Any engine experts that can help re some technical questions on an bmw s85 motor? | FerrariChat
Discussion in 'Technical Q&A' started by craze, Dec 30, 2022.
  1. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    As above
    Its rebuilt and re honed block for alusil
    Heads recoed
    Crank isotropic polished
    Symptom:
    Only if cold first five mins cant rev more than 2000-3000 or engine dies then has zero comp in all cylinders!
    When warm no issue runs fine
    Has to sit for a bit then comp is back and runs fine
    Swapped cam adjusters, vanos solenoids engine harness, ecu, engine oil, no change
    Thank you
  2. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Happy to pay for time if you are extremely familar with this motor
    Its been in shop 9 months now
  3. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    I'm not familiar with your motor specifically, but I do build engines...
    When you say zero compression in all cylinders, do you mean you are doing a compression check (with the throttle body held open) and the readings are around zero PSI??
    Also, has anyone done a leak down test in the cylinders, as opposed to just a straight compression check?
    Do you happen to know the individual piston to cylinder wall clearances for each individual engine bore?
    Also, is this a direct gas injection motor or a port fuel injected motor?
    Ray
  4. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ray is correct, leak down will tell you where the issue is. I had similar issue, bent every intake valve was the issue.
    Compression test tells you nothing about diagnostics. Exept you have an issue. Leak down is next.
    Sent from my SM-G990U using FerrariChat.com mobile app
    RayJohns likes this.
  6. Mhoram
    Mhoram Karting
    Apr 15, 2009
    67
    I have been working on restoring a 2007 M5 and have a pretty good understanding of the engine. I was able to get a Troy 5.5L rebuild. It has been great but I should have just replaced everything else when I put the motor in. Since the rebuild I think I have replace most of the ignition and air control systems and had to work on the diagnostic of each.
    I am not an engine builder and not sure if something in the engine rebuild could cause the compression to come and go. Normally when I see compression go it doesn't just come back. Are you able to use a boreacsope to make sure there are no damage in the cylinders? Any fuel in the oil? If there is something mechanical wrong from the rebuild causing a loss of compression I would think it would either show up on the cylinder walls or in the oil.
    It could have something to do with the ITBs. My understanding is engine doesn't open the throttle bodes until over a a few thousand rpms. Under that it relays on the idle control valves. The throttle actuators do go bad. Each of mine went bad intermittently and it was frustrating to verify before just throwing cash at them.
    Do you have an check engine lights?
    Is the engine going into limp mode? If so what rpm is it limiting the engine to?
    How many miles on the rest of the engine components (ionic control module, throttle actuators, idle control valves, plugs and coils, fuel innjectors)?
    Are you able to monitor with INPA?
    Have you tested for a small vacume leak that could be sealing itself when the engine gets up to temp?
    Sent from my SM-G973U using Tapatalk
  7. Mhoram
    Mhoram Karting
    Apr 15, 2009
    67
    Was the engine rebuilt because of a rod bearing, fuel hydrolock, or some other reason?
  8. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    This engine was rebuilt as I started it after spirited drive and it had missfire/limp mode
    Took it to bmw and originally thought it was vanos pump as it had vanos codes
    Sent whole car back to builder who originally rebuilt it 2500km ago and found bearing x2 span
    A lot of questions some i know the answer to
    I asked re leak down several times and hasnt answered that directly
    I dont see how comp can come and go surely valves not bent
  9. Mhoram
    Mhoram Karting
    Apr 15, 2009
    67
    Wow 2 spun bearing on a new build. Doesn't give much confidence in the build.
    Generally my misfires have have been caused by the ionic control module or coils going out. I haven't had any luck with non bmw coils. The engine uses the spark plug as a sensor to measure the quality of the combustion and as a knock sensor.
    Also a vacuum leak can cause it to misfire.
    There is a vanos high pressure oil line that should have been replaced when the engine was rebuilt, and the vanos bleed procedure should have been done a few times via INPA.
    Also the engine shouldn't be rotated backwards since it can damage the vanos pump.
