Aftermarket wheels and Ferrari center caps | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by 2000 456M, Feb 18, 2014.
  1. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    There are some great wheels out there, but the center holes have a larger diameter than OEM wheels. As a result, Ferrari OEM center caps won't fit. Anyone know of a good-looking solution to the problem?
  2. dave80gtsi
    dave80gtsi Formula 3
    1,904
    Ohio
    Dave Meredith
    #2 dave80gtsi, Feb 18, 2014
    A little ingenuity and some time spent in the plumbing aisle of your local hardware store is all that you'll need.
    FerrariFR33458 likes this.
  3. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Interesting solution, but with silver center caps on the 456M, I'd prefer something a bit more elegant. Does anyone know if there are silver-colored adapter rings on the market where the center cap snaps into the ring and the ring then snaps into the wheel?
  4. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Hey Dave,
    What kind of wheels are those?
  5. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,749
    Boston, MA
    John E. Kenney
    I was wondering about this thing myself. Anyone know of O.Z. wheels that would work on a 348?
  6. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
  7. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    #7 dave80gtsi, Feb 19, 2014
  8. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    Well, then, why not use the PVC parts to do a pattern mock-up, and then find someone with a lathe who can turn something for you out of some aluminum pipe?
    By the way - since the picture above was taken, I have repainted the original gold-painted ring with black paint, which makes it blend better with the yellow cap's black perimeter.
    DM
    FerrariFR33458 and Boomhauer like this.
  9. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Good idea, of course; you can always have custom work done. I was just hoping there was some simpler approach that didn't cost more than the wheels! :)
  10. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Didn't recognize them...I had a set about 15 years ago.
    Good work Dave.
  11. Cav
    Cav Karting
    Feb 27, 2014
    69
    New Zealand
  12. 997_T_u_r_b_o
    997_T_u_r_b_o Rookie
    Nov 14, 2020
    35
    Steve S.
    Dave80gtsi did your custom work sustain the center cap long term? Does the Ferrari center cap clip onto the gasket? It looks like the prongs are shorter then the rubber gasket wall. Thanks in advance.
  13. dave80gtsi
    1,904
    Ohio
    Dave Meredith
    Wow, a Blast From The Past!
    The fit of the OEM yellow center cap into the rubber ring was very snug, as you had to stretch the rubber a bit to fit it over the center cap's prongs. Then, the fit of the rubber ring's O.D. into the PVC ring was also snug. I did have to experiment a bit with some different rubber parts so to find one whose wall thickness fit the two above conditions (that's what I meant by my comment about spending time in the hardware store's plumbing aisle).
    Then, the PVC ring is held to the wheel hub via clear silicone caulk, applied from the backside of the wheel. That's why I drilled some holes into the PVC ring as you can see in the picture, as they formed 'keys' into which I forced the caulk so to help to secure the PVC ring to the wheel.
    All in all, the whole process worked a treat. NO looseness whatsoever after years of use.
    DM
  14. 997_T_u_r_b_o
    Nov 14, 2020
    35
    Steve S.
    Lol! Thanks for the response!
