Alternator warning light came on | FerrariChat
Discussion in '308/328' started by flyngti, Oct 7, 2010.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    The weather has been good recently and I've been driving my 308 to work about once a week. Yesterday on the way home, the "G" warning light came on. This happened on the freeway at about 3500rpm. I brought the revs up to 4-5K, but the brightness of the light didn't seem to change. After a few minutes of changing rpm, the light eventually went out, flickered a little, then stayed off for the rest of the trip home.
    What's my car trying to tell me? Alternator and/or voltage regulator on the way out? When I start the engine, the light usually stays on until I blip the throttle a little. Every now and again when I start the engine, I need to bring the revs up to 3-4K to get the light to go out. When it goes out, it usually stays out at idle. This is the first time it's ever come on during driving.
    If I do need to replace the alternator, can someone confirm a cross reference? I've read an alternator from a 1980 Fiat will work but I'd like a confirmation for a '78 308 GTS.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    I had the same problem two years ago so I took it to our local alternator shop and found that I had bad diodes, they rebuilt the whole Alt, with new diodes, bearings and brushes for $100 No more lights coming on since
  3. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    Did your warning light come on and stay on, or was it intermittent?
  4. miketuason
    Feb 24, 2006
    15,761
    Cerritos, CA.
    It stays on until the rpm reaches about 2500rpm then goes off. The problem was I can drive my car all day and all night long but once you turn it off, it will not start back up, I always have to jump start the car everytime.
  5. Raricar
    Raricar Karting
    Jun 17, 2010
    246
    Greenwood Village CO
    Bill M
    #5 Raricar, Oct 7, 2010
    What is happening is the diodes in your alternator are going, there are six in the alternator that turn the AC output of the alternator to DC and charge the battery. When one or more go then the charge voltage is low and the system can't keep up. A voltage difference is created between the Alternator and the battery and the G lamp comes on, telling you your battery is failing or the alternator is not turning i.e. broken belt. There are several things that can cause diode failure, If there is a bad connection between the battery and the alternator, charging current will find an alternate route to flow to the battery, this over heats the diodes. A poor connection may be caused by corrosion or a broken battery cable. Diode overheating can happen when the alternator tries bring an undercharged battery up charge. This can cause excessive current that can overheat the diodes.
    Diodes can also be damaged when you try to jump start, as an large surge of power can toast some diodes, it doesn't happen all the time but if they are on the edge they may be damaged by continuous jump starts
    When you revved the engine and generated more voltage you charged the battery again and it lasted for a while but it will likely happen again and will continue to to get worse, as more diodes crash and burn. But its easy to repair. Just make sure when you put it back that all the connections are good the the battery is good and will hold a charge at about 12.5 volts. It also a good time to put in a new voltage regulator even if yours is good now and maybe some new bearings.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,302
    First thing is to rule out the easy stuff & make sure its not just a loose belt (though the behaviour seems a bit odd for that).
    It should just be a Bosch alternator so any Bosch specialist should be able to rebuild it - just don't tell 'em what its from ;-)
  7. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I just had the alternator from my '86 328 rebuilt at a local Bosch alternator shop. The whole thing, including new bearings and shaft, complete rebuild, came back looking like new, cost $140. These are plain vanilla Bosch alternators, nothing "Ferrari" about them.
  8. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    Thanks for all the tips. I doubt that's it's as simple as a loose belt because my water temp has been pretty consistent, even in traffic.
    I'm dreading having to dig back in there again because it's such a PITA getting to the alternator. I had to loosen it for a timing belt replacement last year and access was so tight I ended up removing the right fuel tank. On the '78, the mounting bolt head faces inward and was nearly impossible to reach. I did myself a favor though on reassembly and reversed the mounting bolt. Now the bolt head faces out so I should actually be able to reach it.
  9. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    You can definitely remove the alternator on the '78 with the gas tank in place. I did it on my former '78 GTS, no problem. Yes, it's a bit tight getting at things, and you might have to remove the stainless heat shield, but you can get it out. It is much easier if you can get the car up in the air, and if you have someone help you so you don't have to twist yourself like a pretzel to get the wrenches where you need them. IIRC, I might have had to move the coolant pipe that runs through there as well to get it out and back in. Can't remember if we were able to drop it out the bottom or not.
    Note of caution: If you are jacking the car up to do this, please, please, please be sure to use really good jack stands and wheel chocks. We don't want to have to nominate you for a Darwin Award.
  10. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    the red alternator light on my 78 308 just came on when driving. when parked and with the engine running; at idle the light is very dim. when i rev it up, the light gets much brighter. i guess it is time to yank the alternator unless someone can think of something else..
    all cables to and from the battery have been cleaned, tightened and i replaced the battery ground cable to the frame and cleaned teh corrosion there. the battery is relatively new and i have never had a problem storing and running the car without the use of a trickle charger....
    thanks in advance
  11. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,302
    1st thing to do is measure the voltage across the battery with the engine off and then with it running. It should be around 12V & around 14V. If its not then you may have an issue.
