waste their time cleaning it. You have to find a place willing to remove the old tire and and then clean the wheel yourself.
  6. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Slime is awesome...for bicycle tires. I pre-Slime mine all the time. Car? I don't know, but I do know our new Acura says any sealant spray or foam will require new tire pressure sensors in the wheel where it was used. Are there any sort of sensors in your tires/wheels?
  7. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    No TPMS in my car. But this product is apparently safe for TPMS. just thought it might be something good to have...just in case.
  8. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,153
    Seattle Area
    Dave
    I've had this happen. Used a big can of the aerosol goo on the family SUV when
    in nowhere-town, Montana - just to get us to a city that had tire repair facilities.
    (the spare was buried under a huge pile of work samples, suitcases, etc. and I
    didn't want to take the 2 hours it would have taken to change the tire - we had
    to stay on schedule as it was a business trip)
    The Les Schwab guy DID repair our tire - but told us they normally don't touch
    "fix-a-flat" tires because they have no way of knowing if the goo is toxic or
    flammable. Plus they have to scrape it all out to get a good balance when it's
    back on the wheel.
    He did us a nice favor, but boy did I get a lecture :p:p
    Jedi
  9. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  10. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    It's what I've carried for years in past cars that lacked a real spare. (Actually the deluxe version.) I continue that tradition with my present cars. Much better than a can of sealant.
  11. 430tdf
    430tdf Formula Junior
    Aug 7, 2008
    280
    Canada
    Brett
    Am I missing something here?
    Isn’t this slime kit basically the same thing that comes standard with a new Ferrari for flat repair instead of a real tire these days?
    At least that what I think is in the black pouch in my 430, a small compressor and a can of slime, and at 60 dollars it's a lot cheaper than buying it from the Ferrari parts department!
