Airplane physics question | Page 105 | FerrariChat
Discussion in 'Other Off Topic Forum' started by alanhenson, Dec 3, 2005.
Does the plane fly?
  1. Yes
  2. No
  3. Question doesn't allow answer.
Multiple votes are allowed.
Results are only viewable after voting.
  1. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    19,827
    Northern CA
    Yin
    #2601 ylshih, Nov 25, 2017
    The original post is a repost and rewording of a puzzle that apparently began circulating in English around mid-2005. If you search you will find a lot of differently worded versions.
    However, the "original" wording of the problem was apparently posted in Russian in August 2003. Even then it was a posting of a conundrum apparently posed at a school, so that could also have been a variant. Still it is the earliest and most original recorded instance so far.
    http://forum.ixbt.com/topic.cgi?id=64:417
    Island Time likes this.
  2. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    I think you left out a key portion of the translation:
    "The aircraft (reactive or screwed) stands on the runway with movable coating (type of conveyor), the cover can move against the direction of take-off of the aircraft, it has a control system that tracks and adjusts the speed of the web so that the speed of rotation of the wheels of the aircraft is equal to the speed movement of the canvas. The question is: will the plane be able to scatter on this canvas and fly off?"
  3. ylshih
    Honorary Owner
    Mar 21, 2004
    19,827
    Northern CA
    Yin
    Not me, the browser translator. ;)
  4. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    If you understand the parameter "moving in the opposite direction of rotation" to mean the spin of the wheels, then you would need to have the conveyor constructed as a giant wheel, that also spins. The conveyor is not being described this way.
    The question was meant to be about physics, not semantics.
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Moving in the opposite direction of rotation cancels wheel rotation.
    Doesn't matter if it's a conventional type conveyor with drums at each end or a sheet of material pulled along the ground, the above remains true.
    If it's about physics and not semantics I think we already agree the plane would fly regardless
  6. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,546
    E ' ' '/ F
    Trailer Swift
    No way it takes off, the ground speed would not be high enough.
  7. KKSBA
    KKSBA F1 World Champ
    14,930
    SBarbara-La Jolla CA
    KKSBA
    Lol. More of this! :D It’s all about airspeed not groundspeed. They are called airplanes not groundplanes for a reason!
  8. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    51,549
    SFPD
    Dirty Harry
    IIRC, Tillman lives by a private airstrip. Gives him time to observe, which he does quite well.
    Regardless, Pitot Tube would say "No groundspeed *or* airspeed for you!"
    It won't fly.
    Sent from my SAMSUNG-SM-J727A using FerrariChat.com mobile app
    KKSBA likes this.
  9. Island Time
    Island Time F1 World Champ
    10,877
    E. TN
    David
    #2609 Island Time, Jun 30, 2019
    I wasn’t even aware pitot tubes *ever*....*measured*....ground speed.
    Cool stuff.:cool:
    wax likes this.
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    LMAO
    wax likes this.
  11. richard_wallace
    richard_wallace Formula 3
    Feb 6, 2004
    1,956
    Cincinnati, Ohio
    Richard Wallace
  12. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner
    Dec 1, 2000
    59,668
    Southlake, TX
    Rob Lay
  13. Ak Jim
    Ak Jim F1 Veteran
    8,498
    North Pole AK
    A possible problem might be exceeding the maximum tire speed and resulting tire failure.
    Island Time and KKSBA like this.
  14. werewolf
    werewolf F1 World Champ
    11,022
    goodbye
    Even though the question is badly phrased, the real key to understanding the dynamics is that the conveyor belt speed must be constantly increasing ... a conveyor belt that moves rearward at a constant speed will not exert a rearward force on the plane, but a rearward-accelerating conveyor will exert a rearward force on the plane. All the "experiments" that i've seen fail to understand this essential point (more broadly, fail to understand inertial vs non-inertial frames of reference).
    In brief, the question essentially "inverts" F=ma :)
    If the conveyor belt actually accelerates rearward at the correct rate, applying a rearward force on the plane to match the forward thrust of the engines, the plane can & will remain stationary relative to the ground and surrounding air.
    Garretto likes this.
  15. rob lay
    Dec 1, 2000
    59,668
    Southlake, TX
    Rob Lay
    do the wheels really matter? what if it was skis instead? :D
  16. werewolf
    11,022
    goodbye
    nah the wheels don't really matter.
    Heck, throw a brick on a conveyor belt. If the belt (and brick) move at a constant speed, the conveyor belt is imparting no force on the brick (no force is required to move an object at a constant velocity). If, however, the conveyor speed is increasing ... then the conveyor is indeed imparting a net force on the brick (a net force is required to accelerate a mass).
    A constant-speed conveyor belt cannot keep a plane stationary, but a rearward-accelerating conveyor can.
  17. Garretto
    Garretto F1 Rookie
    Sep 3, 2003
    4,932
    Bilbao, Spain
    Rodolfo Di Pietro
    Correct, this is key to the question. Also essential, as you initially said, that the question is badly phrased, which explains the strong opposite reactions of people. Anyway the rearward-accelerating conveyor would need to accelerate infinitely almost instantly, so totally ficticious. A real world setup that tried that would result in wheel and conveyor destruction in seconds.
    ddrewesusa and Jaguar36 like this.
