430 - Airbag light on | FerrariChat
430 Airbag light on
Discussion in '360/430' started by Mario Andretti, Feb 11, 2024.
  1. Mario Andretti
    Mario Andretti Formula 3
    1,745
    Boston
    Hi,
    I pulled some codes of the Computer when I was doing my conversion due to some wiring issues; and by mistake I scanned the airbag system (did a complete scan) , and my seat was not connected.
    I think that triggered the airbag light, and I can no longer delete it with my tool (connecting to the airbag system does not work with the Thinkdiag).
    Any tricks on removing this or I need to go to the dealer?
  2. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Is the airbag light on?
    When I fixed mine the airbag light went off before I'd cleared the codes, so didn't really need to clear them but as I could, I did.
  3. Mario Andretti
    1,745
    Boston
    Yes it stayed on now, won't go off, and I can't clear it.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Unfortunately you need a SD or a Leo
  5. Mario Andretti
    1,745
    Boston
    I was afraid that the answer will be just that.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    The other choice is to send a request to launch and hopefully they will fix in the next release ..they do respond but takes forever
  7. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    I would say that you've still got a fault.
  8. Mario Andretti
    1,745
    Boston
    Unlikely, but not necessarily excluded to be the cause .... I only removed the seats and did a scan; whilst seat, and center console plugs unplugged, and it popped up. Bottom line is that I can't even tell what the fault is without a Leonardo or SD... nor can I reset it.
  9. Mario Andretti
    1,745
    Boston
    so.. the plot thickens. Got access to a tool to clear the airbag module. It had 3 missed codes (most likely from seat disconnected) but there is one "present"
    Front Airbag Passenger's Side - 1st stage- Short Circuit
    I have no clue what that means, I did not touch anything airbag related. This seems translated from Italian, not sure what 1st stage means?
    anyone seen this before? I hate pulling all my interior out again...Anyone has any wiring diagrams which show where airbag is wired ? I can start there i guess.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Try this ..turn car off ..wait 5 mins ..disconnect passenger airbag for s few minutes, reconnect it turn key on and start ..got that from a friend of mine who we were diaging the same issue @fstbiker who got that from a airbag ECU rebuild place ..it worked for him
    Mario Andretti likes this.
  11. Mario Andretti
    1,745
    Boston
    So turn car off completely with disconnecting power, or just ignition off ?
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Ignition off only ..while connector off ..clean it with air etc
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Once the airbag light goes off (hopefully) you will still have an old error in system you can delete with even an ap200
    I don't think it will cause any issues leaving it there as well
  14. Qavion
    Qavion F1 World Champ
    13,832
    Ian Riddell
    Where or how?
    The passenger airbag is wired directly to one of the plugs on the Airbag ECU. No inline connectors other than the one on the airbag. Looks like the wiring goes through some pretty thick harnesses.
    The ECU is not easy to get to, so wiring checks wouldn't be easy.
    Diagram here:
    https://www.dropbox.com/t/NLUfsKdnxA8wWXZQ
    flash32 likes this.
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    Mario is putting back together his car ...loose connections on ECU caused issue ..i am sure he will report back
    Qavion likes this.
  16. RedNeck
    RedNeck F1 World Champ
    11,977
    The CSA
    Me
    I doubt that it's the actual fault, but modern airbags are "multi-staged", I believe the first stage is inflation...but I can tell you from experience that a Ferrari will absolutely have an airbag light from powering the car on without everything connected...it happened to me when I turned the car on without my cluster disconnected. I was able to get it turned off with an autoEnginuity system...so I would just clear the light and call it a day. If there were an actual fault it will come back.
  17. Mario Andretti
    1,745
    Boston
    Yes, all fixed.... The 2 plugs on the ECU have a couple of plastic levers which; when moved , pull the plug out.
    I removed both upper and lower center consoles to get to it, and sure enough, the front plug was out a bit. I must of moved it when I wiggled the bigger lower console back on the car.
    Light is gone, and so is the persistent error.
    6 hours later, all fixed , doh :)
    flash32, Kerwind and RedNeck like this.
  18. LorenzoR
    LorenzoR F1 Rookie
    Mario I told you many times leave the titos alone when working on the car:D
  19. kestrou
    kestrou Formula 3
    1,423
    Danville, IL
    Kevin E. Stroud
    MA & Gang,
    Can I get a hand here too? I'm facing the same situation of airbag light on - so exactly which connector did you pull? The E073-A circled in the diagram above?
    So...
    1) Turn Car Off
    2) Whistle Dixie for five minutes
    3) Disconnect E07-A
    4) Whistle Dixie
    5) Connect E07-A
    6) Ignition on - and magic happens!
    Do I have all that right? :)
    Kevin
  20. Mario Andretti
    1,745
    Boston
    In my case that connector was not seated properly, and was out ( I must have moved it by mistake when I installed my console back during manual conversion, light was on every since). If you did not touch that area of the car, I doubt it's the same issue. I would firstly read the error and then see what it's about....
    But you need an SDx or Leonardo or such to read airbag unfortunately. Could be a lot of things; belt sensor, clock spring, etc.
    flash32 and kestrou like this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,672
    Central NJ
    Dominick
    How did your light come on..what were the steps leading up to the light
    kestrou likes this.
  22. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    904
    S La
    Does this also apply to the 360? I had to change the pass air bag and was told by the company that repaired it that I had to have a dealer reset it to delete the air bag warn light.
  23. Mario Andretti
    1,745
    Boston
    In my experience, on the 430; the light went off immediately when I inserted the plug in, i.e. I removed the fault condition. I would definitely try to scan it first to see the error.
    kestrou likes this.
  24. RedNeck
    11,977
    The CSA
    Me
    Just replacing the airbag I don't believe should trigger a light as long as the battery is disconnected, IF the airbag was blown, however, that stores a code that can't be cleared by a reader...you would have to either replace the ECU or have it reset (might involve sending it to a place my MyAirBags), on modern cars the belt pretensioner would also need to be rebuilt...If you have an airbag light after replacement you would just need a reader that is able to read the airbag ECU to see and reset the light.
    flash32 likes this.
  25. kestrou
    kestrou Formula 3
    1,423
    Danville, IL
    Kevin E. Stroud
    Thanks, guys - f32 pointed me towards an inexpensive means of reading the error code, since my Launch X431 won't read the Airbag ECU.
    He recommended this: Amazon.com: Autel MaxiAP AP200 Obd2 Scanner Bluetooth 25 Service Functions Auto OBDII Diagnostic Scan Tool iOS & Android Full Systems Code Reader Same Functions as MK808 Advanced AL329 : Automotive - for about $50.
    It's now en route, but I'm in Florida all next week so will be at least a week before I get to roll up sleeves on this.
    Appreciate the quick feedback boys (especially from flash32).
    Kevin
    Mario Andretti and flash32 like this.
