agm battery? | FerrariChat
agm battery?
Discussion in 'Technical Q&A' started by 95spiderman, Dec 26, 2011.
  1. 95spiderman
    95spiderman F1 World Champ
    16,815
    ny
    i have an interstate mtp24f battery in my 71 xke and just got a griots battery manager. it has setting for std and agm batteries but i dont know what type this is. cant get info from interstate or griots either. thanks
  2. tepps
    tepps Karting
    Oct 15, 2010
    103
    Buffalo NY
    Tom Tepas
    #2 tepps, Dec 26, 2011
    this means absorbent glass mat battery, Alot of the newer BMWs have these, you dont.Just put in on std.They are meant for deep cycling, non servicable. Cost 2 or 3 times as much.
  3. 95spiderman
    16,815
    ny
  4. DGS
    DGS Six Time F1 World Champ
    69,580
    MidTN
    DGS
    An Interstate MTP24F is a "Mega Tron Plus" -- a standard lead-acid battery.
    Use standard setting.
    AGM batteries are a deep cycle alternative battery type, like the Optima yellow-top.
  5. docf
    docf Formula 3
    Sep 14, 2008
    1,404
    Florida
    Gary
    Sorry not quite right! Red top optima is a regular AGM, yellow top is a deep cycle AGM. AGM's are sealed lead acid battery's that uses microfiberglass to trap gases during dischge cycle and recharge. It is a maintenance free battery using gas recombination like a true Gel battery. Gel battery uses Gel to trap gases during cycling instead of microfiberglass. Gel battery's due to gel medium is more expensive to manufacture. It too is a maintenance free battery. Both retain charge much longer than old lead acid batteries. Both Gel and AGM have a problem with improper overcharging and that is destruction. Have lost two Optima red tops this way. No problem with using the "tender", but if using a regular charger, use charger specified for eg AGM, Gel or regular lead acid. Many new chargers have this capability of separating type with aid of a switch.
