Air in Mechanical Fuel injection System | FerrariChat
Discussion in 'Technical Q&A' started by Napolis, Mar 25, 2009.
  1. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Has anyone had experience with air getting into Mechanical Fuel Injection systems? Could this have something to do with a defective high pressure pump?
  2. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Well, I had a Mercedes Diesel 300 that did this because the ex-wife ran it out of Diesel. They had to pretty much flush out the whole system because little pockets of air got it and sort of just oscillated back and forth rather than clearing themselves out. Plus it stirred up a lot of crud from the bottom of the tank.
    I thought that the high pressure pump got fed by a low pressure supply pump and regulator and that excess fuel got recycled back to the tank on these old systems...maybe fuel sloshing around introduced some air in the primary loop?
  3. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    When you say flush out do you mean fill system with fuel and let both high and low pressure pumps run for a long time into a tank to purge air?
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    #4 ProCoach, Mar 25, 2009
    Jim, if the system is Lucas and/or Tecalemit based (with slide throttles and a stepped mixture control against the cam at the back of the mechanical pump), you'll just need to get the car running and peer down into the intake trumpets to be sure each injector is firing and not dripping.
    It's not uncommon to see air bubbles in the clear lines to the injectors and through the return bleed to the tank. Your system should have a fuel pressure gauge reading in the 80-100psi range (IIRC) and as long as you get that with the HP pump on, you should be ok. I have cracked the lines at the injectors to try and "purge" the lines, but that's a fire hazard!
    I just finished with a Brabham/Lucas system on a Super Vee and that's what I've done with the Alfa V-12 F1 car in the past.
    This is the system I'm talking about. http://www.lucasinjection.com/Notes%20on%20Installation%20and%20Calibration%20-%20Racing%20Cars%20LSK%20535.htm
  5. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    As I recall this (it was 1981), I believe that they first replaced all the filters, including the big water separator. I believe that they then backwashed the main line back to the tank. What they did to the high-pressure injection pump I did not see. There was talk of replacing it because of grit, but it turned out OK. I think it was allowed to clear itself out by operating it.
    But your car is a gasoline injection system without near that much pressure, right? Like for example, a 1972 mechanical injection Porsche? These had a sort of variable cam that mechanically adjusted fuel delivery by sliding to different spots on the cam profiles to send fuel at the right rate. I don't see how it could by itself get air into the system without also leaking all over the place...I just intuitavely thought about the tank feed situation and the primary fuel delivery pump as more likely air-introduction points.
  6. Rifledriver
    36,760
    Jim I have had that problem from a cracked pickup pipe in the tank. Fuel level gets below the area of the crack and sucks air. Winds up going to the pump as an emulsion and a mechanical system just wont work that way. The fact is if you have any air leakage from the immersed part of the pick up to the inlet of the pump that will happen and depending on how the car is plumbed it may not show up as a fuel leak.
  7. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Hi
    The car starts with priming and runs but soon seems to develop air bubbles that cause it to stall out. (Lucas Mechanical Fuel Injection) There is a check valve in the high pressure pump. We're wondering if it could be malfunctioning or the pump cavitating and introducing air. The system is as you'd expect. Low PSI pumps fill a catch tank and then onto high PSI pump.
    The plumbing has always worked but now we seem to have way too much air. We cleaned and re O ringed the distributor so I don't think it's there.
    Thanks!
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Thanks for that thought. We'll take a look at that. It isn't leaking fuel externally but you may very well be right.
  9. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Both good possibilities if the o-rings are fresh on the mechanical pump. Take a look at the Kinsler site. Lots of good information there. Good luck!
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    This is the logical choice if the system started full and didn't lose prime.
  11. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    Your low pressure system should have a vent on it to purge out any air the low pressure system picks up. This should be a small orifice to let the air out but minimizing the amount of fuel returning to the tank. Any chance it is clogged and allowing the air to get into the high presssure pump?
    Cheers Jim
  12. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #12 Napolis, Mar 25, 2009
    We're investigating all of this and will report.
    This is the distributor opened for cleaning and 002C's instruments with non original lights that we hid inside so I can make those night runs a little easier.
