Airbag & AVH Lights On | FerrariChat
Discussion in '458 Italia/488/F8' started by glennglenn, Jun 27, 2017.
  1. glennglenn
    glennglenn Rookie
    Jun 4, 2006
    18
    My 2014 458 Spider has been at the dealers for 3 weeks tomorrow, they are struggling to get them off, has anyone else had this problem with theirs?
  2. denman4
    denman4 Rookie
    Sep 23, 2008
    27
    Walterville OR
    Dennis
    Loose electrical connection on passenger seat.
  3. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    that's an odd combination of codes....which may explain why the car has been sitting for 3 weeks.
    A common airbag light cause IS a loose connector, however there are a few other sources on the airbag itself, and in some cases, in the ECU's (where it detects impact parameters and triggers).
    The AVH is essentially a "hill hold"; when the car is on a slope, it automatically applies the e-brake until the car pulls away
    The only common thread I can think of that might be causing both are the accelerometers (which detect pitch, yaw, roll) - that would explain why AVH isn't sensing properly AND would also trigger a fault code for the airbags.
    Of course, could also be something more systemic (ECU) or annoying (a small crimp/short in the wiring harness if the 2 wires are close to each other).
    As an illustration, if you had your 458 on the Daytona banking, and going slowly, the yaw sensor would think the car is in the middle of rolling over and would toss countless alerts including TCS, ABS, et al.
  4. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    Had this issue on another car not a Ferrari. Might be the same. It was a burnt rear light bulb. Apparently the Airbag circuit was linked to the brake pedal which in turn turns on the brake lights. Since the bulb was burnt there was a different current going thru the system and this was triggering the warning light.
    Replaced bulb problem gone :)
  5. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    There most likely is an issue with the passenger airbag sensor in the passenger
    seat.
    I would have the dealer check all the connections of the passenger airbag sensor
    in the passenger seat and the sensor itself.
    For some reason, the AVHS error code seems to come in tandem with the Airbag error code,
    although the AVHS system still seems to work, at least from my experience.
    Keep us posted on the findings.
    Very best
  6. glennglenn
    glennglenn Rookie
    Jun 4, 2006
    18
    Finally got the car back on Friday (7th). Fault was traced, with the help of a tech at the factory, to the interior light switch; this was changed at the last service due to light being stuck on, it was interfering with the airbag and AVH, a new one was fitted and everything is now fine!!!???
  7. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Glenn,
    I'm glad they were able to sort it out, but man... an interior light switch throwing those kind of codes? What are the odds?!
    Kind regards,
    Nuno.
  8. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Haha Italian women! As complicated as they are beautiful :)
  9. MANDALAY
    May 23, 2013
    14,168
    AUSTRALIA
    ANGELO
    Looks like it was as I was saying above. Strange that they took so long to discover it.
  10. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,243
    Mel
    As this fault goes back to a service, was their cure for free or were you charged for the "repair" ?
