aluminum paint for engine | FerrariChat
Discussion in '308/328' started by Newman, Apr 5, 2007.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,330
    Canada
    Newman
    Anyone have any luck simulating the natural look of the 308 engine with paint? Ive scrubbed and scrubbed and cant get the finish as nice as I want. Any suggestions or pics of some engines that have been painted that dont look like a fake model engine?
  2. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,433
    wisconsin/chicago
    bo
    Sandblast?
  3. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I don't think so, not unless you have the entire engine block apart and are able to thoroughly wash it down before reassembling. Otherwise, you will end up with sand/media in parts of the engine where it doesn't belong, which ain't good for internal engine parts.
    Did you use any chemicals or just soap and water? When I cleaned up my engine over the winter, I used some citrus cleaner, as well as brake cleaner, to get the grease off. They did a pretty good job of making the aluminum block clean up nicely. And remember, with the engine in the car, you see very little of the actual engine block or head. All that stuff is covered up or buried down low and can't be seen. More important you make the valve covers, timing belt covers and air intake look good. Those are the things you really see.
  4. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    #4 FasterIsBetter, Apr 5, 2007
  5. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Looks good Steve.
    BTW what kind of shocks you got in the back?
    Sorry for the hijack.:)
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    There are some aerosol paints that do a good job of simulating the "cast aluminum" look (also "cast iron"). I think PlastiKote makes some. You can get some from Eastwood as well.
    The problems are:
    Applying them to an assembled/installed engine requires a lot of cleaning and masking to do a good job.
    None are fuel-proof. they will come off eventually and need to be redone.
    I have had good success with painting aluminum engines but the 3 little words on the can mean everything "Prepare the Surface". Bead blasting (if you can) and degreasing everything with carb-cleaner works well.
    I have found that usually it is not necessary to use "engine enamel" on many parts (limited choice of colors and finish) but I will use it if it suits the application.
  7. 308 GTB
    308 GTB F1 World Champ
    11,650
    New Jersey
    Barry Wolinsky
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Nice job. No need to paint that one.
    Red wrinkle looks good, what brand?
  9. Newman
    Dec 26, 2001
    14,330
    Canada
    Newman
    What ever happened to Magoo anyway?
    Thanks for the pic Steve, it looks nice. Ii was also debating the painted cam cover option as well, still undecided. I glass bead blasted the covers, timing covers, diff cover and so on and after posting the question about the paint I took another shot at cleaning the block and heads up. I used this rim cleaning solution from work (in the detail department) that is a mild acid, smells like amonia almost. The block actually came up really nice so I may not paint after all. The engine has the heads on it, seperated from the gearbox. I cant go the blast route for that reason and the engine is fresh anyway, no need to take it apart again.
    Ill post some pics once I get it as clean as I can. I have all the hardware plated and waiting to go back on then in the car she goes.
  10. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    I have no idea. We used to keep in touch, but it's been years since I last heard from him. I miss him.
    I painted my valve covers, timing belt covers and other sundry parts of the engine (not the heads or the block) with Canadian Tire's Motomaster "High Heat Manifold Paint", aluminum #47-7532-2. Has a very nice, bright sheen and has held up very well for the past six years. Still looks bright.
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Rub-n-buff works pretty well if the metal is clean, but it's not a true natural look. What I use to clean the raw aluminum is a slurry of powdered cleanser and water. Does a fantastic job of taking off the surface oxidation...
    see http://www.fca-se.org/conc_8.htm
  12. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Phosphoric acid.
    You can get it in a spray bottle from a commercial automotive paint distributor like Finishmaster's. It comes in 1qt spray bottles. Feels soapy to touch. Don't get it in your eyes, and wash what ever you spray it on thoroughly after applying.
    DO NOT SPRAY FABRIC HOSES !!! It will eat them very quickly. If you get overspray on a fabric covered hose, rinse it off immediately.
    DO NOT SPRAY ON PAINTED SURFACESS !!! It will turn shiny paint very dull very quickly. So be VERY CAREFUL OF OVERSPRAY.
    In fact, I'd suggest spraying it onto a rag and using the rag to wipe the surface instead. And make sure you're not upwind of your car while spraying it on the rag !
    After you've applied it to the aluminum and successfully removed the oxidation and cleaned the surface; You can use a small wire brush or a brush on a dremel, or an air gun, to gently buff the aluminum.
    I was first introduced to phosphoric acid when I was a kid. My dad owned a hand-crafted jewelry store, and we used it to gently remove oxidation (often intentionally applied with liver of sulphur) from various metals, like copper, brass, silver, and gold.
    It is very gentle. But it can be corrosive if left on too long. So be very careful.
    Also, it is the active ingrediant in most "aluminum mag cleaners". That's why they say, "DO NO USE ON PAINTED SURFACES". It will damage a paint job.
    Discalaimer: DO THIS AT YOUR OWN RISK - However, I regularly clean my Alfa engine this way. I spray liberally and then rinse it off within a minute or two. And I've learned to avoid :rolleyes: spraying the fabric hoses too! But the paint (which I'm not too worried about) in the interior of the engine bay is jsut fine. A little dull perhaps, but I can't really tell if the phosphoric acid bears any of the responsibility for that. However, I did ruin some nicely painted mags once. So the warning is apt!
    I've also used it to clean the (now empty) engine bay of my GT4, in preparation for re-installing the engine when I get the gearbox back (hopefully) next week. Yippieee!!!
    And yes, the paint on the frame is all still there. :D
  13. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    So do I, Peter. Both of you helped me greatly during my first few months of ownership.
    Thank you, Mike, for reminding me that your concours tips are posted on your FCA-SE site. Now I needn't refer back to my FCA Newsletters.
    Barry
  14. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    It was a fun time in those early days of Ferrarichat. Remember also Ed Gault? I heard from him a couple of years ago too...
    Sorry Paul for straying off-topic here! ;)
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,065
    Dumpster Fire #31
    SMG
    I used dupli-color high temp DE1615 aluminum paint. looks like fresh cast aluminum and has held up quite well on the diff case and throttle body. prep work is a must though, the oxidation was just too much even after cleaning, so i went with the paint, looks brand new!
  16. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    I use the Wurth silver spray paint.
  17. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    POR-15 has a great line of high temp paints too.
    www.por15.com
  18. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    They were on the car when I got it. I'm told they are Aldan shocks with uprated coil springs. They are adjustable for both shock rate and rebound.
    The wrinkle paint is ATH (?? AHT??). Got it from a local speed shop in my area. I've found that the trick with wrinkle paint is to clean the surfaces really, really well, and make sure that the parts, the paint cans and the air temperature are all high enough. Has to be over 72 deg. F or the stuff won't wrinkle correctly. Also, you have to let the stuff dry for a good long time before working with the parts. A few days at least. A week is even better.
  19. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    Sure do! Miss him too.
    Me too.
