Anyone put 19 inch wheels on an FF? | Page 3 | FerrariChat
Discussion in 'FF/Lusso' started by msgm1, Dec 10, 2020.
  1. Caeruleus11
    Caeruleus11 F1 World Champ
    11,584
    Butter Zone indeed! :)
    Il Co-Pilota likes this.
  2. otakki
    otakki Formula 3
    1,634
    Bummer! I just found out both are designed by the same person. It would have been a perfect match!
  3. Caeruleus11
    11,584
    Took her on a highway trip yesterday, people could not believe there is a Ferrari on the highway with winter traction. Had to visit some areas with very choppy roads and while no terrible potholes, many sunken manhole covers. Absolutely no problems, this is the perfect winter setup.
    of2worlds and otakki like this.
  4. otakki
    otakki Formula 3
    1,634
    From everything I have read on this and other threads, is it correct to say that changing this car's wheel diameter will not cause any problems to its firmware, ie ABS/ESC/etc, or hardware? I'm not gonna ask the dealership because their response will always be: if you don't use the oem sizes, it's gonna cause problems to this system and that system blah, blah, blah.o_O
    BTW, is it safe to elevate the front more than the rear with the tire's sidewall? Hopefully at speed the car is not going to do an airborne back flip like the Mercedes CLR's in the '99 LeMans.
  5. ttforcefed
    ttforcefed F1 World Champ
    19,247
    Lets take them out tmrw!
    Caeruleus11 and Il Co-Pilota like this.
  6. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    The difference between OE f/r bias and the new f/r bias is within what the system is designed to work with, so no problem.
    As for raising the front higher, well, you don't. Yes, you change the rake about 3.8mm which is hard to even see. You increase diameter of both front and rear. The car rakes forward a lot more than those few mm, so you would have use a really BIG front to raise the front higher than the rear, so no, you won't make a "Mark Webber" as with this new setup, the car will still rake forward.
    Caeruleus11 likes this.
  7. Caeruleus11
    11,584
    What kind of speeds are you talking about? Around here you would never exceed 110 and that is for a fraction of a second because you've over cooked it. I can tell you I had the car above 100 yesterday with zero issues. It was next to a Lusso on stock tires and there is really no noticeable change to rake, but good to think about this.
  8. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,352
    The Netherlands
    #58 ANOpax, Dec 16, 2020
    Here's the stats on the rolling diameters:
    Stock
    Summer ratio of front to rear 245/35/20 295/35/20 rolling diameter is 5.01% greater at the rear
    Winter ratio 235/35/20 285/35/20 is 5.36% greater at the rear
    OZ Zeus
    265/35/20 315/30/21 ratio is 4.32% greater at the rear
    I did the front/rear rolling diameter calculations when I was choosing tyres for my summer wheel setup with the OZ Zeus. As you can see, my Zeus setup is running less diameter at the rear than OE ratios and it has not presented any drivetrain or handling issues at all.
    If I’ve done my maths correctly, that’s equivalent to 2.5mm less rake vs the OE summer tyre setup and 3.8mm less than the winter setup.
    of2worlds likes this.
  9. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    So, has anyone found the answer to this thread? will a 19 clear the brakes? the 458 challenge car runs on 19s?
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Yes 19" wheels will clear the brakes. What are you looking to do? Winter wheels?
  11. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    Well I'm hoping to run a set of Michelin all season 4, so I'm hoping to hit a 19x8.5 ET 45 on the front with a 245/40/19, while running the 20x10.5 ET50 in the back using the original 295/35/20. The temps in my area most of the year hover around 8-17c, especially in the Spring and Summer, and around freezing during the evenings. So my plan is to get a little bit more sidewall in the front, while running a compound that much more pliable in during the other 3 seasons. As I find Pzeros to be very waxy below 16c.
    Anyone try this?
    https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Sport+All+Season+4&frontTire=44YR9PSAS4XL&rearTire=935YR0PSAS4XL&vehicleSearch=false&fromCompare1=yes
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    In that case, save yourself the trouble and use 245/40R20 and 275/40R20 on the OE wheels.
    Ask Caeruleus11 about that size. It works, and it works well. It will have the same profile as you are looking to have on the 19's.
    Depending on how sporty or winter-able you want them, either of these should do nicely.
    The Vred's are the most "all season" of the bunch, while the Conti, Yoko Goodyear and Pirellis are the more sporty.
    All are Y rated.
    https://www.tirerack.com/tires/tires.jsp?tireMake=Vredestein&tireModel=Quatrac+Pro&frontTire=44YR0QTPXL&rearTire=74YR0QTPXL&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=ExtremeContact+DWS+06+Plus&frontTire=44YR0DWS06PXL&rearTire=74YR0DWS06PXL&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=ADVAN+Sport+A%2FS%2B&frontTire=44YR0ADSASPXL&rearTire=74YR0ADSASPXL&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Eagle+Exhilarate&frontTire=44YR0EEXXL&rearTire=74YR0EEXXL&vehicleSearch=false&fromCompare1=yes
    https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=P+Zero+All+Season+Plus&frontTire=44YR0P0ASPXL&rearTire=74YR0P0ASPXL&vehicleSearch=false&fromCompare1=yes
    So plenty to choose from without resorting to 19's.
    Caeruleus11 and otakki like this.
  13. otakki
    otakki Formula 3
    1,634
    Yup! Those are the sizes that should have been spec'ed by Ferrari in the first place.
  14. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Nah. What they should have done was to fit it with 275/35R20 and 315/35R20 on 9 and 11 inch wide wheels.
    Bundy, Caeruleus11 and otakki like this.
  15. otakki
    otakki Formula 3
    1,634
    Indeed, those 812 sizes will have the same amount of sidewall at the front as 245/40.
  16. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Yep but more importantly, with a lot more volume. They would run at a pretty low pressure by comparison and thus be great at absorbing jolts. You could easily drop the pressure 4-5 psi compared to stock, and gain a softer tyre with a lot more protection. With the correct offset it can be done. Have seen a few FF's with 812 wheels and tyres.
    otakki and Caeruleus11 like this.
  17. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    I went and did it, 19s front with a 245 40 19, dramatic increase in daily driveabikity, slight decrease in steering feel, but well worth it.
  18. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,227
    WA
    Fernando
    What wheels did you get? Pics?
  19. msgm1
    msgm1 Formula Junior
    Nov 4, 2003
    454
    NYC
    Yes pictures pls!
  20. Caeruleus11
    11,584
    I’d love to know!
    I’d also note a friend with a Delta Integrale on his very first drive within 5 minutes had a flat. So that is not a solution to flat tires. The solution is better roads. That is my rant for the day carry on!
    vraa and otakki like this.
  21. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    I'll try and get some this weekend provided the weather co-operates.
  22. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Cool. Which wheels are they?
  23. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    otakki, Wazzer and ANOpax like this.
  24. msgm1
    Nov 4, 2003
    454
    NYC
    nice! did u need to do anything for them to fit over the brakes? how do they handle?
  25. msgm1
    Nov 4, 2003
    454
    NYC
    Could u not do 19's on the rear wheels as well?