  10. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    All that done
    I know right, unfortunately due to covid etc it made the rebuild difficult getting parts
    I have my own opinion as to what happened but this doesn’t help the immediate issue
    Its a missfire as no compression above 2000rpm until warm
    If u let it idle for 5 mins its fine and runs fine
    Im going to fly up and see the car myself
    I dont understand how it idles, yet when revs go up no comp, then when warm its fine
  11. Mhoram
    Mhoram Karting
    Apr 15, 2009
    67
    Maybe the timing is slightly off and the vanos adjustment is compensating for it after the engine is warm. Seems like that could explain the weird compression. Would have to be extremely lucky to get the timing off that would cause this but not have the valves hit the pistons.
    I think you could use INPA to log the different sensors and get a much better idea of what exactly is wrong. There is a lot of data you can get out of the engine. If you are able to do that I could look at the values my engine is giving and see where the differences are.
  12. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Timing has been checked 4 times its via a jig
    Checked target and actual data from vanos inpa on my car and working customer car its all ok
    Hoping an tech from bmw thats worked on these cars is here
    Even taking to bmw dealer sometimes its hard to get a master tech that has relevant training
  13. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    If you had a spun bearing just after a rebuild, that brings into question a lot. Either there is a serious lubrication issue, or someone in the chain of rebuilding doesn't know how to use a micromoeter or something. My concern would be that tolerances were not accurate when boring/honing the cylinders relative to the piston sizes.
    Usually failure to rev (not counting ECU intervention for some reason) relates either to breathing restrictions some place in either the intake system and/or the exhaust system. The other possibility would be having valve timing relative to the crankshaft off a bit. I don't know your motor first hand, but skimming through Wiki, it looks rather advanced. I would also be concerned that something could be damaged in the electronic ignition relative to the ECU understanding crank position. You've got to be very careful about some of those crank trigger components.
    As far as "zero compression", where are you getting this figure from? Having "zero" compression in even one cylinder would be alarming, let alone all of them. Even if you have a hole in the top of your piston, a compression check would probably still be able to muster 10 or 20 PSI on the gauge. Even with a spun bearing, you can usually get 40 or 80 PSI.
    Spun bearing is very bad on a rebuild... something had to have been way off the mark. Bearing clearance usually is held to around .001" per 1 inch of crank journal diameter, so we are talking clearances here of around .0020 to .0025 typically on a performance engine. That's far too small to allow any properly installed bearing to spin over on itself.
    Ray
    JL350 likes this.
  14. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    Anyone talented enough to rebuild your V8 correctly ain't working at a BMW dealership. They are most likely off working in Formula 1 or MotoGP.
    Ray
  15. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    That sounds almost like a coolant temp sensor or something is sending the ECU(s) incorrect information during the warm up phase. I don't know the specifics of your particular motor, but keep in mind that gas has to atomize to burn correctly. When things are cold, motors usually jump through a lot of hoops to try to get the show on the road and warm everything up so the fuel will vaporize better. I wonder if some circuit relative to helping that is out of wack or not functioning.
    If you restart the engine after it's up to temp, does it still run fine?
    Ray
  16. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    Well said.
    Compression test tells you there is an issue.
    Leak down test helps you identify what the issue actually is.
    I just did a compression check on my Toyota.
    Cylinder #1 - 185
    Cylinder #2 - 135
    Cylinder #3 - don't remember because I was in shock from seeing the readings on cylinder #2, which is normally ~ 180
    Cylinder #4 - 160 - double shock, since it's normally 178 +/- 2 PSI
    So off the cylinder head came... discovered lots of bad things. All the compression rings on all the pistons were broken. Piston #2 had holes burned into the upper ring lands. Part of the ring made its escape into the bore/cylinder head chamber and went to town. Here's the current fun over here:
    I think on the BMW, you need someone there who knows what they are doing. Get some compression readings and more data. Also, if anyone worth their salt rebuilt your motor, there shouldn't be any problem getting the rebuild information on the motor - for example, what were the individual cylinder wall clearances, etc. I don't think that's your issue, but you never know. I was just watching a YouTube video series where this guy was rebuilding his Toyota truck and he sent the block out to be re-bored. It came back and he checked it: block was bored incorrectly by .002". Turns out the shop he used allowed "the new guy" to bore it and he wasn't paying attention to something. They ended up having to buy the guy a whole new block.
