Aluminum frame vs Carbon | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by amenasce, Oct 20, 2009.
  1. amenasce
    34,169
    Joe Mansion
    Why is Ferrari still using aluminum for their chassis vs a carbon fiber tub which should be lighter, more rigid and safer.
    Is it cost related ? But then Mclaren will be selling their new car for around the same $$ with more HP and a carbon tub and probably less volume.
  2. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Because Ferrari's are raced in GT2/Alms/Grand Am where carbon tubs are not legal.
  3. amenasce
    34,169
    Joe Mansion
    Ahhh..simple as that !
    Any idea why Carbon tubs are illegal in those racing series ? Too expensive ?
  4. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Basically yes.
  5. BigTex
    79,321
    Houston, Texas
    Bubba
    The aluminum as used in the current chassis design is repairable, based upon nodes that are cast, capturing the extrusions...so after a 'mishap' you can fix it..
    Ferrari of Houston has a Certified Shop with all the jigs...
    As Mr. G knows, if you crack a carbon fiber component, it's basically "back to the oven" to make a new one.....analyzing the damage can be done, but it's not an exact science so they are rarely repaired, but instead replaced....
    From what I understand......
    Old Steel Frame Guy...
    :D :D :D
    Nicky_Santoro likes this.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    What about kevlar, has anybody thought of that?
  7. TheMayor
    104,768
    Vegas baby
    Interesting....a great and concise answer.
  8. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    Same deal as carbon fiber. The use of fibers, whether they be carbon or kevlar or fiberglass, in a composite material is the same. The fibers are embedded in a resin material, which gives it form and rigidity. The strength comes from the fibers. Whenever a composite is damaged, repair is difficult and expensive. When the composite is used structurally (as in a tub), it's "back to the oven" as BigTex says.
  9. Rifledriver
    36,750
    F40.
    Was great until carbon came along.
  10. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Many of the cars use fiberglass for nose and tail. It's very easy to repair. One of the benefits. Guess how I know?
  11. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    IMO, it's all about cost. A carbon tub would make the price of the car skyrocket. Carrera GT is about as cheap as it can get and still retain the other performance features. Production of composite parts is also relatively slow, and most manufacturers already have plenty of knowledge and equipment for working with metals.
  12. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,241
    Worcester, England
    Phill J
    this very question was put to the head of the 458 project because the new McLaren road car will use a carbonfibre tub.
    His reply was that due to the numbers that the 458 will be built in compared to the McLaren, it made more sense to use an aluminium frame for financial reasons. He also mentioned that for a more "mass market" car it made more sense for everyday use.
  13. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I'm not sure how well carbon fiber holds up in terms of fatigue over many years of real world road use. Obviously can be made as strong as required in terms of absolute strength. Probably not a problem, but just a question I've had that I haven't investigated.
  14. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,241
    Worcester, England
    Phill J
    There was an interview in one of the car magazines over here (possibly Top Gear magazine).
    I'll see if I can find it again in the shops.
  15. SonomaRik
    SonomaRik F1 Veteran
    #15 SonomaRik, Oct 20, 2009
    I also understand the 456 hood was a composite of Kevlar and CF.
  16. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    Only the 456M IIRC.
  17. SonomaRik
    I know my hood is CF, just wondering on the Kevlar combined. FofSF mentioned the under side casting number referring to Kevlar. Still trying to google it all.
    rik
  18. TudorMiron
    TudorMiron Rookie
    Jan 1, 2007
    40
    #18 TudorMiron, Oct 21, 2009
    There's nothing to do with racing in FIA GT/ALMS/ACO. There are cars with carbon tub there - their very own MC12 for instance. Mosler in lower class (GT3/4) and others. They still use steel roll cage to comply with FIA regulations. With steel space frame made to FIA spec one doesn’t need to get through FIA crash test homologation. So this reduces the cost of racing program considerably.
    In terms of mechanical properties – aluminum extrusions and castings have considerably lower ultimate strength, fatigue strength and specific stiffness than those made of carbon fiber/epoxy composite. At the same time alu density i.e. mass is higher than density of carbon fiber laminate.
    Alu still has its way in form of honeycomb used in sandwich panels core. As all know tubs are produced out of carbon/alu (sometimes nomex) honeycomb/carbon panels.
