Anyone having problems with the 296? | FerrariChat
Discussion in '296' started by F8Max, Jun 14, 2023.
  1. F8Max
    F8Max Rookie
    Nov 17, 2019
    14
    Europe
    A
    I am having multiple problems with the electric system. It shows check engine/ check electric system, visit service. This seems to be caused by a low charging level of the 12V battery although it is always connected to a charger and weekly driven. The faults do not disappear after driving and letting the car shut down for a while. Unfortunetly it was transported to the dealer twice to check..
  2. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    Airing your dirty laundry in public may result in negative consequences.
    09Scuderia likes this.
  3. dustman
    dustman F1 World Champ
    11,041
    furmano, 350MH83, Hawkeye and 3 others like this.
  4. Divexxtreme
    Divexxtreme Formula Junior
    Aug 14, 2020
    850
    Scott
    No issues here at 3-months of ownership.
    jm2 likes this.
  5. F8Max
    F8Max Rookie
    Nov 17, 2019
    14
    Europe
    A
    Hm, thanks for your very helpful reply! I appreciate a lot!
  6. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,523
    Austin TX
    I would suggest replacing the 12V battery.
    And, do not leave the 12V battery on tender all the time. Once a week for 12 hours or until back to full charge is all you need. The battery does not like being full charge all the time, it needs to relax.
  7. ntatfas
    ntatfas Formula Junior
    Apr 27, 2011
    273
    I have had no issues on an Oct 22 car. I put the hybrid system on charge when I park up and I believe that will charge the 12v system as it sees fit.
  8. PieGre
    PieGre Karting
    Jan 9, 2019
    120
    Luxembourg
    PG
    Radio did not work, should be replaced next week.
    Apple car Play did not work, fixed.
    Mutiple noises from everywhere, dealership useless, I fixed most of them by myself with W40 Spray and felt from my wife :) .
    Ryan S., Ultralab and F8Max like this.
  9. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    Spend $400K on a car and you need to use W40 and cloth to address issues.
    BillPrev, Doug. and ryalex like this.
  10. SVanDyck
    SVanDyck Formula Junior
    Oct 4, 2021
    459
    Joe Michaels
    I also don’t see the point in doing this. Dealership will buy the car back for 100% paid immediately with one phone call, or keep car one year and make a profit. No real advantage to airing this out publicly.
    09Scuderia and SECRET like this.
  11. Ivan Drago
    Ivan Drago Formula 3
    Jul 14, 2021
    1,192
    Midwest
    Ivan Drago
    What's the problem? He bought a car that he expects to work and is having issues, as are others. Aren't people allowed to talk about it and to let other potential owners know about things they can run into? @PieGre said the dealership was not helpful to him. He is frustrated. Max is frustrated. They should shut up and be quiet because Ferrari will come to the message board and be upset?
    We are Ferrari fans, but not on Ferrari's payroll.
  12. 250boano
    250boano Formula Junior
    Apr 27, 2022
    450
    Europe
    DD
    Yeah you idiot. What the hell were you thinking coming to an owner's forum to discuss your ownership experience?
    You must have taken complete leave of your senses!
  13. hubyone
    hubyone Karting
    Aug 29, 2018
    63
    Hubert
    this is not what my dealer told me
    BigJay2050 and ryalex like this.
  14. SVanDyck
    Oct 4, 2021
    459
    Joe Michaels
    Not to hijack but: Is it Ok to never plug in the hybrid system and to only recharge the hybrid system by driving?
  15. hubyone
    hubyone Karting
    Aug 29, 2018
    63
    Hubert
    I'm plugging it in mostly as I don't drive it every day.
    To avoid having battery issues.
    I was doing the same with my F12.
  16. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,523
    Austin TX
    BillPrev likes this.
  17. Divexxtreme
    Aug 14, 2020
    850
    Scott
    My dealer was adamant that whenever I'm not driving car, I should have it plugged in to the charger to ensure the battery level never drops too low. This recommendation was the same for both my 296 and SF90.
    Junaid13, 09Scuderia, fws357 and 3 others like this.
  18. Ivan Drago
    Jul 14, 2021
    1,192
    Midwest
    Ivan Drago
    Don’t these chargers “trickle” down when the battery is full anyway and prevent over charging? They let it drop back down and the fill up again from there. At least that’s how my ctek works but I’m not sure on the model. These are smart chargers
    BigJay2050, howydo, Ryan S. and 3 others like this.
  19. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    932
    San Diego
    Rob Barry
    As stated upstream, the CTEK tenders check the battery, do a fast charge to 80%, a slow charge to 100%, a test to confirm it can hold the charge, then put it in float / pulse mode. My 2014 458 Spider went over eight years on its original factory battery connected to a CTEK 7002 tender when not driven. I have a 2003 BMW Z4 (owned since new for 20 years now), that lasted over 10 years when left consistently on a CTEK 4.3 (for up to a year at a time, because . . . 458). We have an SUV (BMW X5) that barely made it five years being driven several times a week, but only put on a tender every two weeks. If a car comes with a battery tender port . . you should always use the battery tender.
    STEP 1 DESULPHATION
    Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START
    Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK
    Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION
    Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE
    Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND
    Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT
    Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE
    Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
  20. PieGre
    PieGre Karting
    Jan 9, 2019
    120
    Luxembourg
    PG
    I like my 296 and I have no choice, the dealership won't take it back as the electronic problems will be fixed and the "noises" are no real argument. Sooo, I will have a go by myself ... or go to a different dealership around 4 hours away. Time will tell.
  21. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    899
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Thanks for the heads up--my friend had a bricked SF90 which was sold back to the dealer after the second retu4n for diagnostic repair for the electrical issues. Dealer was unable to fix.
  22. Kmaaq
    Kmaaq Formula Junior
    Jul 26, 2019
    602
    Qatar
    Khalid Mohammed ALQattan
    7 months and 6000km in: only plugged the car in ONCE, and it was just to try it. Then again mine is never parked for more than a week.
    And to reply to the main post: No problems with mine. Only once I floored it and got a DRS error message, the spoiler got stuck in the up position. I don’t know why or how but I parked, turned the car off and the spoiler went back in. Turned it on and went on my way, error disappeared and it never happened again.
  23. Shorn355
    Shorn355 F1 Veteran
    6,857
    Colorado
    Scott
    Precisely- Any decent modern tender has 4 stages- The last being float- that is designed- and works flawlessly- to "maintain" the battery but not over charge it.
  24. SVanDyck
    Oct 4, 2021
    459
    Joe Michaels
    This is great to hear. I live in a high rise where it’s a challenge to plug in. I’m expecting my 296 this winter
  25. jjmalez
    jjmalez F1 Veteran
    6,572
    Northern Illinois
    Joseph
    Hey now, there's a backroom lounge here on F-chat for a reason.
    BigJay2050 and Shorn355 like this.
