Air condition not working properly | Page 2 | FerrariChat
Discussion in '456/550/575' started by DPA360, Apr 7, 2014.
  1. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Hey bud havnt got around to fixing it. Drove the car this weekend AC works great but when set to 0 hot air comes out instead of shutting down & nothing coming out. Can not remember if this is normal for these cars or not. Any ideas?
  2. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Previously Maranello
    Hi,
    I fixed the issue last WE.
    CHecked the A/C panel first. the knobs were OK and resistance was clearly changing correctly.
    THen checked the fusebox and each relay. Did some swaps and this is not the issue.
    Unmont the glovebox to reach that fmous part 64280200 VALVE/SOLENOID (a PAIN to access the top bolt).
    I dismanteld it, change the 2 Mosfet as explained in this thread: Fix MK2 ATC heater fan controller - XPowerForums - For MG, XPower & Motorsport Enthusiasts
    All all is good now!!!!
    All is summurized on our French forum La Ventilation De L'habitacle Est Trop Forte! - Ferrari 456 - 550 Maranello - 575 M - Ferrarista - Ferrari Owners Only
    F456M likes this.
  3. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Great job!! I will try to do the same next week. Did you order from euro spares? Last question ;) did it stop all leakage of air from vents when you set knob to 0?
  4. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Sorry just saw your post again and noticed you repaired it instead of replacing it! Awesome
  5. henri66
    henri66 Karting
    Oct 10, 2006
    109
    I did not really want to order a 250€ part if I did not know it was broken or not.
    So changing two 2€ a piece MOSFET I can do it even if not needed.
    And yes, on zero position, no air at all. ZERO :)
    If you do not want to repair, you can find it on the internet for cheaper than euro spares. If you leave in the UK, it is also a rover part. Around 120£.
    F456M likes this.
  6. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    Mk2 45/ZS ATC Transistor Pack Repair (Kit or Service) - JGN000010
    Mk2 45/ZS ATC Transistor Pack Repair (Kit or Service) - JGN000010 | Discount MG Rover Spares - Free UK P+P
    F456M likes this.
  7. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Just took out glove box and can't find switch. Any help?
  8. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Does anyone know how to get to this part? I dismantled the glove box complete as it stated in previous post but still can't seem to find it. It also mentioned that non ATC cars don't have it but have a coil. What is an ATC car? I'm stuck I have a 99 US 550. Any help would be greatly appreciated! TIA
  9. henri66
    henri66 Karting
    Oct 10, 2006
    109
    I did it on a 456. No idea where it is on the 550. Did you check on the drawings and compare 456 position and 550 one?
  10. Cribbj
    Cribbj Formula 3
    By the Ricambi diagrams, it looks to be in the identical location for the 550 as the 456. Whether this is true or not.....?
    Where is this reference to ATC and non ATC cars? I don't find it in the WSM for the 550, nor on the Ricambi page for the parts?
  11. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    #36 DPA360, Jul 9, 2014
    I found the reference to ATC in this post were they spoke a
  12. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    #37 DPA360, Jul 9, 2014
    I also called Ricambi and spoke with Aaron, great guy;) but he as well has no idea where it's located. This is how I'm looking up to now:(
  13. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    #38 bay, Jul 9, 2014
    for me it's the same position .
    flat-12 likes this.
  14. Cribbj
    Cribbj Formula 3
    Ahh, OK then. Perhaps that's something specific to their cars, not ours.
    From the parts diagrams, it looks like it would be embedded in the right (passenger) side of the evaporator assembly. Perhaps Henri will point it out in your photo, or offer some advise.
    How tough was it to get that dash cover off on the 550? Sounded like it was a real bear on the 456, according to Henri (and he's no novice).
  15. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    I didn't remove air bag. Do I need to remove air bag to get to unit you think? It was pretty easy to remove glove box, havnt got to airbag yet hopefully I won't have to:)
  16. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Hey Bay, did you do the same job as I'm attempting? Is removing the airbag necessary? Any info would be great appreciated! Tnxs
  17. bay
    bay Formula 3
    Mar 13, 2011
    1,268
    Belgium
    Bernard
    not necessary to removing the airbag only glove box ;)
  18. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Sounds good I will go back tomorrow to garage and start digging on the left side of passenger side and hopefully find it. I'll keep u guys updated. Tnxs again for all the support👍
  19. 308 GTB
    308 GTB F1 World Champ
    11,643
    New Jersey
    Barry Wolinsky
    It appears that Ferrari part #64280200 is a resistor block similar to the one in my 944 turbo (see post #16 in this thread: http://www.ferrarichat.com/forum/143044106-post16.html)
    If that's the case, the connector contacts should be cleaned and see if that takes care of the problem before ordering a new blower regulator.
    ps. John, your French is fine!
  20. Cribbj
    Cribbj Formula 3
    Et ça d'un Américain :)
  21. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    Un Américain qui connaît français bien, mon ami.
  22. Cribbj
    Cribbj Formula 3
    Je sais, Barry; c’était un blague, cher ami :)
    J'ai fait le même remarque un fois à un Algérien ami, que son français était très bon et il a ri et a dit la même chose pour moi, "et ça d'un Américain" :)
  23. henri66
    henri66 Karting
    Oct 10, 2006
    109
    So on the 456, it is exactly where Bernard has put a red arrow on the picture he has posted.
    On post #38
    So on post 37, on your car, it looks like you have to give us a SIDE photo of the air conditioning unit, next to the black hose that is above the + thing on your picture.
    This is where the DAVIA is. I can post you a picture of what you look for that could help ;)
  24. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    Sounds great! Will take another pic and post.
    Tnxs!