  18. Hopeful
    Hopeful Karting
    May 31, 2019
    143
    Vero Beach, FL
    Tony M.
    Can't believe folks can't get this. The wheels have nothing to do with the ability of a plane to move forward. They only keep the belly from scraping on the ground during take off and landing. The rearward-moving conveyor belt that matches the wheel speed is doing nothing more than setting up a pseudo zero friction scenario. Analagously, imagine the plane taking off on a frozen lake where the wheels have zero friction and therefore can not do anything to help propel the plane forward (not that they ever do anyway). The engine/propellor will still drag the plane forward across the ice and it will eventually reach take-off speed. No different on the conveyor belt. Unless you somehow believe that the conveyor belt moving beneath the rotating wheels somehow exerts a massive rearward force on the plane. The rearward force is essentially zero, particularly relative to the force exerted by the engine/propellor.
    INTMD8 and rob lay like this.
  19. werewolf
    11,022
    goodbye
    A rearward moving conveyor ... moving at a constant speed ... exerts zero force on the plane. Can't possibly balance the forward thrust of the motors/engines.
    A rearward moving conveyor ... that is accelerating ... exerts a rearward force on the plane. If the acceleration is fast enough (infinite acceleration is certainly not required, since infinite force is not required), the rearward conveyor force can balance the forward thrust of the motors/engines and keep the plane stationary.
    The difference between a constant-speed conveyor belt, and an accelerating conveyor, is no small matter. The difference is huge, and quite fundamental ... as different as a body moving at a constant velocity versus a body that is accelerating.
  20. ylshih
    Honorary Owner
    Mar 21, 2004
    19,827
    Northern CA
    Yin
    The problem statement starts with the plane at rest, so acceleration of the conveyor belt is a necessary implication from the conditions.
  21. JL350
    JL350 Karting
    Jan 20, 2013
    205
    No wind and the conveyor matches the ground speed of the plane exactly means that the acceleration due to thrust from engines is the same as the acceleration of the conveyor in the opposite direction so no forward velocity. No forward velocity means no air speeds over the wings means no lift is generated, means no flight, therefore plane is essentially a noisy rock.
    ddrewesusa likes this.
  22. Hopeful
    Hopeful Karting
    May 31, 2019
    143
    Vero Beach, FL
    Tony M.
    Jeez, even the myth busters demonstrated that the plane will take off. The only thing the conveyor belt does is spin the wheels at twice the speed they would normally spin on a take-off roll. The wheels don't drive the plane, the engine thrust does. And the wheels turn freely (essentially) on the conveyor belt meaning they do not get dragged backwards by the conveyor and do not impede the forward thrust of the plane.
  23. werewolf
    11,022
    goodbye
    Mythbusters test was fatally flawed. Constant-speed conveyor does nothing.
    I'm shocked at how many people don't get the essential, fundamental difference between an accelerating conveyor and a constant-speed conveyor ... the fundamental difference between an accelerating body, and a body moving at a constant velocity ... an inertial frame of reference, and a non-inertial frame of reference. These are most definitely not pretty much kinda the same things ...
    Qvb likes this.
  24. Hopeful
    Hopeful Karting
    May 31, 2019
    143
    Vero Beach, FL
    Tony M.
    Wow, let's try another analogy that might be simpler to understand. The engine/propellor create thrust which ultimately acts as a force in the forward direction. Instead of the engine/propellor, consider a sufficiently powerful winch with cable attached to the front of the plane which can exert the exact same force as the engine/propellor would. Do you really think you could not winch the plane forward on free-wheeling tires over a conveyor moving backwards, regardless of the conveyor speed. Likewise, the engine/propellor are doing nothing other than winching the plane forward. The force due to friction between the conveyor and tires is so small compared to engine thrust as to be negligible. Laughable really.
    rob lay likes this.
  25. werewolf
    11,022
    goodbye
    You still don't get the real, fundamental difference between:
    - a body moving at constant velocity, versus a body that is accelerating
    - a conveyor moving at a constant velocity, versus a conveyor that is accelerating
    The difference between "constant velocity" and "acceleration" is not small, nor something to just "gloss over" (as you have been doing). The difference is HUGE, and fundamental to ALL of physics. Pretending that there is no difference, does not help your case. So far, you have not acknowledged or understood that there even IS a difference :rolleyes:
    Once more: throw a brick on a conveyor belt.
    IF the conveyor belt is moving at a constant speed, THEN the conveyor belt is exerting NO force on the brick. Why? Because no force is required to move an object at a constant speed.
    IF the conveyor belt is accelerating, THEN the conveyor belt IS exerting a net force on the brick. Why? because a net force IS required to accelerate an object.
    In one case, there is NO net force. In the other case, there IS a net force. Can't get much clearer than that!
    (It's OK that you don't understand the difference between "constant velocity" and "acceleration" ... the mythbuster guys were equally clueless)
