Aluminum cleaner on engine surfaces?
Discussion in '308/328' started by chairpilot, May 9, 2011.
  1. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    I'm going to search out what is the best method for cleaning/brightening the main aluminum engine surfaces. I'm using Engine Bright to clean off all the grime but it does not leave a nice new raw aluminum sheen. I do not want a polished (chrome) look, just a nice silver aluminum patina. Are there any best posts/threads on this to recommend?
    Thanks,
    Bob
  2. andy2175m4@yahoo.com
    andy2175m4@yahoo.com Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    what I found is that most manufacturers actually paint their aluminum engines with aluminum paint to get that nice even, shiny surface. You can't really get sand cast aluminum to have that nice shiny finish you are looking for without painting.
    I figured this out about 40 years ago when I used to work on Honda motorcycles, back in the 1970's. I was a bit surprised to find that, but that's how most engines are. If Ferrari does it differently, I would be surprised.
  3. stefnews
    stefnews Karting
    Nov 23, 2010
    81
    EU-Hungary, Budapest
    Hello
    I make it everytime with BERNER breake cleaner spray. 100% effect. Is not a cheapest method, but succesfull.
    Stefan
  4. thecarreaper
    thecarreaper F1 World Champ
    17,963
    Savannah
    brake cleaner is extremely toxic!
    Also, it can damage some plastics and rubber parts. Big fire hazard too. be careful!
    Simple Green diluted with warm water and a soft Scoth-brite pad do wonders and leave a brushed aluminum finish. Add a bit of Dawn soap to degrease further, but dawn does leave a residue.
  5. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    A trick I learned from the old airplane hobby is to use Scrubbing Bubbles (that bathroom spray cleaner). It is safe for aluminum and does a superb job cutting through oily grime. You might want to sneak a can from your wife's cleaning supplies.
  6. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    I did not make it clear. I'll have a few items off the car including the cam belt covers while doing the belts. So I have the opportunity to do something a bit more effective. The two photos show my rear bank cover AFTER two applications of Engine Brite cleaner AND a quick rub down with #0000 steel wool. Not very impressive. It looks as though the grime has imbedded itself into the metal. Maybe I should get these detached parts media blasted with something? If so what? And if that does it, should I seal the metal with some sort of durable heat resistant clear finish or leave it raw?
    Thanks,
    Bob
  7. BigTex
    79,321
    Houston, Texas
    Bubba
    I vote Simple Green as well.....but I never clean my engines, as carreaper points out LOTS of bad can happen, and very little good.....
  8. BigTex
    79,321
    Houston, Texas
    Bubba
    The natural alumimum of the timing chain covers CAN be greatly improved upon, take it to a motorcycle guy to 'work thru the grits" and you can get a mirror polished finish like the racing P-51s end up with.....I suppose the same would be true for the valve/cam covers but as we have touched on in other threads the casting for the smog pumps is not as nice as the front bank original one....more grainy....
  9. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    If the parts are off the car use a dilute solution of Sodium Hydroxide. This is what we use in the aviation industry to surface etch/clean aluminum for painting.
    Common source of Sodium Hydroxide is Draino and other drain cleaners.
    Clean the parts with a degreaser. Mix up the draino with water to a weak solution. You should see a slight foaming if its working. If it really starts foaming up, just rinse it with water to stop the action. Should only take a minute or less. Wash with soap and water after and you're done.
  10. WaltP
    WaltP Formula 3
    Nov 1, 2003
    1,512
    Cape Canaveral/Atlanta
    Walt P
    I have Sharkhide Metal Protectant for my truck box, they tell me it will stand up to engine heat. They also make polish and other products that may work well on out engines.??
    http://www.sharkhide.com/
  11. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    I picked up some Draino today. Just how weak a proportion are you talking (2:1, 5:1, 10:1, 50:1.....)?
  12. thecarreaper
    17,963
    Savannah
    no disrespect, but as an aircraft guy we are trained to never, never, never, never use any steel wool or steel brushes on aluminum.
    The steel fibers and flecks will and do embed themselves in the aluminum. I would bet that is what you see in the surface. Try blue scoth-brite pad and mag wheel polish in a small area with a orbital polisher or angle grinder. See if it works for you.
    Red scotch-brite will take off ALOT of metal in a hurry. Blue is safer to start with.
    be careful.
  13. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    None taken, guy. I had just tried steel wool on the back (inner) side and it did nothing. Could be the outer side was done by a PO with S-W which may explain the darkened look. I've got a blue & red scotch wheel that fits an angle grinder. I'll try them & the Draino solution tonight.
    Thanks,
    Bob
  14. Tony K
    Tony K Formula 3
    Jun 7, 2006
    1,772
    Tony K.
    Here is a very educational 5 and a half minutes:
    [ame]http://www.youtube.com/watch?v=cQV0cpIZkak[/ame]
    I don't know who this guy is, but I gave his video a thumbs up!
  15. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,559
    Land of Oz
    Gleggy
    #15 Gleggy, May 10, 2011
  16. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #16 Brian Harper, May 11, 2011
  17. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    After cleaning apply silver Rub & Buff available at craft stores. Hobby Lobby stocks it.
  18. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    I use an 80 grit buffer wheel on aluminum and bolts. It does not leave a finish as nice as the sand blasting shown in the pictures above, but it gets the job done. I avoid strong chemicals or the engine cleaners.
  19. Gleggy
    Gleggy Formula 3
    Sep 22, 2004
    1,559
    Land of Oz
    Gleggy
    #19 Gleggy, May 11, 2011
    The process Wayne uses is non abrasive, he can take the paint off a coke can without damage to the alloy. Some parts from the Boxer. Most of his work is with the more classic motor bike parts, but he tells me he makes an exception for Ferrari bits, he thinks he's funny.
  20. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    #20 doug328, May 11, 2011
    I'm sure there are lot of different ways to clean them. I used the engine bright to remove the grease and grime, then some small brass wire brushes (found at Ace Hardware) to shine up the surfaces a little, the brass is a lot softer then the steel wool and does not leave scratches, followed with a little Mothers Mag Polish. After the initial cleaning the only thing I do now is to wipe it down once in a while with a clean cloth.
  21. BigTex
    79,321
    Houston, Texas
    Bubba
    That's beautiful Gleggy!!!
  22. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
  23. pdf308
    pdf308 Formula Junior
    Dec 28, 2009
    278
    Chicago
    Paul
    Extreme Simple Green® Aircraft & Precision Cleaner
    Extreme Simple Green Aircraft & Precision Cleaner is a biodegradable, breakthrough water-based formula for cleaning engines, aircraft, vehicles and equipment. This product is safe for painted surfaces, gel coat, aluminum, carbon fiber and other composite materials, meeting Boeing Spec D6-17487P for general aircraft cleaning. This non-corrosive, low-foaming cleaner/ degreaser, cleans the toughest types of soil and rinses residue free.
  24. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    I think that glass beads may be pretty aggressive for DIY cosmetic cleaning of cast aluminum and I'd be concerned about residual abrasive dust absent a really thorough cleaning afterward. Commercial shops have the skill to use more aggressive media. There are milder blasting media like plastic beads, crushed walnut shell, corn cob that may not be as quick but will do no harm to soft aluminum.
  25. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    I wonder if that is soda blasting, not the kind to take paint off roads but the baking soda blasting using an airbrush.
