Another Garage Lift Question - 2 cars on 4 posts? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by rockminster, Nov 27, 2012.
  1. rockminster
    rockminster Formula Junior
    874
    Lake Tahoe
    I could use some help prior to pulling the trigger on a garage lift. I want to put 2 lifts into a new construction garage that will have a double door. Bendpak has a setup that allow me to lift two cars with only 4 posts (instead of 8). Of course the primary advantage to this is fewer posts obstructing the garage.
    The biggest disadvantage I see is that I need to move both lower cars to get either upper car out.
    Does anyone have experience with this setup? Would appreciate any feedback - pro or con.
  2. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,383
    ESP
    Bas
    I'd rather sacrifice a little extra space than the inconvenience of moving 2 cars constantly to try and get to the third...
  3. SrfCity
    SrfCity F1 World Champ
    #3 SrfCity, Nov 27, 2012
    +1 If you were to measure two separate lifts side by side vs a single one, how much space are you really saving? Plus the double lift could be tight getting in and out of the left car. Seems like a good idea in theory but hassle in reality, not unless the upper cars you don't plan to drive that much, if so why have them?
  4. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    #4 up4speed, Nov 27, 2012
    I would go with 2 seperate, for the above stated reasons.
    When I bought my lift, I was down to a decision between the BendPak (I definitely liked the looks of the blue BendPak better) and the Direct Lift from Greg Smith Equipment. They each had their own benefits, but I wound up with the Direct Lift. The model I got was longer and wider, higher lifting capacity and had more options. Also, very important, it was a "certified" lift (so was the bendPak). That was very important to me because I was going to be under the lift. At first I was looking at the Back Yard Buddy, but did not even consider it after I realized that it wasn't certified. The certification requires it to have a few things such as a double lock system, a valve that lets it drop slowly if there is a failure with the hydraulic hose, the ability to carry 1.5X more than it's rated capacity, etc. All that doesn't mean that the other lifts are not safe, but I felt more comfortable having an independent agency certifying it.
    Good luck with whatever you pick, I have to say, it's one of the best things that I have bought for myself!
    P.S.- Don't forget to order the 2 rolling jacks for it. They are expensive, but well worth it. That way you can lift the whole car off of the ramps so you can do tire, brake, and suspension work.
    Here is the site for the ALI that certifies the lift. Not all models from a manufacturer are certified. You can look here if you want to make sure that the model you are looking at, is certified:
    http://www.ali-directory.org/ali/ali2.nsf/Multi-Post%20Runway%20Lifts/by%20Manufacturer?OpenView&Start=1&Count=1000&Collapse=8.2#8.2
  5. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    why not get a 4post and a 2post. Both will store 2 cars one above the other,but a 2post is much more versitile to use for service.
  6. Keith Imbriglio
    Keith Imbriglio Karting
    Jun 16, 2008
    175
    Western MA USA
    Keith Imbriglio
    #6 Keith Imbriglio, Nov 27, 2012
    +1
    I find it a pain moving one car never mind two. Also if you wanted to use it for servicing a vehicle it wouldn't be very user friendly.
    Here is my setup.
  7. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    great idea, its what I have BUT you do not want to store a car on a 2-post, its pretty hard on the suspension. I got the impression the op wanted to use it as storage.
  8. henryenzo
    henryenzo Karting
    Jan 16, 2012
    175
    Agree. I have 2 , 4 post lifts, but I would NEVER store a car on a 2 post lift.
    2 posts are very useful, however--just not for storage
  9. rockminster
    874
    Lake Tahoe
    The lifts are primarily for storage but it would be nice to be able to do wheel swaps and some detailing on the lift.
    The comments about the hassle of moving the cars is very helpful. I didn't think a lot about the logistics of having to maneuver 4 cars in what is a somewhat confined area by the new garage.
  10. thedoc
    thedoc Formula 3
    May 27, 2009
    2,159
    I have 2 four posters side by side and the extra 4 posts go almost unnoticed really
    Gary
    Espada
    8394
  11. Electron Mike
    Electron Mike Rookie
    Oct 8, 2004
    8
    I have been looking at the same lift as due to the width of my garage I don't have room for two of the extra wide four post lifts. The advantages of the two car on four posts for me is that two of the four ramps are adjustable to fit wider tracks, and there are no posts in the middle for the cars parked underneath to contend with.
    I have to agree with the others though, if you have the room for the two extra wide lifts (if needed) it's probably easier to go that route.
  12. Alcav5
    Alcav5 F1 Rookie
    4,067
    Scarsdale, NY
    Al
    If in your budget go custom. I used Park Plus lift system. Custom designed to fit my double garage. 4 posts in the corners out of the way, 2 separate lifts using chains.
    If interested I'll post a pic when I get to my desk top in the morning.
  13. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    Not a good idea to store a car on a two post. You can have suspension problems... I did to my Hot Rod, for one winter... I wouldn't keep my Ferrari for long time with her legs hanging.
    I have two four posts for storage and one two post for service.
  14. Electron Mike
    Oct 8, 2004
    8
    Interesting, I wasn't aware there were custom designed lifts available. Pictures and more information would be great!
