Air Force Shocks Defense Sector As Secret Fighter Jet Takes Flight | FerrariChat
Discussion in 'Aviation Chat' started by NYC Fred, Sep 16, 2020.
  1. NYC Fred
    NYC Fred F1 Veteran
    9,668
    Fort Lauderdale, FL
    Fred C
    (((The Air Force is already test-flying a highly secretive prototype of a sixth-generation fighter jet, a top official revealed Tuesday, years sooner than expected.
    The so-called Next Generation Air Dominance (NGAD) fighter would be a follow-on to Lockheed Martin's (LMT) F-22 stealth jet, which is a fifth-generation fighter. But instead of a single fighter, the Air Force envisions a "system of systems" that includes piloted and unpiloted aircraft.)))
    https://www.investors.com/news/sixth-generation-fighter-prototype-flies-secret-air-force-tests/
    ralfabco and Boomhauer like this.
  2. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    This is the correct approach.
    The entire dogmatic procurement approach needs to be refined.
    The F-35 prototype flew a long time ago. The F-35 airplane has barely achieved IOC. Quite a few F-35 jets are not the full updated version and the early block versions are not nearly as capable.
  3. Gatorrari
    Gatorrari F1 World Champ
    15,939
    Georgia
    Jim Pernikoff
  4. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    No way the A.F. buys anywhere near 1700 F-35 jets.
    I hope the NGAD is manned.
    Boomhauer likes this.
  5. David_S
    David_S F1 World Champ
    11,260
    Mountains of WNC...
    David S.
    Is it fair if I would wish that the "NGAD" program would consider, something like a "flight of 3," with a manned "lead," and a couple AI "wing men/women/bots?"
  6. Jaguar36
    Jaguar36 Formula Junior
    Nov 8, 2010
    838
    Cherry Hill, NJ
    The DoD has learned from their attempts at having a joint procurement process between the various branches. It won't happen with this as its just an Air Force platform. It procurement process would be more like the B-21 or the Armies FLRAA program which seem like they work pretty well. I'm very curious what this is though, if its really a new design or if its modified F-22 or F-15 or just some unmanned drone. I find it very hard to believe that you could get a brand new manned aircraft flying without it being known years ahead of time. Even if you could hide the budget, you'd never be able to hide the quantity of hiring that would need to happen. Nor would I imagine this would be how it was announced.
    boxerman likes this.
  7. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    No computers during the Pursuit era :D.
    No doubt you cannot stop progress and it is only a matter of time b4 it is all AI, with just a few keyboard operators with a plastic spoon in the flight suit pocket. yawn.
    I have no interest following hi-tech robotic aviation platforms (drones and other crap). Without manning it is just a tool to complete a job.
    May as well follow updated power drills and other efficient tools.
  8. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    #8 ralfabco, Sep 17, 2020
    Using any of the F-15 components is not going to happen. Perhaps some updated derivative of the current engines used, by the USAF. I did read a few months ago that significant technological breakthroughs with jet engines were on the immediate horizon. Maybe the NGAD is using those engines.
    The F-117 borrowed some different components from other platforms. The XF-35 first flight was in 2000. Something has to change to more efficiently demonstrate full IOC, in less than 20 years. Like almost everyone else I have no clue about the NGAD airframe, avionics, and weapons. Lockheed will not be selling new build F-35 jets to the DOD twenty years from now.
  9. tazandjan
    38,056
    They did a pretty good job of hiding the F-117A for years. No reason this should be any different.
  10. tritone
    tritone F1 Veteran
    6,880
    On the Rock
    James
    Understatement.........
  11. Jaguar36
    Nov 8, 2010
    838
    Cherry Hill, NJ
    That was a very different time both from an information, contracting, and engineering perspective. In addition the F117 was a much smaller and significantly simpler aircraft than an F-22 successor would be. It would take at least 10x the number of people to develop, and probably way more than 10x the budget. I don't see a way you could hide that in this day and age.
    Now he might be talking about something like the Have Blue prototypes that were much smaller scale versions of the F117, but why you would mention that at all is bizarre. Rather I suspect he is talking about something like the J-UCAS program, perhaps their is a successor to that or maybe a fighter version of the MQ-25 in the works.
