Any Bentley Continental Owners? | Page 2 | FerrariChat
Discussion in 'British' started by Dohangs, Mar 11, 2010.
  1. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    You can say that again. I always stayed away from dirt bikes but I thought since I'm older and more mature, I thought why not. Well big mistake. Got a CR250F and while its a blast, I have done a bunch of crazy things.
    Speaking of, a friend rolled a Honda Odyssey 4 wheeler this past week end and rolled it shattering his arm 5 places. Guess what he forgot to put on?
    Ouch!
  2. pingi3
    pingi3 Formula 3
    1,551
    Atlanta
    Quack
    I'm already paranoid with the IRS so probably not the wisest thing to register a 200K car as a business vehicle. I need less red flags when they review my returns. ;)
  3. craigbothwell
    craigbothwell Rookie
    Jan 1, 2011
    1
    Yikes !!! 60 to 90K and the cars are "running fine." I would certainly hope so. My volvo has 200K and is now just broken in.
  4. Brocki
    Brocki Rookie
    Jun 20, 2012
    1
    Have a 05 GT and had to replace the power steering, the rear brake light and now the tyre pressure sensor, gas temperatur sensor and parking sensor have to be replaced after the car went into limp mode while being in the garage for a flat tyre all after only 20.000 miles.
    Horrendous costs, very bad service from various official dealer maintenance shops and little knowledge on site. The sensors alone are £ 2,000.00 not to mention the rest.
    I would never buy one again.
  5. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Wow. Never heard of a cgt going into limp home because of a faulty tyre sensor.....maybe it's just on federal cars...what symbol came up on the DIP?
  6. raptorduck
    raptorduck Formula 3
    May 18, 2009
    1,166
    San Diego
    Mr. Raptorduck
    I had to replace all my tire sensors, but that did not cause any other failures on the car. It only meant I got an annoying message that my tire pressures. No big deal really. I am now over 40k miles after 5 years driving it and drove it just yesterday and it is still an amazing car. Running costs have been lower than with my Ferrari that I drove 1/10 as much.
  7. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Are you sure you paid £2000? Those sensors are around £140 each ( genuine), seems exessive...
  8. sammyinla
    sammyinla Rookie
    Feb 8, 2014
    1
    I have an 06 Continental GT and I have the EXACT same problem. I have no idea how to fix this. Every time I have checked, the brake lights all seem to work but I get the dash warning light (check brake lights) about 50% of the time and sometimes it goes away completely after I drive for a while and sometimes the reminder light on the dash stays there. Any ideas anyone?
  9. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    Pull the bulb out of the warning light.
  10. aleventhal
    aleventhal Formula Junior
    Jan 11, 2005
    661
    Sparks, MD
    Alexander Leventhal
    This is a well known problem with the early style 3rd brake light, which is susceptible to moisture intrusion. The answer is to replace it with the new style that addresses the issue. Any Bentley dealer or knowledgeable independent will be fully aware of this and able to replace the 3rd brake light in a few hours. There IS a technique to do so WITHOUT removing the rear windscreen. No biggie, actually.
    Alex
  11. aleventhal
    Jan 11, 2005
    661
    Sparks, MD
    Alexander Leventhal
    Even better, aftermarket but functionally identical sensors are widely available for $140 for a set of *4*. I know this for a fact as I just bought a set for the winter wheels for my CGT (which I love). I bought mine from OEM Wheels, LLC, IIRC.
    Alex
  12. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,778
    houston/geneva
    Ross
    Does anybody have any experience with the flying spur in snow? Does it really behave as well as they claim? Does the 4 wheel drive work?
  13. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,808
    SoCal
    Edward
    If it snows in Socal, I'll let you know :)
  14. aleventhal
    Jan 11, 2005
    661
    Sparks, MD
    Alexander Leventhal
    Yes, it really works. Bentley sells a winter wheel and tire package for the GT and Spur, which you'll want. With 4 snow tires, it's a tank. I use my CGT to commute in and out of NYC from Dutchess County. With 4 snows it's as capable as anything on the road.
    Alex
  15. ross
    Mar 25, 2002
    37,778
    houston/geneva
    Ross
    thanks alex.
    i guess its the same 4 wheel drive system as audi and porsche, so it must work reasonably well. do you have a separate set of rims for the winter tires?
  16. absent
    absent F1 Veteran
    Nov 2, 2003
    8,810
    illinois
    mark k.
    My wife had one for 2 years as daily/family car (Chicago).
    Had Winter tires (always put them on all my cars,should be criminal not to have them in snowy climate) and that car was unstoppable no matter how bad the weather was.
  17. aleventhal
    Jan 11, 2005
    661
    Sparks, MD
    Alexander Leventhal
    Yes, I have a second set of 19" rims specifically sold by Bentley for winter tires (they are narrower - 19x7.5). That said, you could easily buy Phaeton rims from TireRack for this purpose if you wished - same wheels.
  18. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Great car in the snow/slush/ice! Use the Blizzak LM60 on both the GT and GTC, with the car handing like an Audi/Subie in deep snow only *far* better. As others have suggested, use another set of rims for winter tires as you can get Bentley rims for under $1k/set in the 19" size if you keep checking eBay. Reliability is very good other than few normal niggles, which are all well-known. Guys on the 6Speed forum have an abundance of info. And yes, far lower operating costs than a Ferrari and it gets driven quite a bit as the GTC is my daily driver 24/7/365.
  19. DLPmercutio1942
    Sep 2, 2015
    1
    Purchased Bentley GT new 2006. Always maintained by Bentley dealership. Repeated tire failures. Occasionally immediately after service which did not find problems. Always blamed on need for alignment. Get all new tires and start over. Then new tires fail again in the same manner. Have gone through 3-4 sets in this way. Now -- air suspension failure. Blamed on long history of lack of maintenance. BY THE SAME DEALERSHIP which has always maintained.
    Great engine /drivetrain. Tires suspension -- not so much.
  20. Gene G
    Gene G Karting
    Jul 13, 2015
    68
    Saint Johns Fl.
    Gene
    #45 Gene G, Oct 2, 2015
    I have a 08 Bentley Conentinal GT Speed and haven't had any problems with it. It is beautiful. It is Bronze with a coniac and burnt oak interior. Fit and finish of it is to a Mercedes as a Mercedes is to a Chevrolet.
    George Vosburgh likes this.
  21. GuyIncognito
    99,002
    beautiful color!
  22. Townshend
    Townshend F1 Veteran
    6,677
    Chicago
    Walter
    Gorgeous! Have you had any seat time or owned a base GT? I'm in the market for an 09/10 and debating between Speed and Base.
  23. Iadvise
    Iadvise Karting
    Mar 5, 2013
    50
    The Speed is spectacular. The throatiness of the car coupled with the space and luxury is hard to find better.
    I am considering a 2015 flying spur V8 as a daily driver...
  24. Jo Sta7
    Jo Sta7 F1 Veteran
    5,711
    Scottsdale/Pittsburgh
    Jon
    #49 Jo Sta7, Dec 4, 2015
    My '12 Conti GT. Sorry for the rotated view I can't seem to upload my pics such that they post normal. Is there a trick I'm missing?
  25. kdf398
    kdf398 Formula Junior
    490
    Pasadena
    Keith
    Looks good from any angle!