    Kevlar has considerably different set of mech. properties so it is used in different applications than carbon. Mainly due to high resistance to abrasion and great ballistic strength, in race cars it is used in bottom outer layers (subject to frequent contact with track surface) and wheel wells. Also 8 layers of cevlar are obligatory in FIA F1 chassis constraction (side walls) - in order to help prevent penetration of tub by broken suspension bits etc. There where tubs produced from mixed carbon/kevlar fabric (most known is first Lotus F1 "cut&fold" chassis). In simple terms kevlar is not used for structural/stiffness oriented reasons but used in specific areas of chassis for its specific properties.
    How ever, cost of producing chassis bonded/riveted/welded out of aluminum extrusions/castings is way lower when we talk about 360/430/458 production numbers.
    Is it better from engineering point of view? No way.
    Is it cheaper? Yes.
    Think about why almost all suspension/chassis parts where interchangeable in F360 anf F430? (One can verify it easily by looking up F parts catalog) – one answer. Lower cost.
    Thank You
    Ted
    brogenville and Nicky_Santoro like this.
  19. speedmoore
    speedmoore Formula 3
    Apr 15, 2003
    1,541
    Austin, Texas
    D Moore
    It may seem easy to repair external body panels and brackets and such. We do a lot of wet lay-up vacuum bag repair and custom part fabrication with our restoration and racing services. Carbon is a little more difficult that S or E glass but definately not as hard to work with as Kevlar. You also need a large autoclave to do tubs and components made of pre-preg composites.
    Repairing a tub is a whole different ball of wax and to repair one with extensive damage to original strength is not an easy task nor is it possible in many cases. Having the original mold and the big autoclave is paramount to repairing most which would mean sending back to the factory or simply getting a replacement tub.
    Heat is also a big factor for durability and fatigue and that is why you see little temperature gauge stickers all over an F1 at high heat areas (brakes, engine bay areas, suspension and other components close to exhaust or other heat generators like again brakes). The epoxy resins are designed for the high heat but over time (and not much on an F1 car) they have to be replaced.
    On what we call "vintage" race cars we see quite a bit of delamination of composite materials and components due to fatigue, heat and chemicals.
    But in all fairness we see a lot of fatigue and cracking in aluminum stress members too as well as corrosion. We are already seeing quite a bit of corrosion on the 360 frames especially where electrical grounds interface and speed up the process with anode/cathode reactions.
  20. LightGuy
    LightGuy Four Time F1 World Champ
    44,492
    Texas
    David
    Ferrari should have made the 458 in CF.
    With the speeds this car is sure to obtain and considering the "typical" client that buys the car new, safety becomes a responsibility of the factory.
    Step up Ferrari.
  21. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,387
    ESP
    Bas
    likely to do with the future IMO.
    In a couple of years cars need to average x miles per gallon more than they do with their current cars...lower weight cars use less petrol.
    That's my theory anyhow.
  22. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The MCC is not legal at Le Mans. Why?
  23. ztunelover
    ztunelover Formula Junior
    Oct 1, 2009
    641
    Calgary, AB
    Krish
    Who told you the mclaren is going to be cheaper or even the same price? Its going to be a rarer car and once you look at the MSRP its more expensive than the 458, or the lp560-4.
    Onto the subject, why the new Ferraris are still using aluminum instead of switching to carbon tubs, well first is expense, second is its difficulty to produce them in volume, as said before it takes time to properly manufacture carbon fibre tubs.
    Then we come to maintainence and repair. Replacement is expensive, and producing enough to supply for all the potential demands are going to be difficult to keep up with.
    Now regarding the carbon/alu composite used for tubs, I have a quick question if anyone knows what happened with pagani's research of the carbon/titanium composite tub? I was very interested to see what the result would be because I always thought other than titanium being an exotic and rare metal why not use that for the carbon composite. Anyone know what I'm talking about or am I crazy or something?
    And I honestly dont see any safety issue from using an aluminum frame for a 200mph car. Look at the Jaguar xj220. It hit near enzo top speed using an aluminum frame.
  24. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    There is also the financial investment Ferrari has in aluminum production/assembly facilities to consider.
  25. BigTex
    79,321
    Houston, Texas
    Bubba
    Aluminum recycles.......