    So be careful out there.
    Ray
    craze likes this.
  17. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Thanks a lot
    It makes things difficult as im interstate
    The engine went to the experts in australia
    Ill fly up in the next week or two to see it all first hand
    Thanks a lot
  18. wmuno
    wmuno Formula Junior
    512
    Wilmette, Illinois
    Bill Muno
    I think a leak-down test should be your first diagonist test. The VANOS system doesn't control the valve lift; it changes the valve timing. If there is very low compression when the engine is cold, the valves many not be completely closing. The hydraulic tappets should compensate for this, but IMO your problem is in the cylinder heads with the valve train.
    Qavion, RayJohns and craze like this.
  19. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    As Wmuno mentioned above, valves are always something to consider. If the valves were replaced (new seats, multi angle valve job, valves replaced, reground) but not properly lapped in, they can sometimes not seal well and leak. I'd be interested to know two things regarding the valves:
    1. Was anything done and if so, what
    2. Were they lapped in or just cut/ground - and what was the target seat width
    Stuff like VVTI and VANOS always makes me nervous. Simple motors usually are more reliable motors in my experience.
    Ray
  20. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,695
    Lake Villa IL
    Tight valve guides? (hanging valves at different temps)
  21. RayJohns
    RayJohns F1 Veteran
    7,808
    West Coast
    Ray
    Loose valve guides mainly would affect the seating of the valves on the seats (which would allow compression to escape). It would negatively affect performance, but usually not to the level Craze is experiencing. Whatever is going wrong with his motor has to be something fairly big, for example drastically wrong cam timing, some major blockage in the exhaust system or some failure in the ITB's opening, etc. Also, incorrectly set ignition timing could do it.
    Valve guides not being tight is like the icing on the cake. In this situation, we are missing the cake I think.
    Ray
  22. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,695
    Lake Villa IL
    Right, that's why I said tight valve guides, which would hold the valves open.
  23. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Funny that it starts and runs fine
    Only if rpm is increased it misfires and stalls and when turning over sounds like 0 comp
    Heads were just recoed but same parts fitted back
    So not sure what that entails
    Its been a horrible journey
    Engine was rebuilt as carbon plenum split and engine when lean and cracked a piston
    Opted to rebuilt and not fit 2nd hand motor as these engines are problematic
    Then covid etc
    Only did 2500km and engine span 2 bearings and oil was full of metal
    However when it happened i was driving hard, then did a few km cooldown
    Got fuel
    Restarted engine and it went into limp mode and had misfires
    We initially thought vanos pump exploded
    However all was fine
    Showed vanos codes
    Rebuilt motor again and new crank and be bearings and isotropic crank polish
    So that was deemed the best situation to ensure it lasts
    And now this
    Its been 3 yrs dealing with this crap due to covid etc and ive spent approx $35k au and dont have a running car!
    Thank you all
    Ill be sure to update
  24. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    The engine when rebuilt 1st was done by 3rd party and had bmw australia fit it
    Now since failed sent car to shop interstate that rebuilt engine originally
    Fuel pressure ok
    Vanos pressure ok
    It somehow seems related to a thermal situation?
    Ive had a few engines built over the years and it concerns me always they failed for various reasons within 2 yrs
    Nothing like original
    This is a quasi sump motor
    They suggested rods span due to oil surge or foreign object in oil
    This time we replaced oil cooler and lines as pm measure
  25. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,695
    Lake Villa IL
    You mentioned heads reconditioned. Did it get new guides and valves? I've seen this exact same thing (on other engines not S85) when the guides were not honed for clearance.
    (which would change depending on temp due to different thermal expansion of the valves and heads/guides)
