Any Safe/Sane Techniques on compressing coil springs at Home?
Discussion in '308/328' started by christopher, Dec 30, 2012.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello and Happy New Year fellow “F” Chatters.
    Might anyone have a nice simple DIY technique in compressing the coil springs at the home without killing yourself?
    I’ll be installing new Koni’s and due to my insanely fastidiousness regarding not wanting to chip and paint on the springs or otherwise, wanted to attempt this myself…Albeit safely.
    Thank you much,
    Chris.
  2. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I think you can make a safe compressor out of steel angle and 3/4 threaded rod if you are handy and have access to a welder.
  3. 4right
    4right F1 Rookie
    When I did my suspension, I just took the springs and shocks to a local tire retailer and they removed them for cheap money. I wasn't willing to risk it as I didn't have the correct tools.
  4. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    39,711
    Huntsville, AL., USA
    Andrew
    Would just buying something like this work without the need for welding?
    Then you're not trusting your own home welding not to fail and send the spring pinging up into your own face. Presumably, mass-produced products are designs and constructions that are rigorously tested before being presented to the public. No knowledge or affiliation with that particular tool or seller. Just querying it.
    All the best,
    Andrew.
  5. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    #5 Fairview, Dec 30, 2012
    I like to do as much of my own work as I can, but I'm very happy I had a shop with a spring compressor do this job. I helped with this at the shop, and even with a professional upright floor model spring compressor, it was a bit spooky.
    Andrew, that tool you referred to above won't work on the 308/328 shocks/springs as the centerbolt needs to go where the shock is located.
    Here's what is more suited to the task: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7769092_0006537861
    And here is the style used by the shop which is much better, but it will still scare the bejezus out of you. This thing sells for $750! I'd leave it to the professionals.
    Be careful!
  6. 4right
    4right F1 Rookie
    How much will that cost in comparison to just paying someone to do this work for you? It's not like you will be doing this work on a regular basis that will justify the investment. Unless of course you have other cars that you are working on. Your decision obviously!
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,394
    San Carlos, CA
    Mitchell Le
    They charge about $20 to compress one spring for you. I am totally out of space in the garage, or I would buy one of those $800 strut compressors.
  8. tazz99
    tazz99 F1 Rookie
    4,418
    Kennesaw, GA
    Seth
    Go to your local "Autozone" store and borrow a spring compressor. You pay a deposit then when you return it they give back your money.
  9. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Andrew this kind of compressor does not work on Ferrari springs. There is the shock in the center.
  10. NeuroBeaker
    Moderator
    Oct 1, 2008
    39,711
    Andrew
    Thanks Jeff and Claude. :)
    All the best,
    Andrew.
  11. gdbsti
    gdbsti Formula Junior
    Oct 10, 2004
    283
    Nor Cal
    Bruce
    I Highly recommend taking them to a reputable shop with a Branick or similar spring compressor. Those springs are seriously pre-loaded..
  12. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    #12 godabitibi, Dec 30, 2012
    Here is what I have in mind. Safe and easy to do. One upper and one lower with two rods thru the holes and bingo. Size the rod to be safe. If you need to completly remove the spring from the compressor make sure your rod is long enough.
  13. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Jeff Ward
    Claude,
    I like your design. If you build it with heavy enough metal and are a good welder, that looks much safer for this than a standard spring compressor. Nicely thought out...
    I remember that the springs have quite a bit of preload, so once you slip out the retaining rings, you'll need plenty of length in your threaded rods to fully release the spring.
    Still easier to let a professional shop do it, but I understand self-reliance, too!
    Jeff
  14. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    External spring compressor.
    Borrow from Autozone as said below (loan-a-tool).
    Don't build with welder...too dangerous.
  15. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    The autozone type rentals don't work with the 308 springs as noted above. Believe me, I tried them all. The coils are too close and too thick to allow the hooks of the compressor to get through them. Finally took them to a tire store and they put them in their compressor and changed them out for $10 each.
  16. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Good point. However, if the compressor were disassembled first, the hooks could be emplaced, then reassesmbled for compression. I'll also admit that I haven't compressed the springs on my Konis yet, so this is a genaralization.
  17. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    The strut tamer is the way to go. The company I work for makes it and I am friends with the lead engineer of that item. As simple of a tool as it looks there was Alot of RD around the safety of the design.
  18. Qvb
    Qvb F1 Rookie
    2,844
    Newport Beach Ca.
    John Dixon
    I could be wrong, but I don't see anything here to keep the end piece from rotating through the axis running through the two rods (In other words, if there were a line between the two bolt holes, the part could rotate around that line). It may not fail because of the rotation, but I think it would be scarey! If it were round with 3 threaded rods it would seem more stable. As a kid, I made one out of flat steel bar and threaded rod, and looking back, I probably almost killed myself. It destroyed itself as I used it.
  19. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,282
    Ventura, California
    Robert Garven
    #19 robertgarven, Dec 31, 2012
    The shop that did mine was far less complex that the one shown here. I had the ones that took the spring off with lots of ratcheting, but after spending hours sanding and painting did not want to mess it up reassembling it the same way. They had one mounted on the wall and took less than 10 seconds to put the new shock in the spring and slip in the retaining ring. They are out of business hope they left that thing on the wall, I will go check!
    I suggest going to a suspension shop.
    cant find a pic on line but it was lever mounted and did not have to do anything but put the assembly in there and it pressed on the two ends of the spring, compressing it popped in the retainer the lift up on the arm......
    here are a few I found online that look similar but without the lever, once again the cool ones are only from the UK........
    the top one is a draper and it is 400pundsUK! Id buy one if there were not so expensive it sure looks pretty simple to me!!!
  20. VEEP
    VEEP Formula Junior
    Nov 9, 2005
    525
    Overasselt
    I hope you are not buying stuff for a probably one time only job... Pay one to do it , rent one or borrow one, if you have good understanding with your mecanic you even may be allowed to do it in his shop in slow hours for a good bottle of wine or something like that.
    Worked years that way, my own tools are limited to normal set for most jobs and some bigger stuff that is bought because used more often.
  21. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,800
    Dallas Texas
    If you know you know
    Short answer is No. ( Unless you have the correct equipment )
    You need to use the correct equipment, you do not want a spring bouncing off the car or worse your head. They are unforgiving!
    As others have said, as a DIY'r myself remove the assembly and take the unit to a shop that has the correct equipment and let them do it. It's worth the money saved < wink >
    If you were closer, I'd offer to help...
    GL and be safe,
    S
  22. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    You don't need a spring compressor for these because you can remove the spring/shock unit from the car without compressing the spring.
    The shock can be removed from the spring using a press although it has to be a large one. But that can be used for many other tasks so is a better investment.
  23. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Guys,
    I very much appreciate your input…I think that the majority rules in this case..I’d have to say that I’m guessing I’ll be taking them to a shop….
    Any ideas on how I should protect them from the ham handed individual from scratch any paint on the units?
    Thank you very much Guys!
    Chris.
