Alternator Rebuild Recommendation | FerrariChat
Discussion in '308/328' started by gte619n, May 29, 2021.
  1. gte619n
    gte619n Karting
    159
    Atlanta, GA
    Evan Ruff
    Hey guys,
    The car constantly had a flat battery, the tach would bounce all around and the car would occasionally just stall out. I don't believe the alternator had ever been rebuilt and I never quite got over ~10.7V at the battery. After going through all the threads here I finally pulled the alternator out. The tip on obstruction wrenches is CRITICAL. My wife calls them Italy Fingers, which I find tragically hilarious.
    I live in Atlanta and it seems that all the alternator shops around me are either permanently or temporarily closed. Does anyone have a recommendation for a rebuilder that could handle this project and would be willing to ship?
    On a related note, is the 83A upgrade worth doing? What benefits does this have for a '78?
    Thanks!
    E
  2. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    Why not just buy a new alternator , thats what I did for my 89, It was not that expensive.
    Im sure you wont have a problem finding one.
    Thank you
    mike996 likes this.
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Here..
    http://nationsautoelectric.com/services.html
    They build our custom units for the race engines. They can do everything from rebuild to sky's the limit.
    Here's the thing, the tiny metric belt is the limiting factor on amperage, most one can support is 110, that's pushing it for belt life. For a stock systems 65-100 is fine, 95-100 helps though.
  4. mwr4440
    57,700
    Bavaria, The 'Other' Germany
    Mark W.R.
    #4 mwr4440, May 29, 2021
  5. gte619n
    gte619n Karting
    159
    Atlanta, GA
    Evan Ruff
    @smg2, thanks for the tip! I will contact them on Tuesday.
    @mwr4440, that's a great thread. I'm planning on switching to LED headlights, which I imagine should reduce draw. From there, I was going to swap out the stereo to a simple single DIN, Continental Bluetooth Radio. I don't imagine that will draw much more (maybe less?) than the 70s era Blaupunkt in the car today. Thanks for the tips!
  6. mwr4440
    57,700
    Mark W.R.
    The Collective WISDOM of FChat NEVER Ceases to Amaze me and HELP Me make the wisest decision for ME.
    SMG is one of my BEST Resources here. He talks, I LISTEN.
    Best of Luck on your Project.
  7. lopena
    lopena Formula Junior
    741
    Evan:
    I send my alternators and starters to ABC PARTSWERKS in Naples, Florida (920-378-5538).
    Good luck!
    Alan
    N.J.
  8. ProvaMo
    ProvaMo Formula Junior
    Jun 29, 2004
    345
    Mid West
    Paul John
    If you've pulled the alternator out yourself, you could clean and rebuild it yourself. I did mine years ago (can't recall where I got the parts), I see SuperFormance has at least the brush component: https://www.superformance.co.uk/308/electrical.html
  9. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Having just rebuilt my alternator 3-4 months ago (and I knew how to do it before I started), here's some advice: have a shop that specializes in this, do it.
    My rebuilt one looks stellar, and from all research I could do, had the correct parts. It was certainly assembled correctly. And it still fails under load. To save hassle, I bought another one and will eventually take my rebuilt-one to another shop and have them test it fully on a dyno and determine why the hell it's still under-performing.
    So, consider avoiding the pain I went through.
  10. gte619n
    gte619n Karting
    159
    Atlanta, GA
    Evan Ruff
    @thorn Ouch, sorry you had so much trouble! I'm planning on sending it out for sure!
  11. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Just curious - I assume the Ferrari alternator is just a standard (originally) Bosch alternator model with that vent cover attached to the back. Is that correct?
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Unfortunately, no. It's an obscure tractor unit of European use. It's an oddball, however the guts are easy enough to replace, though if memory serves the stator is odd sized as well. Off the shelf replacements don't exist if that's what you're asking.
  13. Rifledriver
    36,750
    Like radiator repair, alternator rebuilding seems to be a dying industry. I had so many train wrecks trying to find a competent rebuilder in Texas I am sending them to California to have my old guy do it. Same with most machine work.
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    It's like VT radio and tv repair of yore. It's gone from repair, to component replacement and next up is throw out the vehicle and get a new one.
    At some point even getting the internal parts is going to be impossible. Look at the new gearboxes, internal seals and components that are not available, period.. have to get a whole new box. Some enterprising shops are getting custom made lip seals... That's all that needs fixing in most cases..a lip seal. But to the mfg... Bin the whole thing!
    Tangent... McLaren control arm ball joint... Have to buy the entire arm, yet the ball joint is held in with internal clips, it's rebuild able from the mfg.. but no, they don't supply the ball joint. Huh? So does a shop invest in 5k plus units of ball joints or just have the customer buy a whole new arm? It's absurdity like that, that's why we are losing the art of repair... It's just R&R components.
    tbakowsky likes this.
  15. gte619n
    gte619n Karting
    159
    Atlanta, GA
    Evan Ruff
    Quick update: Adam at Nations declined to rebuild the alternator. He said he was unfamiliar with the unit after I sent a picture. The guys down at ABC Partswerks are going to tackle the job, although they're running 10 days, so we'll see how it goes! Thank you for all the recommendations!
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,054
    Dumpster Fire #31
    SMG
    Hmmm that sucks...
    They custom make the ones we use. Odd..
  17. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I rebuilt mine and described it in detail here:
    https://www.ferrarichat.com/forum/threads/dereks-308-engine-rebuild.535247/page-16
    The only test I didn’t do was a megger test on the field and stator windings but the resistance test showed no shorts or earth leaks and it tested fine on the bench.
    I had some Chinese Bosch copies (65 amps) that I sold for $200 on eBay but demand was low so I didn’t order a second batch after the last one sold a year ago.
  18. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    Derek - I don't need an alternator rebuild (yet) but for the day that I might, I read the post that you linked re the alternator. EXCELLENT write up/pics..superb job. I didn't check to see if it's also part of the site's Technical/DIY thread but if it's not, it should be!!! Very nice work. :)
  19. gte619n
    gte619n Karting
    159
    Atlanta, GA
    Evan Ruff
    ABC was fantastic. They are the most friendly guys and they did an excellent job on the alternator. Looks brand new and is pumping out the electricals like nobody's business. Highly recommended. $250 for the complete rebuild.