    The symptoms you have suggest the alternator is not charging the battery. That can only be a bad belt, a bad connection or a bad regulator/alternator.
  12. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    thanks Ian, i will measure the battery voltage with car running and not. i suspect the diodes in the rectifier circuit of the alternator. the belt is on nice and snug, and cables are new.
  13. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i measured battery voltage at the battery terminals
    12.00 volts when car is off
    13.65 volts with car idling
    so, any thoughts as to why my generator light stays lit all the time while driving?. incidentally, i drove the car 30 minutes with the light on, you would think if it was charging a deadish battery, the light would eventually go off - or is that not how it works.
  14. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,302
    Well, clearly those numbers indicate its charging - odd!
    Needs someone with better understanding of the charging system than me I'm afraid.
  15. thecarreaper
    thecarreaper F1 World Champ
    17,958
    Savannah
    bad cell in the battery. Replace the battery ASAP or it will damage your alternator and can damage the charging circuit.
  16. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    dead cell in battery, thats intersting. thanks for the tip.
    i could get the battery checked for that - correct?
    and i should add alternator rebuild to the list - couldnt hurt..
  17. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    Most auto parts stores should be able to test for a bad cell in the battery. As for the alternator, unless you know it's bad, you should leave it alone. I mean, you can pull it if you're feeling the need to have a painful and frustrating experience :)
  18. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i hear ya on pulling the alternator. it sure does look like a PITA.
    thanks for alll the help, i wil keep you all posted.
  19. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,302
    #19 Iain, May 4, 2011
    FWIW I just had the alt on my 328 rebuilt (because the engine was out so it would have been daft not to).
    There was a little play in the bearings (but you could check that without removing it) and the brushes were less than 25% worn after 37K miles. Again I replaced the reg pack (which includes the brushes) because it was cheap & it would have been silly not to - but it wasn't strictly necessary.
    Unless you need to pull it because its not working or the bearings feel really bad, I wouldn't bother.
    FWIW when tested my Alternator is kicking out 14.6V & well over 100 amps (spec 85) - it pegged the gauge on the test bench. :)
  20. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    battery checked out fine, 799 amps from a 800 amp battery.
    looks like i get to R/R the alternator.
  21. BigTex
    79,321
    Houston, Texas
    Bubba
    It's a piece of cake..the rear heat shield bolts are a little hard to get to.....
    Take the mounting bracket and the water coolant tube out of your way, disconnect the charging wire off the stud and out it comes!
    If it doesn't clear the frame, your motor mounts have 'gone soft"....unbolt them and jack the motor to make enough room to get it out....
  22. BigTex
    79,321
    Houston, Texas
    Bubba
    Pay attention to the rubber insulator on that stud, and the tubing protection of the wire going back to the starter soleniod (and from there back to the battery in front).
    IF you accidentally ground out that wire against something on re-installation, the full current of the battery cable goes thru that #8 wire, and it doesn't LIKE it!!
    In my case, that tube had filled with leaking oil and it made quite the smoke cloud!!
    Until the wire vaporized.....
  23. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    thanks Bubba, i will do that. i probably would have left that heat shield in place had you not chimed in. oh, and i yanked the ac compressor last year - so i hope it is easier with that out of the way.
    now, where did i put that judas priest CD; since i will be bangin my knuckles, i may as well be bangin my head!!
    i will keep youse posted on the progress.
  24. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    Geez, you make it sound so easy! It's only easy IF the bolts are facing the correct direction for removal.
  25. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,236
    Snohomish, WA
    Eric L
    I think you have a '78 too, right? I don't know if there are differences between the US and Euro, but here's what challenges I faced on my US '78:
    1) Upper mounting nut on the alternator adjuster is facing the center of the car. The bolt comes in from the outside and is captive in a hex depression on the alternator arm. This means you need to contort your arm to even reach the nut, much less get enough leverage to turn it.
    2) The lower pivot bolt comes in from the center of the car and the nut is easily accessible from the outside. The problem is that when you try to slide the bolt out, it hits the dipstick tube.
    I just couldn't get the top nut loose so I ended up pulling the passenger's side tank. This allowed enough access to get reach behind the alternator to loosen the nut. You may have better luck than I did though. For the lower nut, I ended up removing the alternator mounting bracket from the engine block since I couldn't get the long bolt out.
    Once removed, you can set the alternator on the exhaust and spin it around to unbolt the rear heat shield and the wiring connectors.
    Here's some detail and photos:
    http://f308.blogspot.com/2010/10/hurrah-alternator-is-out.html
