Anybody here have a bulging/herniated disc issue? | FerrariChat
Discussion in 'Health & Fitness' started by pingi3, Aug 19, 2012.
  1. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    If so how serious was it and has the problem went away? My C6 is bulging or so it appears. Seeing a spine specialist on Thursday. MRI was looked at by my orthopedic surgeon and he sees a bulge and is pressing on the nerves from the spine causing numbness in the right arm all the way down to the hand. Can't sleep and in constant pain. Doing some research and seeing mixed reviews about disc repair, both with shots and with therapy (acupuncture, chiropractic methods, etc...). Hoping to hear positive remarks from past experiences.
    Thanks in advance.
  2. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,618
    Pittsburgh, PA
    Matt F
    I had a similar problem, about four years ago.
    It was far lower, around L4-L5, so I had leg pain along the sciatic nerve. But I had the same sleeplessness because I was in constant pain.
    I fooled around with steroids, physical therapy, and other treatments. None worked.
    I finally begged the surgeon to operate. He did, and it was the best thing I ever did.
    I was pain free immediately.
    Back surgery today is minimally invasive and the recovery is rapid. The risk of damaging other nerves is close to nil.
    Your mileage may vary!
    Matt
  3. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    Thanks for the reply. So if I may ask, was it a fusion? What I read was that the disc can not be operated on but could heal if properly "worked" with therapy.
    I'm 40 and see a long future playing sports with my kids so Im a little depressed at the moment with the fear that I have to endure possible pain with limited play. Also having to deal with a non-union of my left scaphoid bone does not help. 2 bone grafts and screws and pins, leaves me to ponder proximal row carpectomy or 4 corner fusion. So bascially I have pain in both arms and neck. Now where is my Lorazepam.
  4. Ducman491
    Ducman491 Formula 3
    Apr 9, 2004
    1,591
    Mentor OH
    Jason
    I had surgery on the disc between C6 & C7 in 2002. It "slipped" badly playing volleyball. Total loss of feeling immediately in my left arm. Tried physical therapy for 6 weeks before surgery but ultimately had to go under the knife. Six weeks of recovery in which I couldn't lift anything heavier than a gallon of milk. Since then no problems at all. I did lose a little range of motion but that is my fault, I didnt follow my PT stretching to the letter. I'm always conscious of how I lift and turn and up until last year I was in a job where I would lift 40-80lbs and carry it on my shoulder 15-20 times a day. I have a Ti plate and 4 Ti screws holding the disc in.
  5. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    Wow, that must have been a serious injury. Was it a complete rupture of the discs?
  6. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    755
    Green Cove Spgs FL
    Harry Welch
    Surgery,make it your last ditch effort,I had a Fusion also on my L4-L5 back in Feb of 2011,for some reason it never took the Pain away in my lower Back or Numbness down my Right Leg,I have been seeing a pain specialist since Oct of last year.He has Performed a series of Injections on my Spine and Pelvis,Which now the Pain is under control.My advice to you is research your alternatives,Laser traetment,Recompression therapy,Core strenghting,Sometimes Surgery(fusion) should be your last Treatment.Hope it all works out for you Harry.
  7. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    Thanks Harry. Hope your pain stays away. Yes, I would hope to say surgery is my last option. I will see the spine specialist on thursday and hope for good results.
  8. bball16
    bball16 F1 Rookie
    3,865
    NY LI FtL
    I had 4-5 surgery in 2005. I have been playing baseball, basketball and golf pain free ever since. Prior to the surgery I tried PT and epidural shots with no success. The surgeon did a diskectomy and double lamenectomy. I walked out of the hospital the next day pain free and have never looked back. The most important thing is to find the right Dr.
  9. Smiles
    Nov 20, 2003
    16,618
    Pittsburgh, PA
    Matt F
    No, not a fusion. Thankfully.
    Good luck. I hope you can be repaired with minimal work.
  10. dm_n_stuff
    I have two down low that sometimes give me trouble. It was much worse ten years ago.
    Lost some weight, saw a really good physical therapist and have not (knock on wood) had any serious problems in 5-6 years.
    Occasional flare up, usually when I do something stupid, but a few days of careful exercise and anti-inflammation meds usually clears it right up.
    Too many years of rugby, I guess.
    D
  11. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    51,541
    SFPD
    Dirty Harry
    Drink Chocolate Milk to reduce inflammation
    Take Motrin with food.
    Sleep on left side with pillow between legs.
    Keep right arm above duvet while gently laying knuckles into pillow, as it helps stabilize the arm.
    If need be, keep a pillow behind you to keep from rolling over to sore/numb side.
    Do what you can muster in Crunches.
    Fortunately, Sex is the best exercise.
