430 - Angry Pizza Error Code on Tach Display??? | FerrariChat
430 Angry Pizza Error Code on Tach Display???
Discussion in '360/430' started by Kruegmeister, Aug 1, 2020.
  1. Kruegmeister
    Kruegmeister Formula Junior
    466
    Michigan
    Kruegmeister
  2. Kruegmeister
    466
    Michigan
    Kruegmeister
    Maybe if I RTFM....
    Answering my own Question. It is:
    Driving mode switch failure
    Indicates a failure of one or more systems that select the driving mode.
    Will Try just Cycling the Switch to see if it goes away...
    tfos750 likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,563
    Central NJ
    Dominick
    It is a error when the mamertino system fails to get a signal from the various sensors ..wheel, ediff, gearbox brake etc
    Tell us a little more about when it happened .. what was going on before that ..
    Sometimes a weak battery in a start can cause it as well
    Sent from my moto g(7) using Tapatalk
    Kruegmeister likes this.
  4. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    5,687
    I think it's telling you to go grab some pizza......It is an Italian car.
    I had a spaghetti warning one time.....
    Robb and Kruegmeister like this.
  5. crazy canuck
    crazy canuck Formula Junior
    Jun 20, 2005
    426
    West Coast
    sometimes this happens as a function of a low battery.
    These cars do not like lower voltages and can light up and throw all kinds of weird messages asa result of a low battery
    Worth a look
    rudkinjc and Kruegmeister like this.
  6. Kruegmeister
    466
    Michigan
    Kruegmeister
    Update for anyone else whom might encounter this.
    It could have been low Battery caused
    Following events:
    1. I had an error on my charger shortly before
    2. Started up weird before a Ferrari Club Event & Drove weird so we flipped around & took the 355 instead
    3. Next time ran fine but got Pizza Error
    4. Posted this Thread
    5. Switched off Battery for 30 seconds & put on previously "rebooted" charger
    6. Drove to Polish Village Cafe & all was perfect in every mode.
    Thanks everyone for Suggestions/Comments
    crazy canuck, brogenville and flash32 like this.
