Anyone has a solution to how to fix broken diecast parts | FerrariChat
Discussion in 'Collectables, Literature, & Models' started by BLACK HORSE, Jan 30, 2007.
  1. BLACK HORSE
    BLACK HORSE Formula 3
    1,954
    California - Bay Area
    Rob
    I’m seeking a solution to how to fix broken diecast parts for 1:18 cars. I have a few which were damaged, suspension, hinges, etc.. you know “the usual fragile parts that are easily broken”. Anyone who has a close secret to repair instead tossing the car away. And just for the record, last week I posted my Mega Ferrari 1:18 Collection “which I will soon post pictures of” and all cars in my collection are un-broken cars. The cars I want to fix are just extras.
  2. lucky_13_2002
    lucky_13_2002 F1 Rookie
    Nov 26, 2006
    3,025
    Colorado
    Michael
    Best thing to do with them is to use them for future projects.That is if you like to modify models,which can a lot of fun.
  3. Scott85
    Scott85 Formula 3
    Dec 16, 2000
    1,240
    Dayton , OH
    Can you post a list of what parts you're looking for , I may be able to help?
  4. 1_can_dream
    1_can_dream F1 Veteran
    Jan 7, 2006
    8,051
    Colorado
    Kyle
    Scratch building, or just getting creative with the pieces, or if you can find replacements as offered above.
  5. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Try JB Weld. It's commonly found in hardware stores or the likes of Wally World. Good luck.
  6. Challenge64
    Challenge64 F1 Veteran
    6,358
    Ron
    fixing diecast is hard. Because it is metal that is cast as opposed to stamped and shaped, its a pain. A diecast hinge is all but impossible to fix.
    There are things you can attempt..Like the stuff someone else above posted..but depending what broke there are other things to try. ie..drilling and sinking a pins...
  7. matelko
    matelko Rookie
    Feb 12, 2007
    2
    Diecast is the common name for ZAMAG which means an alloy mainly made from Zinc and Aluminium with a small portion of Magnesium. It is the Aluminium which makes it so difficult to solder. However, there is a way to resolve this problem: contact your local DEGUSSA representative. DEGUSSA offers a suitable cored solder (e.g. Soldamoll 145) and flux (e.g. Soldaflux AL).
    The next step is a suitable hardware since you cannot use your electrical soldering iron. You need a pencil-style Bunsen burner. This is very important since the burner must have the ability to fine-adjust the flame, otherwise you will burn what you want to repair.
    Ah yes, as always, you finally need some skill and practice which cannot be purchased anywhere.....
    Good Luck!
  8. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    PeterS on this board sells some glue that bonds almost instantly. I have used it on metal, wood and plastic parts and is awesome. It is stronger than crazy glue and inexpensive. It dries clear and is almost unnoticable...
  9. PeterS
    PeterS Five Time F1 World Champ
    51,242
    Goodyear, AZ
    PeterS
    #9 PeterS, Feb 12, 2007
  10. PeterS
    51,242
    Goodyear, AZ
    PeterS
    HOLY CRAP!!!! I just posted a pic of the packaging a 'dcotored up'!!!!!
  11. matelko
    matelko Rookie
    Feb 12, 2007
    2
    Super glue has one significant drawback:
    never shear the glued parts for whatever reason! Otherwise they'll brake again like glassware since Cyanacrylate (the main component of super glue) is brittle. Super glue works perfect as long as any force is applied perpendicular to the glued plane only.
    Just my two cents....
  12. sap1956
    sap1956 Rookie
    Jan 20, 2016
    1
    It bonds diecast??? Where can I buy this glue??? Thank you....
  13. the_stig
    the_stig F1 Rookie
    Sep 19, 2005
    3,497
    Not applicable to diecast metal parts but for certain other pieces a relatively new technology in plastic welding is available from a company called Bondic.
    Similar to certain tooth filling methods this is a clear liquid that is hardened by exposure to UV light. With Bondic the applicator is a liquid filled cartridge in a pen-styled holder with a built-in UV LED light. You build up the repair in thin layers hardening as you go. Can be used to fill in for missing material.
    Might come in handy for plastic parts particularly if they have a "bad" side that is normally hidden.
    As a last ditch effort for unobtainable parts there is always the option of drawing a replacement in CAD software and uploading to Shapeways for 3D printing. A lot of scratch-builders are now doing this to enhance kits like the Model Factory Hiro 1:12 scale Porsche 956.
  14. Setarch
    Setarch Rookie
    Oct 2, 2023
    3
    Steve Tise
    I use either super glue or bondic to get an immediate take. Then I use 2 ton 2 part epoxy around the connection and clean with a q tip. Let sit for 24 hours. I also use eyeglass cement for clear parts, but it mars the surface so be very careful. Epoxy can be removed to start over without destroying the surfaces. I also use model masking tape to hold parts in place while they set up. I have also made replacement chrome parts for small scale using wood, then a primer, then I paint both old and new with an amazing $50/1/2oz. Chrome paint from England. Amazing results.