  12. jcurry
    21,545
    In the past
    Jim
    Disagree. Get management out of the way and allow a very, VERY lean core group of engineers off the leash and things will get done, aka Kelly Johnson incarnate. A prototype such as this does not need all the bells and whistles, nor the same design standards as a production fighter meant to have a 20-30yr lifespan. HOWEVER, you also don't want to fall into the Rutan trap of developing a subscale vehicle that then is impossible to scale up to workable full-scale design.
    Gator likes this.
  13. tritone
    tritone F1 Veteran
    6,880
    On the Rock
    James
    Skunkworks! Sadly, I don't know if we can do this anymore, except in an old Dale Brown novel......
    prove me wrong.......please!
  14. tazandjan
    38,056
    Skunksworks is still active and so is Phantomworks. Have worked with both. X-37B was one of the black programs kept under pretty good wraps until they decided to go public. N-G has something similar to SW and PW. Keeping things under wraps is simple since jail time is involved for leaks. Limited access programs operate widely in the DOD. Harder to get access to than most SCI info.
  15. tritone
    tritone F1 Veteran
    6,880
    On the Rock
    James
    To elaborate a bit; I think we have the technical abilities, esp given the advances in tech, I worry more about the will, and the politicization of things.....tho I guess that's nothing new....probably why KJ and others like him were/are so rare.
  16. Jaguar36
    Nov 8, 2010
    838
    Cherry Hill, NJ
    The problem is two fold, first for something the size of an F-22 you need a large team. A bigger aircraft isn't just the same number of parts all scaled up, its alot more parts. It's also not like a commercial jet where there is ton of acreage structure thats all the same. Plus it would need to be all composite, which takes alot more work to size efficiently than the metallic structures of Kelly Johnson's day.
    Secondly, the aerospace industry is hugely risk averse these days. That means a ton of testing, analysis and review boards. Any new aircraft, even a one-off tech demonstrator will be fully gauged, and proof tested before its ever off the ground. Both of these mean that a full size, 50,000 lbs, manned aircraft is gonna take alot of people to get flying. The airframe engineer community is not very large, and when a program like that starts up word gets out. Like I said, I think its far more likely that Roper was talking about something small and probably unmanned. I think the best similar story in recent times would be the B-21. Everyone knew for years before it was announced that Boeing and NG were working on something and it didn't take a genius to figure out it was the next bomber.
    boxerman and SVCalifornia like this.
  17. Gatorrari
    15,939
    Georgia
    Jim Pernikoff
    I'm surprised that Northrop Grumman never gave their ADP group a fancy name. Considering the name of one of their products, how about.....Spirit Works?
    Bob Parks likes this.
  18. kevin956
    kevin956 Formula Junior
    Jan 26, 2004
    495
    Pasadena, CA
  19. jcurry
    21,545
    In the past
    Jim
    The size of the aircraft does not dictate the size of the team. You actually contradict yourself in this regard when mentioning acreage type structure on a large commercial jet. Yes you need people to cover all aspects of structure/systems/propulsion/etc, but that does not mean you need to have a large group of people in each of those disciplines. Properly designed composite structure can actually reduce part count, and is no more difficult to size than metallic structure.
    Just about everything you wrote is the antithesis of my statement. I was very fortunate to be in R&D at the beginning of my career. Had I been thrown into a production type environment at the beginning my career path likely would have been decidedly different. The last 23 yrs as an independent consultant has only reinforced my opinions regarding bloated top heavy organizations.
    Gator likes this.
  20. ralfabco
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
  21. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,244
    I assumed it was LMT after the Raptor they made and NOC making the next B2. There is no other competition other than Boeing, which seems to consistently fail at making new military or space aircraft and rely on buying from others (F/A-18 and F-15 from McD and space shuttle and B1 from Rockwell) on top of dealing with commercial aircraft problems.
  22. tazandjan
    38,056
    Boeing fielded the MQ-25, X-37B and other new air/spacecraft like the digitally designed and produced T-7, so I would not count them out. L-M acquired GD and that is where a good chunk of their fighter expertise lies, just like Boeing and McDD.
  23. jcurry
    21,545
    In the past
    Jim
    BD-10 —> ATG Javelin —> T-7
