Aftermarket Replacement TPMS Tire Pressure Monitoring System Sensors | FerrariChat
Discussion in '612/599' started by JM280z, Jan 29, 2022.
  1. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    852
    Jake
    Any specific brands and/or part numbers recommended for aftermarket TPMS sensors for 599 HGTE?
    https://www.ebay.com/itm/304318629776?fits=Model%3A599+GTB%7CMake%3AFerrari&epid=22021995144&hash=item46dacdc790:g:O1UAAOSwPGhh56wd
    https://www.ebay.com/itm/313839861387?fits=Model%3A599+GTB%7CMake%3AFerrari&epid=14006363576&hash=item4912503e8b:g:4P8AAOSwNcxh56wn
    https://www.ebay.com/itm/313840541061?fits=Model%3A599+GTB%7CMake%3AFerrari&epid=14021993320&hash=item49125a9d85:g:rVAAAOSwk~1h6FJi
    https://www.ebay.com/itm/303578791315?fits=Model%3A599+GTB%7CMake%3AFerrari&_trkparms=ispr%3D1&hash=item46aeb4bd93:g:WL0AAOSwzxBe1YMz&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSzaVbXtmGxqmWnpn8RLN2q5%252BcoeL49TkJChs15%252Ff6ewKUVRW3PYOUqUVA7p4BZGnv83dbYBXtzEAZjXpCMSMoPBjzBSKikq9RCv32Tm%252BcHPiYgF5qIMVu%252BBBxlaxPyCrYBV07LKENL2X1Te6uykfQv%252F5lVuKy2D%252BRznpY%252BtEzzZarm4zzFuo%252B1JEpYYmw2wMoFGrxkceVz0AZVirs5LU%252B%252F2wQ6WXNSBJVthNNCtmxdvwgxPwNOzmyrNFOTUB9q0kequ2aAQ%252Fj%252BexKV29EUrzbSBIj7Y4nPjT%252FZX3tSTNyj5HHr1l3XSs9edZgr4vYbt3xv7dgVb9Afv8roSKetPm7Z6L%252FCxKasFJtct1SslZdPYIlDAwD7FdFBRWfUXBwTFCy7IK7%252Bf2DLhpbGiLxGTs8oq9M%252F54DpzUVUuHw0wq%252Bd0FTd%252BXEfV8%252FvTJL2J7GUNNWpwX66noC3aF%252F1hRO%252FC1bMGMPXibK3tT9xiP%252FdXy8lAEc6LAFOrEAChThy3BcZozwOPtrHL59FvE8cvc3T7I3IlnICfsTeNQRTm8dV7jpnZaDJzg9gjsGk5fmsIrgsHjnlVAbo66qIZabdTVkhBdJnEj8OmSkdSdaA92x%252F3%252Fm42HlJEnqGm2nBE0%252BFmkyR9wjntXm%252FcKQ5dQ8%252B21XO7Swyv3PlHACbcMHNlIwYj5lDzh8Cxxb%252B4%252By66qdBPXd7LAEfDYljl4zccWs%252FMRJI32K3v%252BMMdM37%252Bppy45drGUQNkCDMd5jRrvyGBJs7bIUI1RfrqcwiB5Dsiq0YpxQCtfcax7MyecsB3zAPzlq61tZ9KbOdQ%252BXMCfqZzl6yaSBgM10RsVYYFYRhDbSg7PoUh2oAQ%253D%253D%7Cclp%3A2334524%7Ctkp%3ABFBMutSG9dRf
  2. steve moody
    steve moody Karting
    92
    Cape Coral, Florida 33914
    steve moody
    I used this one from EBay. It works just fine. Make sure to tell them to program it for a 599. They shipped the next day.
    ITM TPMS Tire Pressure Sensor 433MHz Metal for 2004-2011 Ferrari 599
    Mark Carbone and JM280z like this.
  3. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    I just ordered them when I ordered tires from TireRack. They are not expensive and work perfectly.
    Mark Carbone likes this.
  4. JM280z
    Aug 22, 2020
    852
    Jake
    It looks like there are multiple ITM 433mHz options. Different manufacturer part #s. Do you know the specific one you got?
  5. steve moody
    steve moody Karting
    92
    steve moody
    The box has the following info:
    ITM TPMS
    Uni-sensor Duo
    Aluminum valve
    P/N 08017D
    UPC 639601080175
    It also has a sticker with the programmed ID code that was done by the EBay seller.
    The aluminum valve stem that is installed on this is slightly shorter than the Ferrari OEM units. This means that the vavle stem does not stick out as far as the OEM unit when it is installed on my HGTE wheel. I had to reduce the size of my air chuck to add air. My old air chuck was too big. Simple. I reuse the original valve stem with this new sensor. Otherwise, no big deal.
  6. steve moody
    steve moody Karting
    92
    steve moody
    It is important to get these programmed by a knowledgeable seller. Again, make sure to tell them that your snesors will be used on a Ferrari 599. The one I referenced on eBay did know what they were doing. I just noticed on the box that it says: "To program Dual Frequency Universal TPMS Sensor 315/314 MHz, 433.92/434.42 MHz sensor AID tool must be updated to version 3.8 or later.
    Skidkid likes this.
  7. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    One of the most common issue is people don't get the old ones very far away so the new sensors will not pair. :)
    Rex71 likes this.
  8. brogenville
    brogenville Formula 3
    2,212
    Robin
    599's/612's will auto recognize new sensors, but universal sensors need to be programmed to behave in the same way (same comms protocol - not just same frequency) as the original Huff/Beru sensors.
    If you want to be bullet proof you can read the sensor ID's from your live data, or you can buy a £50 Autel TPMS tool that can read and program Autel MX sensors. Doing this you can clone your existing sensors so the car doesn't see any change at all. Just make sure to have your old ones out of range or you will confuse the hell out of it.
  9. JM280z
    Aug 22, 2020
    852
    Jake
  10. Mark Carbone
    Mark Carbone Rookie
    Oct 16, 2019
    28
    Cocoa Beach
    Mark A Carbone
    Thanks for sharing this product. I just ordered a set for my 599.
  11. ducatiguy
    ducatiguy Rookie
    Aug 10, 2021
    31
    Ohio
  12. steve moody
    steve moody Karting
    92
    steve moody
    Same unit but I bought from seller "autolow" in Lansing Mich. The units need to be programmed. Autolow did that and they worked right out of the box.
    Steve
    JM280z and ducatiguy like this.