  13. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Cavitation won't introduce air, that would be making something from nothing. Cavitation can produce bubbles of vapor, but those bubbles will collapse as soon as the pressure increases (often with impressive force), so those bubbles are not going to pumped anywhere, and they certainly won't be static in a fuel line.
  14. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #14 Napolis, Mar 25, 2009
    Cavitation was the wrong choice of words I meant an air leak causing the pump to act inefficiently and pump air through the system sounding like it was Cavitating. We think Brian is right and problem is a cracked fuel pick up tube in FI tank.
  15. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Hope you're right: nice catch!
    Still, this would also mean that the air-purge system is either not there or defective.
  16. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I second that!
  17. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    We're about to try to start the car from a 5 gallon tank directly into the high PSI pump. We think air is being introduced into the system below that point probably in the FI tank.
    Does the FI tank likely have an "anti syphon" fuel PU that reaches up over the fuel level which if cracked as Brian thought would introduce air?
    Another question. The high PSI pump has a 2.5 bar one way valve but the system operates at 8 Bar. When the car is shut down PSI bleeds off through the one way back into the tank. Should we keep more PSI in the system when the car is shut down? Will it make it easier to start?
    Thanks for all thoughts!
  18. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    One thing to remember is that a one way valve only works for a short period of time...probably not overnight. They need to have pressure against the high side - substantial pressure - in order to work at all. In near equilibrium, they are must about the same as nothing at all.
  19. Steve Magnusson
    26,516
    #19 Steve Magnusson, Mar 26, 2009
    A higher residual fuel pressure will better help prevent the fuel from vaporizing if the lines are getting too warm, but you'll be limited in how much you can raise it by the opening pressure (~3.4 bar?) of the injectors (or whatever "release valve" is downstream of the ports on the metering unit) minus some reasonable margin. Better thermal insulation for wherever fuel is retained would help too if this is part of your problem.
    Your mixture control unit looks particularly simple -- does it have any provision (like the "overfuel lever" on a road unit) to aid starting/restarting?
  20. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Here's the thing. In this car the fuel is heated. The fuel lines run nestled in the water lines which heats the fuel. TR's also do this as the AC line runs through the fuel tank which also heats the fuel.
    The Fuel pick up inside the FI tank is not cracked. The tank does have an air vent. Should this air vent have a one way valve?
  21. Steve Magnusson
    26,516
    Can't agree that the intention on a TR's AC is to heat the fuel (as on a cold day you wouldn't even be using the AC). More the other way around -- to help the AC work a little better.
    Although the water lines may be hotter than ambient, they are still cooler than a lot of other things so "protecting" them with the water lines isn't unreasonable.
    But is your mixture control unit a "race only" arrangement -- i.e., designed around the assumptions that it wouldn't be restarted and that it would almost always be used for max power?
  22. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    In that case, it never could get hot enough to make fuel temperature much of an issue, no?
  23. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Putting the TR aside on the P car they went way out of the way to run the water line for a long time up against the fuel line and when the water gets hot it definitely heats up the fuel. If they had wanted to they could have easily not have done this so I think there is some reason they want to heat the fuel in this system which I admit I don't really understand. Perhaps to make it easier to vaporise?
    Our problem remains that we have an air internal air leak somewhere that is putting air into the system. We're now trying to narrow down where. It's not in the FI surge tank pickup. We're about to test the high PSI pump and will report. What is the purpose of the internal by pass valve in the high PSI pump?
    The mixture control is Start/Warm UP/Race and isn't cockpit adjustable.
  24. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Correct. This problem is not heat related.
  25. MiuraP400
    Feb 3, 2008
    949
    Arizona
    Jim
    I went through this once on a lightweight E-type. Turned out to be an air leak on the suction side. It was fixed by adding a low pressure pump and a FI tank. I would suggest a simple test (assuming you have access to the fuel pickup). Pull the fuel pickup out of the tank and connect a hand vacuum pump to it. Next seal the fuel discharge on the high pressure pump and the any venting on the FI tank and attempt to pull a vacuum on the system. If it does not hold a vacuum you have found your issue. Just isolate parts of the system until you narrow it down. If it does hold a vacuum then it is not an air leak into the suction side. If it passes the vacuum test then I would check the vent on the FI tank to see if it is fuctioning.
    Cheers Jim