  12. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    I actually talked to a lot pf friends today and they also suffered from bulging discs. They all tried different methods (PT, decompression therapy, accupuncture, etc.) and doing well. Most said try to avoid surgery. One did cryotheropy and said it worked wonders. I'm going tomorrow to try cryo. 300 degrees below zero for 3 minutes. Can't wait.
  13. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    My L5 has been really bothering me for a good 10 years. i've been to every Chiro got nothing. My sister told me to try her Chiro Kinesiologist. WOW, after 1 session with Dr. Howard Cohn (google him) I feel like a new (er) man. I'm not 100% yet but from just 1 visit i feel 75% better. i'm going again tonight for my second (out of 4) visit. I've been bothered by this for 10 years. I'm so excited!!!!! www.cohnhealthinstitute.com
  14. Ducman491
    Ducman491 Formula 3
    Apr 9, 2004
    1,591
    Mentor OH
    Jason
    Not a rupture but very close. We played in a higher level league and the Dr. saiid if I would have been hit in the head blocking, with as hard as they hit a volleyball, I may have been paralyzed. Luckily I was 27 and healed pretty well so I moved onto a safer sport...I play hockey now. Good luck and I hope you feel better soon.
  15. wax
    Jul 20, 2003
    51,541
    SFPD
    Dirty Harry
    I'm very, very happy for you - Go Yankees.
    ^How to fit 5 Y's in a concise note^
    via rubber ducky
  16. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    Wow.... meeting a lot of people that have or had the same problem as myself. It looks like it is more common than I thought. Great to hear stories of success ridding themselves of the pain. Still waiting to see the spin specialist on Thursday. In the mean time doing Teeter hang ups and started cryotherpy. Standing in a chamber filled with nitrogen at -190 degrees for 3 minutes. At this point will try anything.
  17. Statler
    Statler F1 World Champ
    Jun 7, 2011
    17,389
    yoga. lots of yoga.
    Haven't missed a day of work or had any pain in four years. 41 years old.
    If you're heavy, drop weight too. Went from 215 to 155 (5'10").
    Cutting was to be an absolute last resort after I did what I could do (Wife's in medicine so we have lots of docs on first name basis.... 2 of 3 wanted to cut). Glad I went that route.
    edit: I was at point where if I moved wrong I would see stars and be in so much pain I would start to black out. Pinched once while tying my shoes and couldn't get off floor for hours... ended up calling 911 when I finally could CRAWL to phone.
  18. Devilsolsi
    Devilsolsi F1 Veteran
    8,526
    MD
    Alex
    I herniated a disc in my lower back a few years ago from playing tennis (don't recall which one it was exactly). I did the PT thing when it first happened and have been managing the pain with anti-inflamatories and stretching/exercise. It flares up a couple times a year but the pain is usually gone within a week or two.
    Unless it gets much worse, I am going to avoid the idea of surgery.
  19. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,874
    You might also investigate VAX-D. Non-invasive, and I had good results with it. It's a de-compression table, basically. You do it every day of the week for 4-5 weeks. Treatments take, all-in, about an hour to an hour and a half, which is a commitment. BUT, like I said, it worked well enough for me.
    CW
  20. Face76
    Face76 F1 World Champ
    11,706
    The Other Oz
    M Wilborn
    L3 - L4 discs give me a problem but only when I ride my tractor or motorcycle. The vibration seems to irritate the sciatic nerve and I have a bad limp for about 5 minutes.
  21. KatMan
    KatMan Formula Junior
    490
    Silicon Valley
    Stan K
    Had problems with L3-L4 disc and L4-L5 disc. Tried everything. Physical therapy, rest, anti inflam meds, injections. Finally did minimally invasive surgery to trim the discs. Still had big problems. After very serious consideration, went for the nuclear option - fusion of L3-L4 and L4-5. The bad: recovery took 1 year with the first 3 months consisting of catastrophic pain. The good: Problem has completely gone away. I am very active and no longer even think of my back, but my God - what a year.
  22. Face76
    11,706
    The Other Oz
    M Wilborn
    KatMan - How old were you when you had the surgery?
  23. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    Me 2
  24. pingi3
    pingi3 Formula 3
    1,547
    Atlanta
    Quack
    #24 pingi3, Aug 30, 2012
    My Dr saw my MRI and pretty much gave me a quick, yep your going to need surgery. I could clearly see a huge bulge pushing into the fluid sack around the spinal cord. If my insurance company allows, he wants to install an artificial disc instead of a fusion. I did not even hesitate. I said lets go for it. Plus I'm tired of the pain meds.
  25. KatMan
    490
    Silicon Valley
    Stan K
    I was in my mid 60's when I had my L3-L4-L5 fusion done. BTW, I was under the impression that the artificial disc has become a controversial procedure.
