Aircon receiver dryer | FerrariChat
Discussion in '456/550/575' started by asalcedo, Jan 26, 2017.
  1. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    I have purchased a reconditioned aircon compressor for my 1998 550 Maranello.
    The supplier tells me: “Before the compressor installation the AC system has to be flushed and the receiver dryer has to be changed”
    Is it true that the receiver dryer has to be changed? I have not heard of it in the many posts I have read about aircon compressor here.
    If so, can someone tell me the part number?
    Thanks,
    Antonio
  2. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,797
    Dallas Texas
    If you know you know
    The receiver/dryer is a lot like an oil filter for your a/c system, it catches imperfections and such and keeps things working as they should.
    While I do not have the actual part number, I DO have a connection for you to get one:
    McCains AC Parts
    10930 Alder Circle
    Dallas Tx 75238
    972-685-6888
    Hope this helps!
    S
  3. ///Mink
    ///Mink Formula Junior
    Sep 5, 2006
    818
    Fair Oaks, CA
    Tom Mink
    Yes. Replace it.
  4. tazandjan
    39,010
    Your maintenance schedule calls for the receiver/dryer/filter to be changed every two years. Look in your owners manual.
  5. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    I don't think there are many dealers that will actually do this. Is that something lost in translation where they meant the interior air filter? I seriously doubt there would be any benefit to exchanging the dryer if the system has not been open, especially with the miles our cars are getting.
    If the system has been opened, it should be exchanged. If the system has been opened for longer, the system first should preferably be evacuated once or twice before exchanging the dryer, so there is a lot less moisture to absorb.
    Why is the compressor being changed?
  6. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    You MUST replace your receiver/drier when replacing the compressor. Why are you replacing the compressor? If it was leaking, the filter should be all that needs replacing with it. If it was making noise/seized/mechanically failed, you should replace your TX valve as well, at minimum.
  7. tazandjan
    39,010
    #7 tazandjan, Jan 26, 2017
    166- Look in your owners manual. No, it is not the environmental filter.
    I seem to remember you recommending 5 year intervals for some fluids to a Dino owner, so this may be unknown territory to you.
  8. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Listen to this man, he does it day in day out for a living. :D
  9. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    I am replacing the compressor because it was leaking through the seal in between the two halves (according to the mechanic). After a gas refill (we did two) cool air would be produced for only five days.
    Thank you for the information, I will then replace the receiver/drier.
    Anybody knows the part number and approx. price for a 1998 550?
    Many thanks.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,911
    Isle of man- uk
    Eurospares are showing a new one at £80, they also have some used ones at 1/2 price- it is probably a common part anyway
  11. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Sheesh, that's an unnecessary sneer at my address, Taz. I realise some people here may somehow consider not following the Ferrari bibles as utter heresy, and me telling others there are other bibles and prayers out there somehow as dangerous.
    Let me pray to my gods, I'm letting you pray to yours.
  12. tazandjan
    39,010
    166- Sorry, just could not resist. Too much of a straight line. I might do some things not recommended in the manuals, but I never recommend them to anyone else, except the 5 year interval for cambelts on the 456s and 550.
  13. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    Hi,
    Is this Ferrari Part #64894200 DEHYDRATOR FILTER?
    Thanks,
    Antonio
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,911
    Isle of man- uk
    Eurospares are listing that number as for the 550, used ones at about £40 and new to order at £80.
    Page 56 heating and cooling, item 8 on the 550 section
    If you put the part number in a google search a few suppliers come up
  15. tazandjan
    39,010
    There are tons of substitutes for the receiver/dryer/filter.
  16. fatbillybob
    Aug 10, 2002
    28,559
    socal
    Thank You for posting!
  17. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    So, just to confirm, is Ferrari Part #64894200 DEHYDRATOR FILTER the only part that I need to purchase in addition to the compressor that I already have?
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,911
    Isle of man- uk
    You will have to swap over the pressure switch but that would probably be a copper washer, the hoses look to be cone fittings so straight fit- look at the drawing on eurospares
  19. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    You will need O rings as well
  20. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    I got a quote from an official UK mechanic of 3 hours for the compressor change and gas refilling, which seemed reasonable. However, to change the receiver dryer they will charge 2.5 hours.
    Does the receiver/dryer change require that many hours? Isn't it just like a filter change?
  21. tazandjan
    39,010
    If it is like the 575M, the receiver/dryer/filter is riveted to the body, so needs to be drilled out and then either reriveted or the rivets replaced with a threaded fastener. That adds to the time. It is buried down there pretty deep, too. When my guys replaced mine, not sure whether they riveted it or used a threaded fastener.
    We left the vacuum pump on her overnight to pull a really good vacuum and that really helped AC efficiency. Many shops only do it for 30 minutes or so.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,911
    Isle of man- uk
    Depends upon where it is, i changed a Mondial one in a few minutes but easy to get too.
  23. asgor
    asgor Formula Junior
    Sep 8, 2016
    712
    Virginia, USA
    Taz, would would be a good place to look for a substitute/rebuilt dryer - equivalent to Ferrari OEM?
    For instance, I am looking at Polar Bear, Inc. but they only have an earlier version of the dryer I need https://www.polarbearinc.com/index.cfm/category/289/ferrari.htm (the one I need is part #64799500). Could you recommend another vendor where I could source a substitute item?
    Thanks!
  24. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,911
    Isle of man- uk
    As long as it is the same physical size and fittings it will do the job, just need a bracket to fit it
  25. tazandjan
    39,010
    Yup, no such thing as an updated receiver/dryer/filter as long as it fits. Polar Bear should be a good source for a new one. If possible, get one in a sealed package so you do not start with water already absorbed into the unit. Pulling a good vacuum will probably get most of it out, but might as well start with the best conditions you can. We put an OEM into mine, but that is mostly a waste of money. It did come sealed, though, and not much chance of moisture getting in here in New Mexico. We had 1% humidity here a year or so ago.
    FBB used to bake his old one in the oven to get the moisture out. Eventually, though, they need changing.