  15. strongx
    strongx Karting
    Mar 20, 2009
    166
    Utah
    Rock Thompson
    #15 strongx, Dec 1, 2012
    I have a two post lift and I use it a lot for storage, but with some wheel-engaging adapters that I made, so the suspension doesn't hang. There are a few versions around that you can buy, but I made my own because commercial ones are pretty ugly and heavy and I made mine to fit sports car tires. I did NOT make them myself to save money. Considering the design time, materials (aerospace aluminum, anodized, of course) and that I hijacked an otherwise productive CNC horizontal machining center they probably cost half as much as my 993... But I try not to think about that.
    They are my preferred way to lift a car and I only change to lift by the frame if I need to take a tire off. It makes removing F430 under trays (which surround the rear frame lift points) much nicer than the usual methods.
  16. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    Rock, that is so ridiculous it is awesome and vice versa. I love when someone overdoes it to point of sheer insanity in the process of creating a solution so elegant it makes zero commercial sense.
    If I needed climbing gear, I know where I would look.
  17. wlanast
    wlanast Formula 3
    Jan 9, 2007
    1,178
    Santa Ana,California
    William
    #17 wlanast, Dec 2, 2012
    a poster earlier mentioned having a certified lift. I piece of paper does not assure safety, construction material, engineering, and construction methods along with rigorous in house testing does.
    Safety was my number one priority, so I did as much research, spoke with as many engineers of manufacturors of the different lifts as it took until I was satisfied that gaining extra space wasn't going to put my loved ones, or my cars secondarily, at risk. It is also a comfort to deal with an American company using American steel, makes them accountable if they hope to stay in business.
    I chose 2, 4 post lifts, staggered so the posts at the center made the narrowest profile possible.
    Considerations when using a 2 car, 4 post lift:
    - the cars on the lift necessarily are parked closer to each other than on the ground making opening doors next a possible problem (unless you always park on face in, the other face out so the driver's doors open out toward the walls)
    - weight restriction; I have SUV's that occassionally I want to store or work on on the lift
    - more restrictive positioning: easier to move each independently than one larger footprint that is more restrictive.
    - lastly, after 5 years of use, I have found that repositioning one car below is time consuming enough, but having to move two every time would get old quickly.
  18. Electron Mike
    Oct 8, 2004
    8
    Nice setup! Can you share the dimensions of your garage and the type of lifts you have? Seems like a good option to overlap them a bit as you did if possible.
  19. wlanast
    wlanast Formula 3
    Jan 9, 2007
    1,178
    William
    #19 wlanast, Dec 10, 2012
    Hi Mike,
    Garage dimensions: 20' wide, 22' deep, 16' garage door opening.
    Lifts: over height (84" clearance at top lock), extra wide (9' between posts)
    Backyard Buddy, 220v (custom ordered black powder coat finish, didn't like the stock red) http://www.backyardbuddy.com/automotive-lifts/car-lifts-7000-pound-4-post/
    Accessories: casters, sliding jack platform, extra drip trays
    In the link, the one I have is the "7,000lb. Over Height 4 post." It should be the third lift down on the page that I linked.
    Since I have a modestly sized garage, needed more space but was restricted from adding additional garages on to the house for aesthetic and logistical reasons (not to mention it was very expensive for not a huge improvement.) As tight as the garage is, I have an unusually high, open ceiling ( lowest at front of garage at 11', 17' at center, 14' in the back)
    The casters are fantastic, you can even move the lifts/clean the floor under them with a car still on it. Jack platform comes in very handy, easy to remove wheels and still have the car on the lift and safe.
    With the collar-over-post design, which is very strong and reliable, there is no need to bolt the lifts down. From an engineering perspective, the lift is designed so that in the event of a significant earthquake, the lift will "walk" rather than possibly shake the lifted car off the ramps. Living in seismically active SoCal, earthquake safety was a big concern. I am confident my house would come down in huge earthquake, but my lifts would be left standing.
    Lastly, keep in mind under height clearance if the lift will be close to a door. In my case, the house is one step higher than the garage, and, since most people look down because they are stepping down into the garage, it is possible they could run right into the ramp with their head if it was lower. In my case, anyone 6'7" or under will not have to duck when exiting the house into the garage. But don't only consider the underheight clearance for the car parked underneath, but for ease of use as you walk in and out of the garage.
    Hope that helps.
    W
  20. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    Absolutely!!! :D
  21. SCantera
    SCantera F1 Veteran
    5,830
    Living Falls NC
    William,
    I like the way you have a staggered post set-up to fit into a tight width garage. I am designing a home w/ a 4 car garage and wondered how to put 2 lifts side by side w/o pinching the other half of the garage.
    I have 2 Backyard Buddys....one in FL that has the extra ht and length. In NC garage I ordered a std height as the taller lift has ramps 1' longer which I could not afford the room. I feel as safe as can be operating and working under the car with the BYB. I also use the rolling jack cart to pull wheels regularly (wire wheels need to be cleaned from both sides). Having drip trays is a must under vintage cars that leak everything. I don't mind the red lift....my cabinets are pretty close in shade so it's a clean look.
    thanks for the tip
  22. wlanast
    wlanast Formula 3
    Jan 9, 2007
    1,178
    William
    Forgot to add my thumbs up to Stongx and the amazing lift set up. Very nice.
    As much as I measured and preplanned, there is no substitute for moving the lifts around until you optimize your space. Those casters are invaluable for that alone. Not easy to move those 2,000+ lb lifts around, but with the casters it couldn't be easier.
  23. dhwflash
    dhwflash Rookie
    Jun 8, 2014
    1
    Do you have drawings for the wheel adapters that you had machined? Would appreciate this to consider making myself a set. Thanks.
